    3D Truss Models
    1.5k Posts 31 Posters 869.7k Views 30 Watching
    • medeekM Offline
      medeek
      Post or send me a sketch of the D-Style and I can add it in. I'll also add the box gutter and the fascia gutter. This will be a total of 5 different gutter types. I can always add more now that I have the template setup
      Your right it doesn't make any sense to limit the downspout type to a particular gutter style. I will setup some additional options/parameters:
      Downspout Type: RECTANGLE/ROUND
      Downspout Length (ft./m): This length will be measured from the top plate of the wall that the truss or rafter roof rests on.
      For Rectangular Downspouts, the following two parameters:
      Depth: (default value 2.25" or metric value?)
      Width: (default value 3.125" or metric value?)
      For Round Downspouts, the following one parameter:
      Dia.: (default value 3.0" or metric value?)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        The gutter extension is how much the gutter extends past the rake board on a gable roof, this does not apply to a hip roof or dutch hip roof.
        http://superiorgutters.net/wp-content/uploads/drip-edge-ext.jpg
        The vertical offset is the distance the gutter drops down from the top edge of the fascia board, the default is zero.
        With a metric template the dimensions are given in mm or metres with the grid shown in cm. In US units dimensions are in inches or feet with the grid shown in inches.
        design.medeek.com
        • medeekM Offline
          medeek
          SketchUp Essentials has put together a nice overview of the plugin.
          I've been talking to Justin and I may have him put together some tutorials for me. My videos are quite bland compared to his presentation.
          design.medeek.com
          • jujuJ Offline
            juju
            trade information on this one seems to be terrible. See attached PDF, page 11/12 has a diagram of sorts...
            DPI Plastics plumbing & drainage fittings Aug 2011 - low resolution.pdf
            • medeekM Offline
              medeek
              The D-style profile is very interesting mathematically. Its not quite an ellipse but it really has no flats so it is actually more than a rectangle with fillets since the curvature is continous. I'm going to say it can best be approximated by a superellipse with n = 2.5:
              http://upload.wikimedia.org/math/1/7/1/171490937fc13b93677c00b8c80ffb76.png
              Superellipse - Wikipedia
              (en.wikipedia.org)
              For modeling purposes though it is probably easiest just to model it as a rectangle with fillets. As such it can be defined with five dimensions, four linear and one radius.
              design.medeek.com
              • medeekM Offline
                medeek
                D-Style Gutter:
                http://design.medeek.com/resources/images/truss_su300_800.jpg
                design.medeek.com
                • jujuJ Offline
                  juju
                  Looks good, how about a radius field to control the curvature?
                  • medeekM Offline
                    medeek
                    The field with the "R" is the radius, I've uploaded version 2.0.4d so you can test it out. Let me know if there are more appropriate default values to use for the dimensions.
                    I just noticed the units are missing from the screenshot of the D-style gutter, I'll fix that.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Since I'm adding in gutters I should probably add in fascia and soffits, yet another tab in the global settings.
                      design.medeek.com
                        dpaul
                        Gutters, downspouts, and other pieces of your trusses/roof plugin will be of value to us, of course.
                        But since you are now widening the use and scope of the plugin to roofs and entablatures themselves, can I suggest a close look at GET YOUR HOUSE RIGHT--architectural elements to use & avoid-- by MARIANNE CUSATO?
                        I believe studying the parameters she highlights as historically correct can only be of real help to how you precisely lay out new plugin parameters (for example, how the half-round gutter fits on the entablature, or how 'poor man's greek return' could be done easily and accurately. And so on....).
                        All best.
                        • medeekM Offline
                          medeek
                          All best.
                          Bought it and a couple others for good measure. I'm still working on the straight skeleton but I'm also wanting to add in some of the finishing touches to a roof so that the plugin can actually be utilized by architects and designers.
