    3D Truss Models
    1.5k Posts 31 Posters 978.8k Views 30 Watching
      dpaul
      Hello Nathaniel
      I appreciate being able to provide you feedback as per your invitation to do so. It also helps me think through what I could most use for my house modelling.
      With regards to Item #2, please send me some details on your floor assembly that sits within the foundation. I need to understand how this construction comes together and works.
      Please see the attached sketches from Rob Thallon's book GRAPHIC GUIDE TO FRAME CONSTRUCTION (it has been an invaluable reference to me since I bought it quite a few years ago now). The sections he drew show clearly what I have referred to as 'floor assembly within the foundation walls'.
      I kind of came into the plugin world with an engineering mindset but have slowly evolved into a design tool developer as the client base has pushed me progressively in that direction. In an effort to make the plugins more useful I have tried to keep the big picture in mind but sometimes I get sidetracked and fall back into my engineering ways.
      Never a problem. I value the context of your coding journey.
      Ultimately, I have plans to develop a plugin specifically for residential structural engineers, and it will be a game changer for engineers like myself, especially if I can fully automate the load takedown, analysis and report generation.
      I did not know this, but I fully agree: it will be a game-changer, not only for engineers but for firming up the communication and synchronicity of drawings with SU as the platform for both engineers and designers. Your direction here is a very good thing, I am convinced.
      I enjoy making fairly realistic models (I'm not into cartons). Hence, the truss plugin has been enabled with details such as plates, rakeboards, sub-fascia, gypsum, ridge cap etc... I have been considering adding in some more advanced options such as soffit, fascia, barge board and soffit boxes to better finish off the roof.
      We want all of these 'menu items'. They fully support and speed up detailed modelling.
      Speeding up the design process is really what it is all about, I get that. If the designer can create an entire roof in a matter of seconds versus spending hours manually drawing all of the various elements this is certainly worth something. However, the plugin needs to be able to take care of all the details without bogging down the designer, if the details are to be included. The truss plugin currently can successfully do this for a simple rectangular roof or floor outline (hip or gable) but as soon as you get into anything more complicated it again becomes a manual process and the details become more a hinderance than a help
      Now, this can be an ongoing--and compelling---conversation with us, your user base, as you sort out how to go about coding for modelling complexity. This is an attractive problem to solve, I can only imagine.
      With the foundation plugin I have attempted to address the non-rectangular footprint with some success. However, the final step is to provide a preview screen which will allow one to accurately place and preview potentially multiple internal bearing points/footings.
      Very cool indeed......πŸ˜„
      A tip o' the hat.
      • medeekM Offline
        medeek
        Version 1.9.9 - 09.12.2017
        • Added a hip & ridge option for gable rafter roofs.
        • Fixed some miscellaneous bugs with rafter roof modules.
        There were some really annoying issues with the rafter roof module that needed to be addressed. I still have more work in this regard since I need to go through all of the other rafter roof modules (glulam beam, dual glulam beam etc...) and clean a few things up but I made a fairly good dint in it this evening.
        At some point I would like to also add roof returns to the gable rafter roofs, this should not be too big of an issue. Another thing to add to the todo list is partial roofs where a rafter roof butts up against a larger wall and/or roof.
        The list never ends, but then I never quit, I'll probably still be working on this thing 20 years from now when I'm 65.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • jujuJ Offline
          juju
          Thanks for putting in the effort!
          • medeekM Offline
            medeek
            @dpaul
            Framing the floor joists flush with the sill plate seems to be particularly popular in Oregon, I've never seen this done before until I did some structural jobs in that area.
            I've seen a number of configurations and details. Some actually use pockets in the stemwall, others use the ledger method as shown in the images above. I've also seen where the ledger is below the joists which then directly bear on the ledger. I will see what I can do in this regard.
            design.medeek.com
            • pbacotP Offline
              @medeek said:
              @dpaul
              Popular in California too. Good connection of floor diaphram to foundation. Used where the grade outside may be higher than the crawl space, or a waterproof terrace is adjacent (in which case the curb may also be raised and the sheathing is NOT over the mudsill). The disadvantage is in running power and plumbing up through the wall.
              • medeekM Offline
                medeek
                Two issues with this system:
                1. As noted above getting the utilities into the wall from the crawlspace presents a challenge, especially plumbing.
                2. Insulating for cold weather environments is also difficult. Where the corner of the interior space is almost in direct contact with the stemwall creates a thermal bridge.
                The major advantage of this system is less sheathing needed for exterior walls since you don't have to add in the height of the rim joist.
                design.medeek.com
                • medeekM Offline
                  medeek
                  I've been thinking about multi-level roofs and how to deal with them.
                  http://design.medeek.com/resources/images/truss_su267_800.jpg
                  Currently I don't see a good way to automate truss roofs, I think there will be some manual intervention required.
                  For rafter roofs though I think I can fully automate the process.
                  View model here:
                  3D Warehouse
                  (3dwarehouse.sketchup.com)
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    As I previously mentioned I am slowing working on making all previous version of the plugin available here:
                    Medeek Design Inc. - Medeek Truss Plugin Versions
                    (design.medeek.com)
                    Each new version adds improvements and fixes. Probably at some point once this plugin has fully matured then I might see a good reason to install a previous version, but hopefully I never get to that point where the plugin becomes bloatware.
