    3D Truss Models
    1.5k Posts 31 Posters 936.3k Views 30 Watching
    • medeekM Offline
      medeek
      I next want to turn my attention to mid-panel splices:
      http://design.medeek.com/resources/images/truss_su238_800.jpg
      Nothing to exciting going on with this bottom chord splice, the splice will be loaded in tension with a moment, the same methods developed previously would apply.
      In the case that the OSB or Plywood doesn't have enough strength for the combined axial + moment load then a vertical extension like what is shown could be improvised. This will not only increase the moment capacity of the gusset plate(s) but also the tensile strength. Note, that the number of fasteners into each bottom chord is not modified or decreased by the vertical extension of the gusset plate.
      To be conservative I would not consider the 2x4 insert in the calculations of the updated tensile or moment strength of the gusset plate(s) even though it will contribute some unspecified amount. The filler block is primarily to secure the protruding gusset plates and to prevent them from buckling out-of-plane. To that end I don't feel that specifying the number of fasteners is overly critical. A reasonable amount of fasteners and some glue will create a cohesive unit.
      In the case of top chord splice with the members being in compression the previous equation would dictate using a force that is 1/2 the compressive force, this would seem reasonably conservative but other load cases that could potentially load the splice in tension should also be investigated and compared. Again, any moments at the splice would also factor into the gusset plate sizing and fastener quantities.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        The member calcs for a WGC truss will be very similar to an mpc truss except that the matrix analysis model will have rigid joints instead of pin joints. This will introduce some minor bending into the internal webs but nothing significant since these member are not being loaded along their spans. The deflection of the truss should probably improve slightly with its higher rigidity.
        design.medeek.com
        • medeekM Offline
          medeek
          Spent some time Sunday night and yesterday evening working on the stepdown hip truss set. Given the shear number of trusses involved in one of the these assemblies I'm figuring it will be the rest of the week before I will see the light at the end of the tunnel, but progress is steady.
          design.medeek.com
          • medeekM Offline
            medeek
            The stepdown hip truss set is mostly finished. I probably have a couple more days of work setting up raised heels, internal web algorithms, and advanced options.
            http://design.medeek.com/resources/images/truss_su239_800.jpg
            design.medeek.com
            • medeekM Offline
              medeek
              Advanced options are now configured: fascia, sheathing, cladding, gypsum, ceiling battens.
              Girder trusses can be single or double ply, I can add more plies if requested.
              I've also added the option to use a drop-in purlin frame, see image and model below:
              http://design.medeek.com/resources/images/truss_su240_800.jpg
              View model here:
              3D Warehouse
              (3dwarehouse.sketchup.com)
              Items still needing attention:
              • Error check in metric mode.
              • Internal webs for hip trusses
              • Internal web algorithm for end and hip jack trusses.
              • Raised heels
              • Enable soffit cut for jack trusses and hip trusses.
              • Enable plates for hip, jack and drop-in purlin.
              • Setup the half-a-hip option (one end is a gable end).
              design.medeek.com
              • medeekM Offline
                medeek
                The complexity of the hip truss sets makes them a bit of pain to program but when its all said and done it is a thing of beauty.
                Once I have the stepdown hip set well on its way it will not be to difficult to enable the other styles of truss hip sets. The only one that is significantly different is the terminal hip set and the dutch hip set but even those will fall into place relatively easily.
                Once I get all of the hip sets configured I'm half tempted to bump my price another $10, would that be too much of a stretch? I'm already at $30 for the plugin and I would like to keep it within reach of even the casual user.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.9.2 - 06.24.2017
                  • Added Stepdown hip set trusses.
                  • Enabled advanced options for stepdown hip sets.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Using the stepdown truss set as a primitive it is possible to generate some fairly complex roofs:
                    http://design.medeek.com/resources/images/truss_su241_800.jpg
                    In this case I created two hip sets and then tied them together with a valley set. View model here:
                    3D Warehouse
                    This one way to do it but the more typical way would be to further customize the larger hip set so as to eliminate the valley set entirely.
                    Interesting how the larger girder truss ties into the smaller girder truss (3 ply). The smaller girder truss would need to be beefed up to handle this point load if there is no bearing wall below, and then the point loads from the posts supporting the girder truss (in wall) would probably need spread footings.
                    A few seconds to create the basic geometry and then about 10 minutes of trimming (with the trim function) and manual adjustments. I can see that the truncated hip set feature would be nice to have where hip roofs are tying into other roofs, similar to what I have enabled for the gable truss tool.
                    design.medeek.com
                      MtnArch
                      In my neck of the woods we don't use valley sets - where one roof covers the main truss set it is usually stick-framed (usually 2x4's and 2x6's) with what we call 'California Fill' that bears on the main set. PM me if you'd like to see a typical detail.
                      Highest Regards,
                      Alan T. Hendry, RA
                      Architect
                      • medeekM Offline
                        medeek
                        I've seen them done this way up here in Washington but probably not as often.
