    Black shapes
    renderpluginsextensions
    9 Posts 4 Posters 1.6k Views 4 Watching
      michielelsen
      is there anybody that knows why these black shapes apear when i render ?
      it only shows up when im rendering in 'rendering image.
      • BoxB Offline
        One of the most common reasons for black faces is reversed faces.
        Sketchup has front and back faces and many render engines ignore back faces.
        Look at your model in monochrome mode and if you are seeing anything but white then you need to orient your faces correctly.
          michielelsen
          if i set my model in monochrome, all my faces are white and the inside isof each volume is 'light grey'.
            Mudo
            I had a similar problem, with me the cause was the glass, I deleted all the glasses on the scene and built with again, the problem stoped.
            I don´t know why it happend, try rendering without your glass on the scene to see if it's causing it.
            https://sketchucation.com/forums/viewtopic.php?f=322&t=68080
            Sorry for the bad english.
              michielelsen
              if i hide the glass materials it does not show up, everytime i rebuild the glass materials it shows up again.
              • H Offline
                hvanessen
                Did you Paint Both sides off the glass panels, otherwise you look at the Innerside off the back.
                  michielelsen
                  both sides have the glass texture
                  • BoxB Offline
                    You might get more answers on a vray forum.
                      michielelsen
                      i posted this on the vray section but thanks for the info, if i find the answer to this problem i wil post it here.
