    Default dimension style
    10 Posts 6 Posters 6.1k Views 6 Watching
    • E Offline
      ever
      Can someone explain me if, and how, it is possible to change the default dimension style
      P: ever
      • KrisidiousK Offline
        Krisidious
        go to Window>Model Info>Dimensions
        you can change
        Font
        Font Color
        Leader Type
        and alignment type
        then there is the expert settings, that's mainly how to show the dimensions...
        good luck.
        By: Kristoff Rand
        • E Offline
          ever
          Thanks,
          This is what I needed
            Krisidious
            mp
            By: Kristoff Rand
            • N Offline
              nyszabolcs
              you can change
              Font
              Font Color
              Leader Type
              and alignment type
              good luck.
              and if you get tired of changing it every time when creating a new drawing, then create a new file, change everything you need.
              Save it in a convenient place (maybe with the templates), then go to Preferences - Template and choose your freshly customized template.
              Sorry if it's been mentioned before. I've just done it, and had to share.
              Regards,
              Szab
                No, Szabolcs, that's a good tip. You can always save a file with special sets under the Resources > en-US (in the English version) > Templates folder to have it at hand when changing or choosing your custom templates.
                Actually there is a template_utils.rb plugin by Jim Foltz which allows you to easily save a file as a template. Download from here:
                http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_fil_page.htm
                • chrisglasierC Offline
                  chrisglasier
                  But how do you get rid of mm as default - which, if I remember correctly, is contrary to ISO standards.
                    Do you mean you don't want to show the units? In Window>Model Info>Units, untick "Display units format."
                      chrisglasier
                      As concisely helpful as I remember. Thanks.
                        Happy to help.
                        If you don't want those units to show in future models, remember to open a fresh SketchUp session and make that setting. Then use File>Save as template to make a new default template.
