    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • medeekM
      medeek
      Life is tough, you've got to find a silver lining somewhere.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Gutters:
        http://design.medeek.com/resources/images/truss_su298_800.jpg
        design.medeek.com
        • medeekM
          medeek
          The half round gutter type (U6):
          http://design.medeek.com/resources/images/truss_su299_800.jpg
          These are probably the two most common gutter profiles but there are others that I can add if requested:
          • box gutters
          • fascia gutters
          Even though I've listed these at the K5 and U6 gutter types, one can easily modify any of their dimensions to generate any size of these gutter types with the given profile. The reason I've named them with the sizes "5" and "6" is because the default values correspond to these sizes.
          design.medeek.com
          • medeekM
            medeek
            Version 2.0.4c - 10.30.2017
            This sub-release has the gutter menu added to the global settings as well as a new roof layer added for gutters in the layer menu.
            You can't actually create any gutters yet but you can test out the new GUI in the global settings and offer any feedback.
            I am still working out the algorithm for the downspouts. My intent is to use the standard rectangular profile downspout material for the K-Style gutter and a round profile downspout for the U-Style (half round) gutter.
            design.medeek.com
            • jujuJ
              juju
              Please have an option to use round downspouts on the K-style (we call it OGEE) gutter.
              Also, is it possible to create a D-profile gutter? It is much like the half-round, with some extra input fields required in order to get the half-ellipse with straight ends to the top. Maybe an option for a box profile gutter as well?
              • medeekM
                medeek
                Post or send me a sketch of the D-Style and I can add it in. I'll also add the box gutter and the fascia gutter. This will be a total of 5 different gutter types. I can always add more now that I have the template setup
                Your right it doesn't make any sense to limit the downspout type to a particular gutter style. I will setup some additional options/parameters:
                Downspout Type: RECTANGLE/ROUND
                Downspout Length (ft./m): This length will be measured from the top plate of the wall that the truss or rafter roof rests on.
                For Rectangular Downspouts, the following two parameters:
                Depth: (default value 2.25" or metric value?)
                Width: (default value 3.125" or metric value?)
                For Round Downspouts, the following one parameter:
                Dia.: (default value 3.0" or metric value?)
                design.medeek.com
                • medeekM
                  medeek
                  The gutter extension is how much the gutter extends past the rake board on a gable roof, this does not apply to a hip roof or dutch hip roof.
                  http://superiorgutters.net/wp-content/uploads/drip-edge-ext.jpg
                  The vertical offset is the distance the gutter drops down from the top edge of the fascia board, the default is zero.
                  With a metric template the dimensions are given in mm or metres with the grid shown in cm. In US units dimensions are in inches or feet with the grid shown in inches.
                  design.medeek.com
                  • medeekM
                    medeek
                    SketchUp Essentials has put together a nice overview of the plugin.
                    I've been talking to Justin and I may have him put together some tutorials for me. My videos are quite bland compared to his presentation.
                    design.medeek.com
                    • jujuJ
                      juju
                      trade information on this one seems to be terrible. See attached PDF, page 11/12 has a diagram of sorts...
                      DPI Plastics plumbing & drainage fittings Aug 2011 - low resolution.pdf
                      • medeekM
                        medeek
                        The D-style profile is very interesting mathematically. Its not quite an ellipse but it really has no flats so it is actually more than a rectangle with fillets since the curvature is continous. I'm going to say it can best be approximated by a superellipse with n = 2.5:
                        http://upload.wikimedia.org/math/1/7/1/171490937fc13b93677c00b8c80ffb76.png
                        Superellipse - Wikipedia
                        (en.wikipedia.org)
                        For modeling purposes though it is probably easiest just to model it as a rectangle with fillets. As such it can be defined with five dimensions, four linear and one radius.
                        design.medeek.com
                        • medeekM
                          medeek
                          D-Style Gutter:
                          http://design.medeek.com/resources/images/truss_su300_800.jpg
                          design.medeek.com
                          • jujuJ
                            juju
                            Looks good, how about a radius field to control the curvature?
                            • medeekM
                              medeek
                              The field with the "R" is the radius, I've uploaded version 2.0.4d so you can test it out. Let me know if there are more appropriate default values to use for the dimensions.
                              I just noticed the units are missing from the screenshot of the D-style gutter, I'll fix that.
                              design.medeek.com
                              • medeekM
                                medeek
                                Since I'm adding in gutters I should probably add in fascia and soffits, yet another tab in the global settings.
                                design.medeek.com
                                  dpaul
                                  Gutters, downspouts, and other pieces of your trusses/roof plugin will be of value to us, of course.
                                  But since you are now widening the use and scope of the plugin to roofs and entablatures themselves, can I suggest a close look at GET YOUR HOUSE RIGHT--architectural elements to use & avoid-- by MARIANNE CUSATO?
                                  I believe studying the parameters she highlights as historically correct can only be of real help to how you precisely lay out new plugin parameters (for example, how the half-round gutter fits on the entablature, or how 'poor man's greek return' could be done easily and accurately. And so on....).
                                  All best.
                                  • medeekM
                                    medeek
                                    All best.
                                    Bought it and a couple others for good measure. I'm still working on the straight skeleton but I'm also wanting to add in some of the finishing touches to a roof so that the plugin can actually be utilized by architects and designers.
                                    The roof, and the entire structure for that matter, is similar to the human body. The trusses and framing is only the skeleton. We need all of the other components to make the assembly whole.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Preview of the E-Style or "Box Gutter":
                                      http://design.medeek.com/resources/images/truss_su301_800.jpg
                                      Note that I've also added the downspout options and parameters. The units don't show in this screen shot but they will within the plugin.
                                      This type of gutter is probably more common in commercial applications.
                                      design.medeek.com
                                      • jujuJ
                                        juju
                                        Attached ZIP file with some PDF's and DWG's of frequently used system, at least in South Africa. The files may be relatively old, but they are still current.
                                        I think the profiles relate closely to some of the various style variants you refer to.
                                        Watertite.zip
                                        • medeekM
                                          medeek
                                          Version 2.0.5 - 11.05.2017
                                          • Added gutters and downspouts for rafter and truss hip roofs.
                                          • Gutter menu added to the global settings.
                                          • Custom roof layer added for gutters in the layer menu within the global settings.
                                          http://design.medeek.com/resources/images/truss_su302_800.jpg
                                          http://design.medeek.com/resources/images/truss_su303_800.jpg
                                          I still need to add gutters and downspouts to the gable roofs (truss and rafter).
                                          Four gutter types with two different downspout types.
                                          This is a new feature so please send me your feedback and I will try to address all of the issues.
                                          The gutter shown is a 6" half round with a 2.75" round downspout. The gutter and downspouts are separate solids so that one can easily adjust the placement of the downspouts after the fact.
                                          The downspout angle is 15 degrees, with a 3" drop out of the gutter and a downspout center line radius of 3".
                                          View model here:
                                          3D Warehouse
                                          (3dwarehouse.sketchup.com)
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            http://design.medeek.com/resources/images/truss_su304_800.jpg
                                            K-Style gutter with "2x3" downspouts.
                                            I may need to add a few more user configurable variables:
                                            • offset from bldg. corner (currently I have it offset 0" from the framing)
                                            • offset from framed wall (currently I have it offset 1" from the framing)
                                            • downspout radius (currently set at 3" @ CL)
                                            • downspout drop (currently set at 3" before the first bend)
                                            Right now these values are all hard coded into the plugin.
                                            design.medeek.com
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 76
                                            • 77
                                            • 47 / 77
