    MSPhysics tests and questions
    104 Posts 21 Posters 59.7k Views 21 Watching
    • robintR
      robint
      Hi Anton
      Just seen your Turret thingy, blown away by it
      30 pages of code - I might as well try and become a brain surgeon!
      3D Warehouse
      (3dwarehouse.sketchup.com)
      Very skilful
      Robin
      As one door closes another one slams in your face
      • gillesG
        gilles
        Just playing with basics,
        brought me to some questions:
        When you at the screws,
        -one is static mesh and is collision shape fits perfectly.
        • to achieve the same collision shape for the mobil oneI had to it with several components.
        Any reason the soft isn't able to calculate the same collision shape but not static?
        To make those movements running well I used a workaround.
        For rotation we have hinge, motor, servo.
        For translation we have slider, piston, why not a linear motor?
        For translation + rotation we have corkscrew, why not motor + linear motor , servo + piston, servo + linear motor , linear motor + piston?
        For curve we have curvy slider and curvy piston, why not a curvy motor and curvy piston?
        Nota bene: just curiosity here, no request.
        Vis MSPhysic.skp
        • robintR
          robint
          At last
          Terminal velocity
          Time
          Distance
          Now the basis of my cannon project
          Anton has made a sophisticated urret thingy available on 3D warehouse/msphysics
          but I want to make a simpler model for a gunner with inputs for
          horiz angle
          Azimuth
          muzzle velocity
          Range (from a range finder measurement of a distant target placed at random)
          Air density (from Bar pres, RH and temp)
          Air friction ?
          output > distance landed from target (eg a forward spotter)
          Simplistic stuff for a Napoleonic gunnery officer
          Maybe a moving target next (eg tank)
          On the 7th day god made Robin
          falling block6.skp
          • F
            faust07
            Hi Anton, after extensive tests with the fairly complex ice stage model, I can report that everything works very well.
            I just had to reverse some curves and exchange the programmed Curvy Piston Joint for the Orca. The calculation of the transformed emitter objects seems to work more precisely.
            This costs a little more time for the simulation, but the viewport problems no longer occur.
            That's great! Thank you very much!
            I have extended the simulation around a rain with middle large hailstones and it works.
            And for the future the integration of the good old SketchyPhysics fracture/split function and a kind of soft or flexible surfaces would be great...
            πŸ‘
              Anton_S
              Thanks for testing and verifying, Faust. Next feature would be to improve performance of export to Skindigo and Kerkythea. I think there is a way to reduce export redundancy. The fracture thingy would be implemented too.
              • F
                faust07
                Sounds good!
                • F
                  faust07
                  Testing MSPhysics in SketchUp 2017.
                  In a direct comparison between SketchUp Make 2016 and 2017, this incomplete image is created in 2017 when using the following script:
                  Sketchup.active_model.active_view.write_image("e;/MSPh_Temp/frame_%06d.png" % frame,1600,900,true,1.0)
                  How should it be right for SUp 2017?
                  result in SUp 2016
                  result in SUp 2017
                  • Z
                    ZoltanSpin
                    (learning Ruby for MSphysics)
                    I would like to move several objects, each one following an (x,y,z) curve, in a synchronous manner.
                    I imagined to have a public tick and then on tick each body compute its next (x,y,z) position and goes there using set_velocity([vx,vy,vz]).
                    • is this a correct way to use MSphysics scripts? Are there (close) examples in warehouse?
                    • how to write if for, say, a cube moving at 1m/s from x=0 to x=100m then when x=100 --> x=0 and loop?
                      Thank you for your help.
                      Anton_S
                      Hello, Zoltan,
                      Yes, you understood the concept correctly.
                      For such behavior, however, a script might not be necessary. You can use a Piston or a CurvyPiston joint. When you add a Piston joint, set its position units to m, linear rate to like, 1000, and the controller to, world.time % 10. This will generate a value b/w 0 and 10 on a timescale of 10 seconds.
