    Soap skin not working
    4 Posts 2 Posters 1.2k Views 2 Watching
    • G
      goranmax
      Hello
      Hope someone can help me.
      please have a look....my Soap Skin is not working correctly.
      Am I doing something wrong with my shapes?
      here some pix.
      thank you all for the help
        I expect you'd find it works much better if you use smoother curves, avoid the sharp points and use a higher number for generating the surface.
        I was just playing around and got this. It still needs a bit of fine tuning.
        • G
          goranmax
          Hello Dave
          Thank you for the Help.
          I understand what you mean.
          I use illustrator to draw the shapes and export to Sketchup.
          do you know a plugin that generates line shapes to bezier curves?....they work better
          or to generate smoother curves?
          regards
          Goran
            @goranmax said:
            do you know a plugin that generates line shapes to bezier curves?....they work better or to generate smoother curves?
            They do work better. I used the Bezier tool from Fredo's Bezier Spline which is available here in the Sketchucation Extension Store.
