    3D Truss Models
    1.5k Posts 31 Posters 937.0k Views 30 Watching
    • pbacotP Offline
      @medeek said:
      @dpaul
      Framing the floor joists flush with the sill plate seems to be particularly popular in Oregon, I've never seen this done before until I did some structural jobs in that area.
      I've seen a number of configurations and details. Some actually use pockets in the stemwall, others use the ledger method as shown in the images above. I've also seen where the ledger is below the joists which then directly bear on the ledger. I will see what I can do in this regard.
      Popular in California too. Good connection of floor diaphram to foundation. Used where the grade outside may be higher than the crawl space, or a waterproof terrace is adjacent (in which case the curb may also be raised and the sheathing is NOT over the mudsill). The disadvantage is in running power and plumbing up through the wall.
      • medeekM Offline
        medeek
        Two issues with this system:
        1. As noted above getting the utilities into the wall from the crawlspace presents a challenge, especially plumbing.
        2. Insulating for cold weather environments is also difficult. Where the corner of the interior space is almost in direct contact with the stemwall creates a thermal bridge.
        The major advantage of this system is less sheathing needed for exterior walls since you don't have to add in the height of the rim joist.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM Offline
          medeek
          I've been thinking about multi-level roofs and how to deal with them.
          http://design.medeek.com/resources/images/truss_su267_800.jpg
          Currently I don't see a good way to automate truss roofs, I think there will be some manual intervention required.
          For rafter roofs though I think I can fully automate the process.
          View model here:
          3D Warehouse
          (3dwarehouse.sketchup.com)
          design.medeek.com
          • medeekM Offline
            medeek
            As I previously mentioned I am slowing working on making all previous version of the plugin available here:
            Medeek Design Inc. - Medeek Truss Plugin Versions
            (design.medeek.com)
            Each new version adds improvements and fixes. Probably at some point once this plugin has fully matured then I might see a good reason to install a previous version, but hopefully I never get to that point where the plugin becomes bloatware.
            I suppose the only reason to install a previous version is if you have an expired license and do not wish to upgrade, I can respect that, especially if you only use the plugin on a infrequent basis.
            design.medeek.com
            • medeekM Offline
              medeek
              Starting to work on the straight skeleton algorithm today, complex roofs have got my attention.
              The model below has a saddle point and this lends itself to some rather complex framing:
              http://design.medeek.com/resources/images/truss_su268_800.jpg
              Even with the roof primitives and trim tool, which helped out tremendously, it still took me almost an hour to fully generate the roof framing.
              http://design.medeek.com/resources/images/truss_su269_800.jpg
              The goal is to turn hours into seconds.
              http://design.medeek.com/resources/images/truss_su270_800.jpg
              View model here:
              3D Warehouse
              design.medeek.com
              • medeekM Offline
                medeek
                If you really want a headache try and truss out this same roof outline:
                3D Warehouse
                After about 45 minutes I've given up, not because it can't be done but because the amount of custom truss profiles and manual editing required far exceeds my patience and determination.
                On a different note it looks like the extension warehouse is down so I am unable to sign any new revisions to the extensions, I guess 1.9.9b will have to wait.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Needing a break from the rigors of the straight skeleton code I realized that I have still not implemented the octagon hip roof yet. On a related note the circular roof could also use my attention:
                  http://design.medeek.com/resources/images/truss_su271_800.jpg
                  View model here:
                  3D Warehouse
                  The number of rafters can be given by this equation N = 8 + 8n where n = 0,1,2,3,4 etc...
                  In this model n = 3
                  People do actually build these things:
                  http://www.quittintime.com/attachments/3705-Dscn4931.jpg
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    A turret roof:
                    http://design.medeek.com/resources/images/truss_su272_800.jpg
                    View model here:
                    3D Warehouse
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Winter is coming...
                      http://design.medeek.com/resources/images/truss_su273_800.jpg
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        View model here:
                        3D Warehouse
                        Using the hip rafter roof as a template it won't be too hard to add the octagon and circular roof, two more checkboxes to fill. I do admit that sometimes I like the low hanging fruit, but it is really the challenging stuff that piques my interest and drives me.