                      Also, in case you don't know how to use joints, here is a Wiki:
                      https://github.com/AntonSynytsia/MSPhysics/wiki/Using-Joints
                      But if you want a special behavior that would teleport a moving object after it surpasses a scalar of a coordinate, then this is how you do it:
                      onStart {
                        @max_x = 100.m
                        @start_pos = this.get_position(1)
                      onUpdate {
                        this.set_velocity(1,0,0)
                        if this.get_position(1).x > @max_x
                          this.set_position(@start_pos)
                      Paste this script into the desired moving object(s).
                      Basically, this will move an object at 1 m/s along the x-axis and teleport it back to start when the objects X coordinate surpasses maximum x position.
                      You can also, instead, control it by force rather than velocity:
                      onStart {
                        @max_x = 100.m # in inches; the .m converts it meters to inches.
                        @des_vel_x = 1 # in m/s
                      onUpdate {
                        # Compute the desired acceleration in m/s/s -> (des_vel - cur_vel) / timestep
                        ax = (@des_vel_x - this.get_velocity.x) / simulation.update_timestep
                        # Apply force
                        this.add_force(ax * this.mass, 0, 0)
                        # Teleport if necessart
                      Applying forces are better than applying velocities because they don't dissipate any other forces like the force of gravity or the force of contacts. Also, if you don't want to have the object be affected by the gravity, you can, as well, add force to the z component, like 9.801 * this.mass or you can simply disable gravity for the object. Both yield the same behavior.
                      But, like I said, to if you want to create moving platform that doesn't involve teleportation, you can add a Piston joint and connect it to the desired object. Then add an oscillator controller to the Piston joint, like oscillator(50)*100.
                      Regards,
                      Anton
                        DingBEN
                        I created a floor (static mesh), and a ball and a cube both compounds
                        I tilted the floor (5)
                        ...Friction ON
                        Play:
                        • Ball rolls to the edge of the floor and stops! ?
                        • Cube does not even move
                        ...Friction OFF
                        • both roll/slide off the floor and disappear in the abyss
                        I wait for 10 15 secs,
                        • the floor's front face disappears so the inside of the floor can be seen,
                        • and from that face the floor melts away until it reaches the back right corner
                        • then it melts from the back right corner to the left one and vanishes!
                        Also if using any SketchUp commands, for example, to realign the scene
                        then the behavior of objects and mouse pointing and other function go to the abyss of absurdity
                        Hope this is helpful.
                        • F
                          faust07
                          Hi DingBEN,
                          I guess the ball stops at the edge because its shape is defined as "Compound".
                          You could test is with a collision shape "Sphere".
                          When in MSPhysics objects fall down into infinity, they gradually enlarge the overall model.
                          They are falling too far away from the camera.
                          And the "clipping" problem known in SketchUp is getting stronger until all objects are optically cut off in the field of view of the camera.
                          You can read a bit more about the "clipping" issue here:
                          http://support.google.com/sketchup/bin/ ... swer=36261
                          • C
                            chad3006
                            I posted this same question at the MSPhysics Github. I'm very new to MSPhysics and not very smart either, so I was wondering if anyone has attempted a simulated wind-tunnel or something like that using MSPhysics? Is such a thing even possible at the moment? If so could you share?
                              Anton_S
                              Wind tests are not possible with MSPhysics. I once came across a plugin dealing with fluid analysis but can't recall the name of it.
                              • F
                                faust07
                                Here the first small test example MSPhysics v1.0.0 with scripted emitters.
                                Unfortunately, SketchUp crashes completely after a few seconds.
                                In MSPhysics v1.0.0 WIP7 there was no problem with this.
                                Thanks in advance.
                                Edit: Fixed in high Speed - now it works - thanks to Anton! πŸ‘
                                Rain-Test_SUp17-MSP100_01.skp
                                • ecatiE
                                  ecati
                                  To ensure smooth movement, how should the green piece connect to the blue piece?
