🔌 Quick Selection | Try Didier Bur's reworked classic extension that supercharges selections in SketchUp Download
How Can't the Triangulated Points Work for a Voronoi Buildin
11 Posts 4 Posters 1.0k Views 4 Watching
    JSA_SJ
    I just learned to do the voronoi patterns in sketchup using plugins as Voronoi_XY and point tool, when I was trying to draw some points on my imported JPEG of a building that I wanted to model, I couldn't get it correctly after hitting the 'Triangulated Points' button. Where did I go wrong? Or shouldn't I use Voronoi plugin to model this building at all?
    Thanks in advance.
      sdmitch
      I have some experience using the Voronoi plugin to generate irregular polygons in my FloorGenerator plugin but I don't recall ever seeing a "Triangulated Points" button. As its' name implies, Voronoi_XY is for points on the XY plane only. It requires Delauney3 to do the triangulation.
      http://sdmitch.blogspot.com/
        I'd tackle this with SUbD.
          JSA_SJ
          Many Thanks! That looks cool! I'll give that a try.
            JSA_SJ
            You're quite right! After posting this yesterday, I thought of one step that I hadn't done, which was click on the view 'top' that'll make all points on XY plane. Thanks for your advice.
              JSA_SJ
              May I ask how you'd draw the basic geometry in a fast way?
                Split tools by TIG
                Then Move Scale some edges/ Vertices
                  Here's a quick version using linear arrays.
                  You could manually add the 8 diagonals or use split donut as I have done here.
                  Then it's up to you how you move the geometry about. You can use Move, Rotate and Scale.
                  Personally I would use Quad face tools and Vertex tools to manipulate the shape.
                    Some ideas Minutes 13.20 😉
                      JSA_SJ
                      I downloaded the Quad face tool and the split tool, just tried them as the photo but I may need to add more triangulates to make the holes look smoother. But I think it'll work to model that building. Very much appreciated.
                        The more times you click the green button the smoother the geometry becomes.
