    3D Truss Models
    1.5k Posts 31 Posters 937.1k Views 30 Watching
    • medeekM Offline
      medeek
      Try it now, there may be some other cross browser issues that I was not aware of. That is the reason for posting this link, it will help expose any issues.
      I use Chrome as my primary browser so I am fairly confident there will be no issue with that browser.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        I've got all of the bolts working now for each plate as well as the extra logic to make sure bolts don't get too close to the scarf line at the heel joint.
        (design.medeek.com)
        Please go ahead and test out the link I've given above.
        If there are no major fixes then I am ready to implement this module into the plugin.
        I still need to come up with the metric version but first I will implement the imperial version fully.
        design.medeek.com
          KrisM
          Nat,
          The link works fine now but there are some other issues.
          Leaving all the settings the same as the link presents - Changing span to 25', the right hand support disappears. Changing the span to 24'or less, the right most plate disappears. Generally speaking, I never see the bolts. Some detective work for you.
          KrisM
          • facerF Offline
            facer
            Medeek Const Library - Kickstarter Status at: 20 Aug
            All or nothing. This project will only be funded if it reaches its goal by Tue, August 29 2017
            Just a moment...
            (www.kickstarter.com)
            • medeekM Offline
              medeek
              @krism said:
              Nat,
              KrisM
              Your right, not out of the woods yet on this one.
              The html preview is working fine in Google Chrome but completely blows up in Firefox and has some issues with the bolts in IE.
              It appears that SketchUp uses IE as the default browser for web dialogs (on Windows) so I've got to address the bolt issue first. I've loaded this up in Safari on my Ipad and it seems to be without any issues, maybe someone on a MAC can verify that.
              design.medeek.com
              • medeekM Offline
                medeek
                In Internet Explorer, parentElement is undefined for SVG elements, whereas parentNode is defined.
                That seems to have fixed the bolt issue within SketchUp. Please test the link with either Chrome, Safari or Internet Explorer, Firefox still has multiple issues.
                Cross browser problems are typical when you start using complex javascript and SVG (which is a relatively new technology compared to other web protocols).
                design.medeek.com
                • medeekM Offline
                  medeek
                  This is would be the typical output of the html input for the timber trusses:
                  http://design.medeek.com/resources/images/truss_su261_800.jpg
                  I may add in the L1 dimension and the heel height dimension.
                  EDIT:
                  No major complaints or concerns with the way I have it currently configured, so far. I've starting creating the ruby code that does the heavy lifting. By the end of the week I should have something ready to go for timber trusses.
                  My goal is to also add in the Queen Post and Howe configuration for timber trusses, these other two seem to be the most commonly used.
                  There is a number of ways one could arrange the bolts on these plates or even configure the plates. I am trying to come up with the mostly widely accepted method that will make at least 75% of the user base happy. Hopefully I can achieve that.
                  At another level I am really happy about this latest edition to the plugin, I now have a better understanding and comfort level with designing bolt connected timber trusses and I can better address local customer requests in this regard.
                  design.medeek.com
                    dpaul
                    There are currently 371 active (unique) users of the truss plugin. Yet the turnout is very low with the Kickstarter Campaign, which leads me to one of two conclusions:
                    1.) Kickstarter does not work well with the SketchUp community.
                    OR
                    2.) The number of "active" users of the plugin is much smaller than the registered user base.
                    Nathaniel,
                    it is #1 as I believe it is very difficult for purchasers of any SKP plugin to come to a user forum as a learning venue only to find that there is a further investment (?) proposal being offered on a plugin we have already purchased. In my opinion--and I say so with great respect----your funding efforts perhaps could have been undertaken elsewhere. There is nothing wrong in trying, of course, but it never felt right to do so on the forums. In truth, we are just purchasers and users of plugins only on this forum, not necessarily equity partners (I have pledged, by the way, and as you know, I have also offered additional funds to you if the goal is not reached).
                    If #2 is the case then it leads one to believe that the real world utility of the plugin is limited at best.
