    3D Truss Models
    1.5k Posts 31 Posters 977.1k Views 30 Watching
    • facerF Offline
      facer
      View Medeek's Model in Sketchfab:
      Note option to view in Virtual Reality (VR)
      Refer to Sketchfab instructions
      MEDEEK_OFFICE_HIP3 - Download Free 3D model by facer0001
      MEDEEK OFFICE Shows example of the use of Medeek Sketchup plugins. Meedek foundation plugin for Sketchup http://design.medeek.com/resources/medeekfoundationplugin.html Medeek Truss plugin for Sketchup http://design.medeek.com/resources/medeektrussplugin.html - MEDEEK_OFFICE_HIP3 - Download Free 3D model by facer0001
      Sketchfab (sketchfab.com)
      • medeekM Offline
        medeek
        The hip and ridge is now fully implemented for hip roofs as shown.
        http://design.medeek.com/resources/images/truss_su255_800.jpg
        It can also handle pyramid roofs where there is no ridge cap.
        In the global settings I will setup and option to enable this feature and also an option to set the (ridge/hip) cap width and thickness.
        Its too late tonight but I will see what I can do tomorrow about rolling out a new version.
        View model here:
        3D Warehouse
        (3dwarehouse.sketchup.com)
        The trigonometry required to calculate the beveled cuts on those hip caps is something else, but it never fails to amaze me how it all works out once the math is right.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • facerF Offline
          facer
          %(#000000)[View Medeek's Model in Kubity:
          Refer to Kubity instructions
          Model LINK:
          https://www.kubity.com/p/v8uRve]
          • facerF Offline
            facer
            Medeek Const Library - Kickstarter Status at: 29 Jul
            https://www.kickstarter.com/projects/128644708/medeek-construction-plugin-library
            • medeekM Offline
              medeek
              Version 1.9.6 - 07.29.2017
              • Added a hip & ridge option for all hip type roofs.
              I will now need to setup hip & ridge for all other roof variants (gable, dutch gable etc...)
              I'm quite pleased with the way this has come out. Within the global settings under the "Sheathing" tab you can adjust the width and thickness of the hip/ridge cap.
              This option definitely adds a finished look to the roof.
              design.medeek.com
              • medeekM Offline
                medeek
                Added a hip & ridge option for all gable truss roofs (sub. rev. 1.9.6b):
                http://design.medeek.com/resources/images/truss_su257_800.jpg
                http://design.medeek.com/resources/images/truss_su256_800.jpg
                View model here:
                3D Warehouse
                design.medeek.com
                • facerF Offline
                  facer
                  Medeek Office - sliced open to show structure
                  using Zorro2 plugin
                  Sketchfab LINK:
                  https://sketchfab.com/models/7dd005d09e6040e181ac2319b6dc4cfa
                  • facerF Offline
                    facer
                    Medeek Office - Rendering in Thea for Sketchup
                    • medeekM Offline
                      medeek
                      This afternoon I began to put together the HTML for the timber truss GUI (what I have so far):
                      http://design.medeek.com/resources/images/truss_su258_800.jpg
                      I think I've reduced a metal plated (bolts) timber truss down to twenty (20) parameters.
                      Hopefully the preview panel will help simplify the entry of these parameters and give the user instant feedback on what each one does. With these sort of trusses the look and feel of the truss is every bit as important as the structural aspect so a preview is very important.
                      The preview panel will not only show the timbers but also the metal plates and exact position of each bolt.
                      Once the user submits "go", the timber truss module will draw one (1) timber truss with all of the timbers, metal plates, bolts, nuts and washers.
                      In the global options the user will be able to specify the bolt standard and the washer standard as well as set the material (color) for the plate and hardware.
                      As usual the design and programming is a little more involved than I originally anticipated but in the end it should be quite dramatic to be able to create a fully bolted and plated timber truss.
                      design.medeek.com
                      • pbacotP Offline
                        I like seeing the 2d display! Looks great! What a productive afternoon!
                        • medeekM Offline
                          medeek
                          Visually, not a lot of progress:
                          http://design.medeek.com/resources/images/truss_su259_800.jpg
                          But what you can't see is the algorithm to efficiently position and display the bolts.
                          For larger trusses I'm a little worried that the display is too small to show the bolt details, but I'm not sure what else to do about it.
                          design.medeek.com
                          • jujuJ Offline
                            juju
                            Looking good! Maybe have the view automatically scale down to fit the larger trusses, equipping the window with a zoom tool / widget / whatever is probably asking too much...
                            • medeekM Offline
                              medeek
                              There seems to be some confusion regarding the licensing for the plugins. Just to be clear when you purchase a license it is permanent, it will work forever. There is no need to renew your license for continuous functionality.
                              Renewing your license gives you access to the latest version of the plugin(s) within the Medeek Account Manager. The primary reason to renew your license is so that you can upgrade the plugin(s) to the latest version and take advantage of any new features and bug fixes.
                              I may update the plugin(s) pages to better explain what I have written above.
                              Hopefully this clarifies the Medeek licensing policy. Please feel free to contact me directly with any questions.
                              design.medeek.com
                              • jujuJ Offline
                                juju
                                Thanks for the clarification Nathan, maybe download access to the last version a licence qualifies for is needed? I've only seen upgrade options (when licence has come to expiration date) and no alternate link to last qualifying version.
                                Having said that, upgrades are quite affordable, thank you.
                                • medeekM Offline
                                  medeek
                                  I agree that I should probably have a page with the ability to download any of the previous versions. I have resisted this slightly though since earlier versions did not implement any licensing system and in my mind some of the earlier versions are such crude and flawed attempts that no one in their right mind would want to use them over the current versions.
                                  design.medeek.com
                                    dpaul
                                    It is a pleasure to watch the remarkable development of this plugin (and the others).
                                    A question: might it be possible to control the overhang of the roofing layer only so we can add as much
                                    detailed fascia work as we require (say using PB) to complete the roof details?
                                    Thanks.
                                    • facerF Offline
                                      facer
                                      MEDEEK PLUGINS - PRICING POLICY ($)
                                      Posting by Medeek at:
                                      by medeek ยป Wed Aug 02, 2017 12:30 am
                                      https://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=63133%26amp;p=623551#p623551
                                      Sample Model - view on any web device and in VR using iphone with cardboard viewer or headset
                                      Sketchfab LINK:
                                      https://sketchfab.com/models/7dd005d09e ... 19b6dc4cfa
                                      • medeekM Offline
                                        medeek
                                        @dpaul said:
                                        Might it be possible to control the overhang of the roofing layer only so we can add as much
                                        Thanks.
                                        I have given this some thought previously since I am only really modeling the sub-fascia and not the entire fascia treatment. By the way what does PB stand for?
                                        Should both the roof cladding and sheathing layer have this ability for an additional overhang or just the rood cladding? I am thinking about adding this setting into the global settings where you set this additional offset for the roofing/sheathing.
                                        http://design.medeek.com/resources/images/truss_su205_800.jpg
                                        design.medeek.com
                                        • jujuJ Offline
                                          juju
                                          PB = Profile Builder
                                          Profile Builder 2 out now, much improved from original Profile Builder.
                                            dpaul
                                            I think just the roof cladding. Our trim can go up under the cladding and hide the
                                            roof sheathing and sub-fascia.
                                            Thanks.
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 75
                                            • 76
                                            • 45 / 76