                          The roof, and the entire structure for that matter, is similar to the human body. The trusses and framing is only the skeleton. We need all of the other components to make the assembly whole.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Preview of the E-Style or "Box Gutter":
                            http://design.medeek.com/resources/images/truss_su301_800.jpg
                            Note that I've also added the downspout options and parameters. The units don't show in this screen shot but they will within the plugin.
                            This type of gutter is probably more common in commercial applications.
                            design.medeek.com
                            • jujuJ Offline
                              juju
                              Attached ZIP file with some PDF's and DWG's of frequently used system, at least in South Africa. The files may be relatively old, but they are still current.
                              I think the profiles relate closely to some of the various style variants you refer to.
                              Watertite.zip
                              • medeekM Offline
                                medeek
                                Version 2.0.5 - 11.05.2017
                                • Added gutters and downspouts for rafter and truss hip roofs.
                                • Gutter menu added to the global settings.
                                • Custom roof layer added for gutters in the layer menu within the global settings.
                                http://design.medeek.com/resources/images/truss_su302_800.jpg
                                http://design.medeek.com/resources/images/truss_su303_800.jpg
                                I still need to add gutters and downspouts to the gable roofs (truss and rafter).
                                Four gutter types with two different downspout types.
                                This is a new feature so please send me your feedback and I will try to address all of the issues.
                                The gutter shown is a 6" half round with a 2.75" round downspout. The gutter and downspouts are separate solids so that one can easily adjust the placement of the downspouts after the fact.
                                The downspout angle is 15 degrees, with a 3" drop out of the gutter and a downspout center line radius of 3".
                                View model here:
                                3D Warehouse
                                (3dwarehouse.sketchup.com)
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  http://design.medeek.com/resources/images/truss_su304_800.jpg
                                  K-Style gutter with "2x3" downspouts.
                                  I may need to add a few more user configurable variables:
                                  • offset from bldg. corner (currently I have it offset 0" from the framing)
                                  • offset from framed wall (currently I have it offset 1" from the framing)
                                  • downspout radius (currently set at 3" @ CL)
                                  • downspout drop (currently set at 3" before the first bend)
                                  Right now these values are all hard coded into the plugin.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 2.0.5b - 11.06.2017
                                    • Fixed a minor bug with the downspout module, downspout solid is now a uniform extrusion with no unnecessary seams or edges.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 2.0.5c - 11.07.2017
                                      • Fixed a minor bug with the gutter layer for installation upgrades of the plugin.
                                      If you have version 2.0.5b please upgrade to this version or be sure to open up the global settings and click on the layers tab, this will create the default gutter layer setting.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 2.0.6 - 11.10.2017
                                        • Added gutters and downspouts for rafter and truss gable roofs.
                                        • Added gutters and downspouts for dutch gable rafter roofs.
                                        I still need to add gutters to monoslope truss roofs, shed roofs and some other specialized truss roofs. Adding the gutters to the common truss roof became slightly more complicated when I realized I also had to deal with roof returns and their various configurations.
                                        http://design.medeek.com/resources/images/truss_su305_800.jpg
                                        This gable roof has a hip return with fully wrapped gutter, you can also choose to half wrap or no wrap (linear gutter only at eaves, does not wrap around corner).
                                        http://design.medeek.com/resources/images/truss_su306_800.jpg
                                        The dutch gable is really no different than the regular hip roof, when it comes to the gutter and its configuration, but internally it is a completely different set of advanced options.
                                        design.medeek.com
                                        • pbacotP Offline
                                          Very nice looking models!
                                          • medeekM Offline
                                            medeek
                                            Half wrap of a hip roof return:
                                            http://design.medeek.com/resources/images/truss_su307_800.jpg
                                            http://design.medeek.com/resources/images/truss_su308_800.jpg
                                            All of the gutters and downspouts are constructed as solids so that it is easy to manipulate them with Pro's boolean tools or other third party solid tools.
                                            design.medeek.com
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 74
                                            • 75
                                            • 38 / 75
