Bezier Surface plugin / control points
Hello people, I have question about the Bezier Surface's plugin by ThomThom, I saw in a tutorial that it is possible to manipulate edges, faces with many control points on a mesh, but I only see red points on each corner of my mesh.
Can someone help me with this?
Thanks -
Hi Alan,
You probably saw his other plugin in use: Vertex Tools -
@filibis said:
Hi Alan,
You probably saw his other plugin in use: Vertex ToolsThanks Mr. Filibis
Yep I made a mistake by searching for another plugingI was looking for this
If someone is searching for the same plugin, I found it here: https://sketchucation.com/forums/viewtopic.php?t=5475
