    SketchUp Update Broke the Foundation Plugin
    8 Posts 3 Posters 2.1k Views 3 Watching
    • medeekM Offline
      medeek
      I'm not entirely sure what has changed but I just noticed that the "face" tool of the slab-on-grade foundation is throwing an error after I updated SketchUp (SketchUp 2017), everything is working fine in previous versions of SketchUp:
      Error: #<NoMethodError: undefined method volume' for #<Geom::BoundingBox:0x0000000f7b2488>> c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/medeek_foundation_ext/medeek_sog_trim_rebar.rbs:104:in trim_rebar'
      I've indicated the exact line where the error is happening below.
      The code is:
      # Slab on Grade (TRIM REBAR) Methods
      def sog_trim_rebar (slabgroup, rebargroup, profileface, edgedistance)
       # Initialization
       @mod = Sketchup.active_model
       @ent = @mod.active_entities
       # Profile Face
       @face = profileface
       @slab_ents = slabgroup.is_a?(Sketchup;;Group) ? slabgroup.entities ; slabgroup.definition.entities
       @slab_trns = slabgroup.transformation
       @rebar_ents = rebargroup.is_a?(Sketchup;;Group) ? rebargroup.entities ; rebargroup.definition.entities
       @rebar_trns = rebargroup.transformation
       MedeekMethods.face_inset(@face,edgedistance)
       v3 = @face.normal
       v3.length = 24
       @bf = @ent.add_group
       @bfe = @bf.entities
       @bft = @bf.transformation
       last = @o_pts.length - 1
       0.upto(last) do |i|
        @bfe.add_face(MedeekMethods.make_a_face(@o_pts[i],@o_pts[i-last],v3))
       face = @ent.add_face(@o_pts)
       MedeekMethods.trim_rebar(rebargroup,face)
       @bf.erase!; @ent.erase_entities(face.edges);
      def trim_rebar(ci,f)
       plane = f.plane;
       bb=Geom;;BoundingBox.new;
       0.upto(7){|i|bb.add ci.bounds.corner(i)}
       [b]unless bb.intersect(@bf.bounds).volume == 0.0[/b]
        ci.make_unique; cit = ci.transformation;
        cde = ci.is_a?(Sketchup;;Group) ? ci.entities ; ci.definition.entities;
        new = cde.intersect_with(false,cit,cde,cit,false,@bf)
        if new
         # puts "Finding clipped edges"
         rmv = cde.grep(Sketchup;;Edge).select{|e|
      				!new.include?(e) && f.classify_point(e.midpnt.transform(cit).project_to_plane(plane))==16
         # puts "Erasing clipped edges"
         cde.erase_entities(rmv)
         unless ci.manifold?
          # puts "Making manifold"
          new.grep(Sketchup;;Edge).each{|e|e.find_faces if e.valid?}
      def make_a_face(p1,p2,v)
       pts=[];
       pts<<p1.offset(v)
       pts<<p2.offset(v)
       pts<<p2.offset(v.reverse)
       pts<<p1.offset(v.reverse)
       return pts
      def face_inset(face,dist)
       @c_pts=face.outer_loop.vertices.collect{|v|v.position};
       last = @c_pts.length-1;@o_pts = []
       0.upto(last) do |a|
        vec1 = (@c_pts[a]-@c_pts[a-last]).normalize
        vec2 = (@c_pts[a]-@c_pts[a-1]).normalize
        unless vec1.parallel? vec2
         vec3=(vec1+vec2).normalize
         ang = vec1.angle_between(vec2)/2;
         if vec3.valid?
          vec3.length = -dist/Math;;sin(ang);
          vec3.reverse! if face.classify_point(@c_pts[a].offset(vec3))==16
          t = Geom;;Transformation.new(vec3)
          @o_pts << @c_pts[a].transform(@slab_trns*t)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • TIGT Online
        As Dan says, bounds does not have a method .volume !
        Also, don't leave a space between a method and its arguments:
        should be
        def sog_trim_rebar(slabgroup, rebargroup, profileface, edgedistance)
        etc...
        • Dan RathbunD Offline
          Dan Rathbun
          You cannot use bbCode bold tags inside a bbCode code block.
          Try marking errors inside code using comments like:
          erroneous code # <<<<<<<<<<--------------<<<<<<<< ERROR !
          Or, bracketing:
          THIS DOES NOT WORK
          result = some_code()
          a = b + result
          Regarding your NoMethodError error. The BoundingBox class does not have (nor ever did,) an instance method named volume(). So I doubt that it could work as intended on older versions.
          EDIT: However, it is possible you were relying upon a modification to the BoundingBox class made by some extension that you've not loaded in the latest version ? (Generally, you should not rely upon API modifications made by other extensions.)
          You also seem to have ignored the advice in the API docs concerning the BoundingBox#intersect method.
          You'd have to either define a singleton volume() method and attach to that single object:
          module BB_Volume
            def volume()
              height * width * depth
          bb_obj.extend(BB_Volume)
          unless bb_obj.volume == 0.0
            # do code here
          OR .. just use the Geom::BoundingBox#empty? method:
          unless bb_obj.empty?
            # do code here
          I'm not here much anymore.
            Dan Rathbun
            I would also suggest avoiding naming objects "new" as this is the standard name for the class constructor method. This could confuse the Ruby interpreter under some situations, as it must decide whether you are trying to make a method call or creating a local reference of the same name.
            The idea is to train yourself to avoid hard to find errors.
            • medeekM Offline
              medeek
              Dan you are a SketchUp Wizard.
              Sure enough after I did a bit of digging about I found two class modifications that I was relying on that somehow got deleted from my plugins folder:
              class Sketchup::Edge
              def midpnt
              Geom::Point3d.linear_combination(0.5, self.start.position, 0.5, self.end.position)
              class Geom::BoundingBox
              	def volume
              	 vol = self.width*self.height*self.depth
              	 vol = vol<1.0e+30 ? vol : 0.0
              Which basically tells me that the rebar for the slab-on-grade foundation was never working for anyone except me (polygon and face tool)
              design.medeek.com
              • medeekM Offline
                medeek
                I never said I was good at programming in Ruby or dealing with the API, actually I'm very weak in that regard. I know just enough to get me into trouble. I'm surprised that I have gotten as far as I have with these plugins.
                design.medeek.com
                • TIGT Online
                  You should not modify or add to shipped modules/classes - like Sketchup and Geom.
                  It won't get past the EWH audit.
                  It's easy enough to define similar methods inside your own module[s]...
                  def midpt(edge)
                    Geom;;Point3d.linear_combination(0.5, edge.start.position, 0.5, edge.end.position)
                  Used thus, passing it an edge:
                  mpt = midpt(edge)
                  returns a point...
                  and
                  def bbvol(bb)
                    vol = bb.width*bb.height*bb.depth
                    vol = vol < 1.0e+30 ? vol ; 0.0
                  Used thus, passing it a bounding-box:
                  vol = bbvol(bb)
                  returns a float volume...
                    Dan Rathbun
                    Or single object extension via mixin module (as shown above.)
                    unless bb.extend(BB_Volume).volume == 0.0
                      # do code here
                    Or if only supporting Ruby 2.x+ SketchUp versions, you can use class refinements that are only active within your files.
                    See: http://ruby-doc.org/core-2.0.0/doc/syntax/refinements_rdoc.html
