Free 3D scanning
Hi, I am trying to find out about free 3D (android) scanners the results of which could be imported into Sketchup?. Has anyone had any experience with them and would care to advise?
Depends on lots of factors.
MeshLab will help you reduce mesh density if the scan is too heavy for SketchUp.
Scanning has lots of things to consider - lighting, reflections etc. Results are ropey at times.
Best scanners for home/hobby use are Structured Light based. Like these...
http://www8.hp.com/us/en/campaign/3Dscanner/overview.html?jumpid=va_t1345uf8k6
Scanning is time intensive and requires lots of patience.
This article may be worth a quick look...?
Thank you Rich and Sam, I think this may be a solution for myself wanting to make organic wood playground elements. as they are kind of organic and free-form anyway a bit of randomness can be tolerated. And as Rich says poly count needs to be considered. Would still like to ask if anyone has any experience with a free 3D scanner please post with good or bad results it would be very much appreciated.