                        https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=6e7076e2-910c-4877-a8fd-253830273f51
                        I haven't shown the vertical studs and their pads only the sleepers, rafters and ridgeboard are shown, view model here:
                        3D Warehouse
                        Where the Fill connects back to the other roof do I have that correct? Do you install another rafter against the truss?
                        Notice that I did not bevel the 2x12 sleeper, just shifted it so that if lines up correctly with the roof plane, of course if this is mounted on top of the sheathing then the position will change accordingly.
                        Those double bevel cuts on the rafters would scare me, but then again I'm no carpenter.
                        Funny how everything has a "California" in front of it:
                        • California Corner (Ext. Wall Corner) http://design.medeek.com/resources/framing/FRAMING_CORNERS.pdf
                        • California Fill
                        • California Hip Set https://3dwarehouse.sketchup.com/model/97644895-c988-435c-bdc4-c7b8956a6d46/California-Hip-Set-Rev-2
                        I guess the Californians are innovators.
                        design.medeek.com
                          MtnArch
                          That's pretty much how it's done down here, and with the detail I sent you it sounds like what you've seen and what we do are pretty close. I would agree, too, that the 2x sleepers rarely have the edge beveled to be in-plane - it takes too much time for the framers to figure the correct cut.
                          Highest Regards,
                          Alan T. Hendry, RA
                          Architect
                          • medeekM Offline
                            medeek
                            I was working on the hip sets last summer before my neck injury took me out so I'm glad to finally get back to it and at least get one variant knocked out.
                            I probably should have gotten on to it in January but I was still not feeling 100% so I been only tackling the easy stuff and chipping at those one by one.
                            I still have all the other variants to complete as well as raised heels, then the plates.
                            Timber trusses with bolted connector plates is on my hot list as is completion of the attic and gambrel attic trusses.
                            My full todo list for the plugin is at least two pages of hand written notes so there is plenty more to do.
                            The holy grail would be to have the plugin convert any complex roof outline (face) into a full truss or rafter roof without any manual editing, that is my target.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Added energy/raised heels for stepdown hip set (3 variants: wedge, slider and vertical w/ strut).
                              http://design.medeek.com/resources/images/truss_su243_800.jpg
                              View model here:
                              3D Warehouse
                              Now the possibilities are limitless since you can match the heel height of any other roof (ie. rafter, TJI etc...)
                              Adding in this feature was not as bad I thought it would be but each truss type in the set must be considered and dealt with separately:
                              • Common Trusses
                              • Hip Trusses
                              • End Jacks
                              • Hip Jacks
                              • Corner Jacks
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                I am wondering if any one has some shop drawings for a truss roof like the one below:
                                http://design.medeek.com/resources/images/misc/model-home.jpg
                                I am trying to understand how the trusses are configured where the two roof lines meet at the interior corner.
                                I'm also looking for a full set of shop drawings for a California Hip Set, I'm seeing a few variations with this hip set I'm trying to determine the most typical way they are put together.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  For those not familiar with truss hip sets, here is a primer:
                                  6" raised heel with open end jacks and a drop-in purlin frame.
                                  I've also added in the option for open or closed end jacks (sub release "d").
                                  http://design.medeek.com/resources/images/truss_su244_800.jpg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.9.3 - 06.25.2017
                                    • Added Terminal hip set trusses.
                                    • Enabled advanced options for terminal hip sets.
                                    • Added energy/raised heels for terminal hip set (3 variants: wedge, slider and vertical w/ strut).
                                    • Added the option for open vs. closed end jack and single and double ply girders
                                    http://design.medeek.com/resources/images/truss_su245_800.jpg
                                    View model here:
                                    3D Warehouse
                                    This style of hip set is typically used for spans less than 20 ft.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Here is a model of the L-shaped hip roof I am in question about:
                                      https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=80a3499e-e459-40f6-851f-0df9c328cb83
                                      View model here:
                                      3D Warehouse
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        I've been following my ratings for the plugin in the PluginStore for a while now and I've now reached 30 ratings, however my rating level is progressively getting worse 3.2 -> 3.1, I've been adding more features and improving others but the rating level is gradually falling. What am I doing wrong?
                                        I admit that a comprehensive manual would be a useful companion to the plugin, so perhaps that is where I'm dropping the ball.
                                        Tonight I'll probably put together another tutorial video explaining the new hip truss tool and its features.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          I think my love of trusses sometimes blinds me to the fact that most people don't really care to model the details of their roof. With that being said I don't think my time was wasted since I have learned an immense amount about programming a SketchUp Plugin and manipulating the API. However, I think it is now time to give the Truss Plugin a rest and focus my efforts on projects that will give me a better return for my investment. I'm not sure what exactly those projects are yet but I'm working on it.
                                          http://design.medeek.com/resources/images/truss_su246_800.jpg
                                          design.medeek.com
                                          • jujuJ Offline
                                            juju
                                            The manual would be a useful addition. I think the most commonly used trusses configurations have been covered, users can always contact you / request additional functionality as it comes up.
                                            Are all features available and consistent across all truss types? If not that is probably one thing that may need to be addressed for the time being before the extension's development "takes a rest".
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 75
                                            • 76
                                            • 34 / 76