                    Wrong. Happily so. The real world utility of, not only the truss plugin, but the other 2 (foundation and wall plugins) is potentially significant. There are many more users of other big 3D CAD platforms coming to SKP, either for the first time, or for a final time as they, like me, have 'burnt out' on the size and complexity--and rules(!) of these other programs.
                    To have your plugins available to us, in tandem with the workflow importance of other plugins like VALI's and KERNAN's (extraordinary), PROFILE BUILDER, SKALP, and the brilliant host of productivity tools, allow us to produce and compete equally with the 'big boys/girls'.
                    And SKP makes us happy. It will always be the 'little engine that could'. Many more designers of all stripes are taking notice of SKP. Hence the essential requirement for what you are coding.
                    Admittedly the plugin is a bit of novelty
                    Not a novelty. Essential.
                    it can do some cool stuff but does the registered user actually employ it on a daily basis and does it add significant value.
                    Yes, and yes.
                    What is of greatest importance to us, I further believe, is to have a robust WALL TOOL. It must be robust in the sense that CHIEF ARCHITECT's wall tool is robust. It is the best one in the business. One can work in plan, yet the 'Z' is already in place, walls can be cut, sliced, extended, and fused into other walls automatically. It easily takes windows and doors, etc. (please ensure we can place windows & doors inside a wall group). What is needed is a design and editing wall tool. While we very much care about joists and trusses for roofs and floors, wall studding is just not that important (except for take-off calculations---but John Brock's plugin can deal with that). What is crucial is our ability to design, but particularly, to EDIT our layouts, quickly and efficiently.
                    As such, I can only encourage you to bring the wall tool forward for us to purchase and then proceed to integrate the three in one 'construction' package, as you have suggested is coming. Again, the VALI model. His architectural package is far greater than the sum of its parts (I use the win/door tool every day and is essential to my detailed workflow).
                    Your '3 in 1' could have the same effect and in doing so, your user base will increase exponentially.
                    ...back to the issue at hand, I do not know how you fund yourself to get there (a question we all face in our own business'), but please do not give up. Your solutions for SKP are as vital as they are brilliantly coded.
                    As always, you have my very best wishes for the success of your efforts on behalf of us immediate users and the larger SKP community.
                    • TandemT Offline
                      Tandem
                      Well said dpaul.
                      • medeekM Offline
                        medeek
                        The html webdialog is now integrated into the plugin and variables are passing correctly between the two:
                        http://design.medeek.com/resources/images/truss_su262_800.jpg
                        Developing new modules, especially one with some many variables/inputs is a time consuming process.
                        design.medeek.com
                        • facerF Offline
                          facer
                          Medeek,
                          PM sent re what is your Skype address.
                          please reply to my gmail address.
                          Regards,
                          Ray
                          • medeekM Offline
                            medeek
                            I've uploaded a minor update which integrates the timber truss web dialog (won't actually create anything just yet) for those interested in testing it in SketchUp. It will only load up in Imperial/US unit templates for now. My main concern is cross browser issues that I'm not aware of but may pop up for other users who have their PC's configured differently than my own.
                            Let me know if there are any issues.
                            design.medeek.com
                            • facerF Offline
                              facer
                              Medeek Const Library - Kickstarter Status at: 26 Aug
                              • medeekM Offline
                                medeek
                                Version 1.9.7 - 08.26.2017
                                • Added king post timber trusses with bolts and metal plates.
                                http://design.medeek.com/resources/images/truss_su263_800.jpg
                                There may be a few bugs to work out as I haven't had the time to test every possible configuration but it appears to be mostly working now. The metric version is not quite ready so the GUI defaults to the imperial units regardless of the template.
                                View model here:
                                3D Warehouse
                                (3dwarehouse.sketchup.com)
                                I will add in the Queen Post and Howe configurations if requested by users and make any other corrections or adjustments as needed.