                    I suppose the only reason to install a previous version is if you have an expired license and do not wish to upgrade, I can respect that, especially if you only use the plugin on a infrequent basis.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Starting to work on the straight skeleton algorithm today, complex roofs have got my attention.
                      The model below has a saddle point and this lends itself to some rather complex framing:
                      http://design.medeek.com/resources/images/truss_su268_800.jpg
                      Even with the roof primitives and trim tool, which helped out tremendously, it still took me almost an hour to fully generate the roof framing.
                      http://design.medeek.com/resources/images/truss_su269_800.jpg
                      The goal is to turn hours into seconds.
                      http://design.medeek.com/resources/images/truss_su270_800.jpg
                      View model here:
                      3D Warehouse
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        If you really want a headache try and truss out this same roof outline:
                        3D Warehouse
                        After about 45 minutes I've given up, not because it can't be done but because the amount of custom truss profiles and manual editing required far exceeds my patience and determination.
                        On a different note it looks like the extension warehouse is down so I am unable to sign any new revisions to the extensions, I guess 1.9.9b will have to wait.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Needing a break from the rigors of the straight skeleton code I realized that I have still not implemented the octagon hip roof yet. On a related note the circular roof could also use my attention:
                          http://design.medeek.com/resources/images/truss_su271_800.jpg
                          View model here:
                          3D Warehouse
                          The number of rafters can be given by this equation N = 8 + 8n where n = 0,1,2,3,4 etc...
                          In this model n = 3
                          People do actually build these things:
                          http://www.quittintime.com/attachments/3705-Dscn4931.jpg
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            A turret roof:
                            http://design.medeek.com/resources/images/truss_su272_800.jpg
                            View model here:
                            3D Warehouse
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Winter is coming...
                              http://design.medeek.com/resources/images/truss_su273_800.jpg
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                View model here:
                                3D Warehouse
                                Using the hip rafter roof as a template it won't be too hard to add the octagon and circular roof, two more checkboxes to fill. I do admit that sometimes I like the low hanging fruit, but it is really the challenging stuff that piques my interest and drives me.
                                I've had a bit of a cold all night, tempted to call in sick and spend the rest of the day coding but my wife would probably kill me if I did.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Working on adding in the inset floor joists per the details given by dpaul:
                                  Parameters are the following:
                                  1.) Stemwall Thickness (inset amount)
                                  2.) Ledger Option: Yes or No
                                  3.) Ledger Height
                                  4.) Ledger Width
                                  5.) Hanger Option: Yes or No
                                  I'm still waffling on what to do if the hanger option is "yes". I was considering having the option of selecting one of the many Simpson-Strongtie hangers from a long list of hangers. However, no models exist for the bulk of these hangers and I don't have the time or data to try and model a bunch of them. Item 5 may not be feasible.
                                  I also have a question on the ledger board option:
                                  http://design.medeek.com/resources/images/truss_su274_800.jpg
                                  As you can see in the image the 2x12 PT dimensional lumber ledger is smaller in height (11.25") than the 11-7/8" TJI. In this case would the ledger be run flush to the bottom of the TJI or is this not a concern? I was thinking that one would probably call out an LVL or LSL ledger with felt backing between the ledger and the concrete so that the ledger matches the height of the I-joist. Additional information when the floor joists are I-joists or EWP would be helpful here.
                                  View model here:
                                  3D Warehouse
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Someone suggested that I try out Patreon rather than Kickstarter:
                                    Redirecting...
                                    (www.patreon.com)
                                    design.medeek.com
                                    • facerF Offline
                                      facer
                                      Medeek,
                                      Interesting approach of having pledges towards a monthly salary that you have set to allow you to
                                      develop your plugins full time.
                                      One question I have is how long do the "Patrons - pledges" last?
                                      Is it set by a time limit or a predetermined stage in your plugin development?
                                      Following with interest, best of luck!
                                      Regards,
                                      Ray
                                      • medeekM Offline
                                        medeek
                                        @facer said:
                                        Medeek,
                                        Regards,
                                        Ray
                                        I haven't read through all of the details on Patreon's website but there does not appear to be any time limit on the pledges, each patron can stop their patronage at any time.
                                        Realistically, I am thinking a couple of years should be enough time to advance the development to the stage where the momentum and plugins will carry themselves.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 2.0.0b - 10.01.2017
                                          • Enabled roof cladding for shed and shed w/ ledger rafter roofs.
                                          http://design.medeek.com/resources/images/truss_su276_800.jpg
                                          View model here:
                                          3D Warehouse
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 2.0.0 - 09.30.2017
                                            • Added a hip & ridge option for dutch gable rafter roofs.
                                            http://design.medeek.com/resources/images/truss_su275_800.jpg
                                            View model here:
                                            3D Warehouse
                                            Not exactly how I should terminate the hip cap where it meets the gable section of the roof. What I have now seems reasonable enough for presentation and estimating purposes.
                                            Quite a bit of convoluted code to get those sections of hip cap just right, where there is a will there is a way.
                                            design.medeek.com
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 75
                                            • 76
                                            • 42 / 76