                        I've had a bit of a cold all night, tempted to call in sick and spend the rest of the day coding but my wife would probably kill me if I did.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Working on adding in the inset floor joists per the details given by dpaul:
                          Parameters are the following:
                          1.) Stemwall Thickness (inset amount)
                          2.) Ledger Option: Yes or No
                          3.) Ledger Height
                          4.) Ledger Width
                          5.) Hanger Option: Yes or No
                          I'm still waffling on what to do if the hanger option is "yes". I was considering having the option of selecting one of the many Simpson-Strongtie hangers from a long list of hangers. However, no models exist for the bulk of these hangers and I don't have the time or data to try and model a bunch of them. Item 5 may not be feasible.
                          I also have a question on the ledger board option:
                          http://design.medeek.com/resources/images/truss_su274_800.jpg
                          As you can see in the image the 2x12 PT dimensional lumber ledger is smaller in height (11.25") than the 11-7/8" TJI. In this case would the ledger be run flush to the bottom of the TJI or is this not a concern? I was thinking that one would probably call out an LVL or LSL ledger with felt backing between the ledger and the concrete so that the ledger matches the height of the I-joist. Additional information when the floor joists are I-joists or EWP would be helpful here.
                          View model here:
                          3D Warehouse
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Someone suggested that I try out Patreon rather than Kickstarter:
                            Redirecting...
                            (www.patreon.com)
                            design.medeek.com
                            • facerF Offline
                              facer
                              Medeek,
                              Interesting approach of having pledges towards a monthly salary that you have set to allow you to
                              develop your plugins full time.
                              One question I have is how long do the "Patrons - pledges" last?
                              Is it set by a time limit or a predetermined stage in your plugin development?
                              Following with interest, best of luck!
                              Regards,
                              Ray
                              • medeekM Offline
                                medeek
                                @facer said:
                                Medeek,
                                Regards,
                                Ray
                                I haven't read through all of the details on Patreon's website but there does not appear to be any time limit on the pledges, each patron can stop their patronage at any time.
                                Realistically, I am thinking a couple of years should be enough time to advance the development to the stage where the momentum and plugins will carry themselves.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 2.0.0b - 10.01.2017
                                  • Enabled roof cladding for shed and shed w/ ledger rafter roofs.
                                  http://design.medeek.com/resources/images/truss_su276_800.jpg
                                  View model here:
                                  3D Warehouse
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 2.0.0 - 09.30.2017
                                    • Added a hip & ridge option for dutch gable rafter roofs.
                                    http://design.medeek.com/resources/images/truss_su275_800.jpg
                                    View model here:
                                    3D Warehouse
                                    Not exactly how I should terminate the hip cap where it meets the gable section of the roof. What I have now seems reasonable enough for presentation and estimating purposes.
                                    Quite a bit of convoluted code to get those sections of hip cap just right, where there is a will there is a way.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 2.0.1 - 10.04.2017
                                      • Added (FULL) roof return option within the advanced options menu for common, scissor and vaulted trusses.
                                      http://design.medeek.com/resources/images/truss_su277_800.jpg
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        I'm not entirely sure how one frames up a full "greek" return or cornice. When you strip away the sheathing and cladding you can see that my rafters don't line up well with anything:
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          I'm considering selling my plugins and code, I won't divulge the potential buyer(s) but I have really no idea how much it is worth, I suppose that is purely subjective. If you have a suggestion please feel free to message me.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 2.0.1b - 10.06.2017
                                            • Added ceiling joist option for Hip Rafter Roofs.
                                            http://design.medeek.com/resources/images/truss_su278_800.jpg
                                            design.medeek.com
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 75
                                            • 76
                                            • 44 / 76
