    Cut Glass Fruit Bowl
    18 Posts 7 Posters 2.4k Views 7 Watching
    • soloS Offline
      Cool model thanks for sharing.
      Took a break from work to play.
      • andybotA Offline
        andybot
        Nice work Chris! Thanks for sharing.
          CJRyan
          Cotty, thanks for responding, I'll look into Indigo more thoroughly!
          Solo, that's almost exactly how it looks sitting on my kitchen table!
          I'm flattered that you took the time to render it. I've seen a lot of your work over the years. Thanks for showing me what it could look like.
          I know because of you experience rendering, you could probably get nearly the same results in many renderers. But out of curiosity, not that I could afford it, what are you using?
          • soloS Offline
            Thank you for the distraction, have not played in a while.
            I used Thea Render, a fast 5 minutes Presto render.
            • BoxB Offline
              @cjryan said:
              I do wish there was a plugin like Chris Fulmers Shape bender that created concave and convex group/components.
              For future reference, Shapebender will bend a bunch of components/groups as long as they are nested in another Group/component.
                CJRyan
                Solo,
                LOL, I let mine grind for hours. And it ain't all that slow! Six core running at 3.7.
                Box,
                Do you mean to tell me that if I'd have bent it on the red axis, then re-bent it (after switching my axis 90 degrees) I could have done it that way? Please show me. But, that's sure a doh moment if that actually works! (and where the heck where you when I asked about that in my first post?)
                Box, this was what I was going for. I wish shape bender could have done it!
                  CJRyan
                  Never mind solo, I just realized I was rendering an entire model, just not the fruit bowl and a floor.
                  But thanks!
                  • pbacotP Offline
                    Wow guys. Incredible!
                    • BoxB Offline
                      Here's a rough version using shapebender just as you describe.
                      It starts off as a group of components but ends up as one component.
                      It may not be as clean as you want, you'll notice some of the faces are split to allow the bend, but it is very quick.
                      You could also use Fredo's Radial Bend, part of Fredoscale.
                      Crystal Shapebender.zip
                        CJRyan
                        Thanks for the example Box,
                        It never occurred to me to bend the bottom twice!
                        Because I sure would have! Oh well, I learned about "Smart Drop" anyaway!
