    Creating VR experience for SketchUp models
    15 Posts 2 Posters 2.3k Views 2 Watching
      ashraf
      Samples can be found as part of SimLab Composer.
      Install SimLab Composer from the following link
      After installing SimLab Composer, start SimLab VR Showroom, it includes different samples that you can view using HTC Vive, Oculus Rift , or using the Desktop viewer.
      The following tutorial shows how to add and view models to the Showroom
      @ntxdave said:
      BTW: On the animation, can you animate subcomponents/subgroups?
      Yes you can do that.
      Following example shows something done for a simple system
      • ntxdaveN Offline
        ntxdave
        Thanks for your quick response.....it looks like this product has come a long way.
        I downloaded a trial version about 18 months ago. Would I be allowed to "try" it again?
        Press F1...thank me later
          ashraf
          Yes, this is a new version so you should get a new 21 days of free trial.
          If you faced any issue with trial, email license@simlab-soft.com they will help you with that.
          • ntxdaveN Offline
            ntxdave
            Thanks @ashraf, I was able to download it and have it running. However, I am having huge performance problems. Any action I try to perform is resulting in 30-60 second delays. I even tried rebooting the machine after installing the software but still get the same lag. Is there a setting somewhere that I need to check?
              ashraf
              😞 this is strange, the first time i hear about that.
              We have a good user base with different machines.
              Are you getting the delay in Simlab composer action or when running a VR experience?
              • ntxdaveN Offline
                ntxdave
                When I am running SimLab Composer. I think I am going to uninstall and reinstall. Maybe I can do that later today.
                OK, I completely uninstalled and reinstalled 2 times and still the same problem. I have trouble getting almost anything done because of the huge lag after clicking on anything.
                  ashraf
                  This is really strange.
                  Are you getting this even before opening a model? with Simple ground?
                  Do you have an anti virus slowing the machine?
                  Ashraf
                  • ntxdaveN Offline
                    ntxdave
                    Ashraf
                    Yes, I am getting this even before opening a model.
                    I started up Composer and everything seems fine. When I click on the materials panel, I can expand/close material categories and everything seems fine. So then I created a sphere an wanted to apply a material to the sphere. That seemed to go pretty good but then I thought I would try a different material. That is when things started going down hill. If I tried to select a different material category, things began to slow down. Once the new category opened I noticed that when I moved my mouse over different materials, there was a lag that began to show up as I moved the mouse from one material to the next. It would take a couple of seconds for the new material name popup to show with the correct name for the next material. It also then began to be more difficult to change material categories. The delay time increased.
                    I also went to the toolbar along the top of the viewport. At first when I clicked on a selection, the dropdown panel would show up quickly but after then things began to slow down there too. It then takes several seconds (somewhere around 10-20 seconds) for the panel to show up. If I now the shortcut key to click for what I want to do, that seems to work fine.
                    It appears to me that it all has something to do with the interface. When I can use a shortcut key, that seems to work fine. It is when I need to select a new panel or click on something in a panel that I get the delays. Cannot say for sure but it seems that longer I work or the more I do, the slower it goes. I have also noticed that it seems to affect other applications that I might be running at the same time. As an example, I was working in Composer and wanted to go check an email. When I switched over to email, the screen had a slow reaction and the email screen was messed up for about 6 or 7 seconds.
                    Hope all of this helps.........
                    • ntxdaveN Offline
                      ntxdave
                      I signed up for the SimLab Composer forum and found out this is not really that strange after all. Look at this link on your forum and you will see that others have experienced something very similar but I could not see how they really solved it.
                      This is really holding me back and the clock is ticking on my trial.
                        ashraf
                        Are you running windows 10?
                        When you right click on the composer windows do you run with graphics card so you can select a graphics card to run with?
                        • ntxdaveN Offline
                          ntxdave
                          Yes
                          When you say "right click on composer windows" I am not 100% sure what you are asking. What do you mean by "composer window"? Do you mean after I have started Composer?
                          • ntxdaveN Offline
                            ntxdave
                            For anyone else who may be experiencing problems on Windows 10, please see visit this thread on the SimLab Forum and I think you will see that the problem has probably been identified and is in the process of being addressed. Hope the resolution comes quickly.