                                http://design.medeek.com/resources/images/truss_su264_800.jpg
                                The permutations with this thing is ridiculous. The truss above has larger members with a wider plate width that allows for two rows of bolts.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  We got about 50% the way there which in my mind is pretty good. I don't know that Kickstarter was the right venue for trying to stir up the momentum for a SketchUp plugin but I thought it's at least worth a shot. I sincerely appreciate all who have pledged their hard earned money and supported me in this endeavor. Your faith in me is the reason I keep plugging away at these tools.
                                  I am currently pursuing other funding options. To produce a wall plugin that can do what the other "big boy" softwares can do will take a serious investment of my time and effort. I'm am figuring at least two years of solid programming to produce a polished product that has all the bells and whistles.
                                  How I get there, I'm still trying to figure out. Currently I spend my weekends and a small amount of my time during the regular work week (usually going after the low hanging fruit). Surprisingly I am able to make some headway but progress is too slow in my opinion, somehow I will need to speed up.
                                  Again I would like to thank everyone who participated in this campaign and for all of your pledges, it means a lot to me.
                                  design.medeek.com
                                  • facerF Offline
                                    facer
                                    Medeek Const Library - Kickstarter Status at: 29 Aug
                                    Funding Unsuccessful
                                    • medeekM Offline
                                      medeek
                                      Looking at the code structure of the timber truss module and the html web dialog it doesn't appear to be too difficult to add in the Queen Post and Howe type truss. This addition will make this feature considerably more versatile and useful in my opinion since it should cover 90% of most timber trusses of this type used in residential and commercial construction.
                                      I will make it a point to add in both additional truss types before moving on to something else.
                                      Recently I have not had a lot of feature requests so please fire away.
                                      The next big item on the list is the implementation of the straight skeleton algorithm and the ability to create any rafter roof shape, this is a big one. If I succeed, which I will, this should be tremendously valuable to many of the plugin users.
                                      How to do this sort of thing for truss roofs becomes a bit more difficult since truss roofs are a bit more ambiguous and can be pieced together in a variety of ways. I think it is possible but I will need to give this one more thought.
                                      The next big item which needs to be tackled is the ability to generate floor joists and trusses for any floor outline. I've already given this some serious thought and the path forward is clear to me but it will just take some focused coding time and debugging. Along the same lines, the ability to cut holes in the floor assembly (stairwells, access doors etc...) is also a hot item, I will address this at the same time.
                                      Work on the Wall Plugin has begun in earnest but my free time right now is limited so meaningful progress is slow, especially as I am still devoting the bulk of my time towards the truss plugin.
                                      I have exactly zero feedback on the timber truss module so I am curious if anyone has used it yet and if they are encountering any difficulties or other issues that they would like to see addressed.
                                      • Is this feature useful?
                                      • What would make it more useful?
                                      • Would other timber truss types (timber rivets, etc...) be more useful?
                                      Just because I find it fascinating and would like to add it to the plugin doesn't mean it has any real world utility, I've learned that through experience.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Plates are mostly there now just need to work on the bolts for the Howe Timber Truss:
                                        http://design.medeek.com/resources/images/truss_su265_800.jpg
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Bolts and plates are now complete for the Queen and Howe Timber Truss types:
                                          (design.medeek.com)
                                          Please feel free to test out the web dialog at the link above.
                                          Now all that remains is to bring the javascript code into the ruby.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.9.8 - 09.04.2017
                                            • Added queen post and howe timber trusses with bolts and metal plates.
                                            http://design.medeek.com/resources/images/truss_su266_800.jpg
                                            View model here:
                                            3D Warehouse
                                            Timber trusses haven't seemed to garner much interest or feedback but I do feel like it is a worthwhile contribution to the plugin.
                                            There is more to be done with the engineering side but I will move on to something else unless customer feedback brings me back to it.
                                            The big prize right now is the straight skeleton implementation. I have been mulling this one over for at least a year now.
                                            The truss yard now has 23 different truss types/profiles:
                                            3D Warehouse
                                            design.medeek.com
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 75
                                            • 76
                                            • 42 / 76
