    [Plugin] TIG-weld
    36 Posts 15 Posters 49.1k Views 15 Watching
      Grice
      I take it all back... despite Trimble's plugin warehouse listing this plugin as not compatible with SU2016, I installed it anyway and it is working fine...
      Looks like Trimble need to up their game in terms of keeping their customers satisfied. Isn't that what we pay our yearly subscription fees for?
        Here's v2.0 http://sketchucation.com/pluginstore?pln=TIG-weld
        It's made into an extension and is also signed, so it's fully compatible with all of v2016's 'Loading Policies'.
        Note:
        Because it needed a name change when becoming a compatible extension, note that if you have a old shortcut key set you to 'Tools/Weld' you need to reset it to it's new persona = 'Tools/TIG-weld'...
        • E Offline
          ericbartha
          Hi - new to sketch up and SketchuNation. Trying to install your Weld extension, but I am getting an "Outdated Signature" error. Even in unrestricted mode it will not load, and my Google search did not help much. Any thoughts?
            I should load in Unrestricted mode.
            It installed and runs just fine for me too [PC v2017]
            It's one of the one's that's not yet been re-signed for full v2017 compatibility.
            Thanks for the reminder.
            I'll get it re-signed and posted in the PluginStore...
            Watch for an update today...
              Here's v3.0 http://sketchucation.com/pluginstore?pln=TIG-weld It be re-signed for full v2017 compatibility in all loading-policies.
                rastamannichk
                It doesnt work in SK 2k15.
                How do I install this .rb file?
                I try to use the simple plugin installer but wont work and does appear in tool or extension the weld
                  Use the Dowmload link button, that's just two posts ago - this goes to its entry in the SketchUcation PluginStore.
                  Then Download its latest RBZ file from there.
                  It should work in v2015...
                  Use Preferences > Extensions > Install Extension... button
                  [Note that in v2017 this has changed to Window > Extension Manager... etc]
                  Find the downloaded RBZ and install it.
                  When it's installed 'TIG-weld' is an extension.
                  Check that it is activated in the Extensions dialog...
                  When installed and activated it has a menu item under:
                  Tools > TIG-weld
                  There is no Toolbar or context-menu entry for this tool.
                  You refer to a .rb file - if you mean the customized example RB attached to an earlier post please ignore that and get the last v3.0 RBZ from the link...
                  You should always get the latest RBZ from the PluginStore...
                    laughcry
                    Usefull and smart
                      laughcry
                      just tell me where i can download this usefull thing?
                      • jujuJ Offline
                        juju
                        just go to the pluginstore, search for weld, select the approriate option, download
                          JKsys
                          Does weld work in 8 make?
                            It should work in all current SketchUp versions [pro/free], including those which are no longer supported like v8.
                            Remember that v2017 Make is available if your OS can run it ?
                            That is the last free desktop version available for personal non-commercial use.
                            With v2018 its 'free' version is web-based, and currently does not support plugins/extensions...
                            • JClementsJ Offline
                              JClements
                              Hi TIG:
                              Would there be a chance of upgrading TIG-Weld?
                              1- When welding, if there are two of more adjacent segments that are colinear/coplanar then have them changed into a single, straight segment. This would help in: the general cleanup of unnecessary geometry, lowering file size, and eliminating undesired snapping points.
                              I suppose there should be user-defined setting available for this option that would continue to be active unless the user decides later on to turn the option off.
                              2- Could it also appear in the Selection Context menu?
                              Thanks for your consideration,
                              John
                                Look at Fredo's toolset 'FredoTools' https://sketchucation.com/pluginstore?pln=FredoTools
                                • RemoveLonelyVertices https://sketchucation.com/forums/viewtopic.php?p=332047#p332047
                                  His tool already makes such edges into one edge...
                                  [Don't forget to install LibFredo too]
                                  JClements
                                  Thank you.
                                  • 2 / 2
