ℹ️ GoFundMe | Our friend Gus Robatto needs some help in a challenging time Learn More
Geom::Transformation
5 Posts 2 Posters 1.4k Views
    anteolic
    I am totaly beginner in Sketchup scripting.
    This code move object to some position,
    trans = Geom::Transformation.new(bb.center.vector_to([100,0,0])) ; # move the temp bounding box
    How is posible to move object just by zaxis and other axis dont affect.
      Your example uses a point [100,0,0] to move the object 100 inches along the X_AXIS.
      To move it in the Z_AXIS just try [0,0,100]
      Also it'll be best to do a simple 'translate' rather than '[re]locate' it ?
      trans = Geom::Transformation.translation([0, 0, 100])
      A three element array can be substituted for a point or a vector.
      If you want units other than inches do it like this 100.mm
        anteolic
        I have some object with his location, and select it and i want just to move this object to zaxis=0, and leave other axis unchanged.
          Slightly different question.
          If you want to move its center onto the ground-plane [z=0], consider this...
          ### ... bb = some_object.bounds ct = bb.center pt = ct.clone pt.z = 0 ve = ct.vector_to(pt) tr = Geom::Transformation.translation(ve) some_object.transform!(tr)
            anteolic