                                  soru.skp
                                    Anton_S
                                    The green piece can be grouped with the blue pieces: ungroup both of the blue pieces, hold CTRL, select the green piece, and regroup them all together.
                                    For improvements you can change the collision of the yellow wheels to Cylinder shape. Also, set the solver model to iterative 16 passes and material thickness to zero.
                                    The only way you will achieve a smooth ride is by relying on the CurvySlider joints and having the entire track set be ignored; relying on contacts will rarely show you good results. Here I attached your model with two CurvySlider joints lining the entire track. I also used Fredo6's Curvyvizard (http://sketchucation.com/forums/viewtopic.php?p=415495#p415495) to smooth the curvy at certain, rough locations.
                                    soru.skp
                                    • F
                                      faust07
                                      Comparison between V0.9.9 and V1.0.1(V1.0.2)
                                      Have the following problems:
                                      • the deep impact of small scripted emitters on heavy bodies.
                                      • strong reflection of that emitted objects (non collision) on a Buoyancy Plane.
                                      • continuous OnTouch events of object with a plane for "waves" and "splashes" don't work anymore.
                                      Here are two files, on for SkechUp 2016 with MSPhysics v0.9.9 witch worked well and the other for SketchUp 2017 with MSPhysics v1.0.1 for witch I need help.
                                      For the parallel tests I hade to install MSP v0.9.9 on SUp 2016 - sorry!
                                      The GIF of V0.9.9 shows what I want to achieve.
                                      Thanks in advance!
                                      OnTouch-Test_01_MSP0.9.9_SUp2016.skp
                                      OnTouch-Test_01_MSP1.0.1_SUp2017.skp
                                        Anton_S
                                        There were a few issues.
                                        In new version, onTouch is triggered only one time, whenever there is a contact between bodies. In your script you tried to use the onTouch event as a repetitive event for generating trailing waves. It did work, as a bug, in version 0.9.9 but not anymore.
                                        Another thing is setting emitted bodies non-collidable. Setting the original bodies non-collidable won't make the emitted body non-collidable. You must appply such state explicitly to the emitted body:
                                        body = simulation.emit_body(...)
                                        body.collidable = false
                                        I fixed all these issues and also made rain droplets be independent of touch event.
                                        Faust's Whale.skp
                                        • F
                                          faust07
                                          Hi Anton, once again thank you for the quick reply. πŸ‘
                                          This is, of course, an interesting approach and for me something new to explore again.
                                          A touch function as a repetitive event for generating something would be great. I think it was a good bug and you should bring it back as separate option. if it is possible... 😎
                                          One problem in the new solution is, that after about 700 frames the lifetime of some emitted objects doesn't end.
                                            Anton_S
                                            Hmm... I think something is wrong in code or with MSPhysics. Try changing the rain dproplet's code to this:
                                            onStart {
                                              @instances = {}
                                            onTick {
                                              dir = this.group.transformation.zaxis
                                              dir.length = this.mass
                                              point = this.get_position + Geom;;Vector3d.new((rand()-0.5)*1000, (rand()-0.5)*1000, (rand()-0.5)*10)
                                              tra = Geom;;Transformation.new(point)
                                              rain = simulation.emit_body(this, tra, dir, 5)
                                              rain.collidable = false
                                              @instances[rain] = true
                                              @instances.reject! { |k,v|
                                                next true unless k.valid?
                                                point = k.get_position(0)
                                                if point.z < 0
                                                  #k.destroy(true)
                                                  posineu = Geom;;Point3d.new(point.x, point.y, 5)
                                                  tra = Geom;;Transformation.new(posineu)
                                                  body = simulation.emit_body(@@splash2, tra, @@dir, 0.25)
                                                  if frame % 3 == 0
                                                    posineu = Geom;;Point3d.new(point.x, point.y, -2)
                                                    body = simulation.emit_body(@@bubble2, tra, @@dir, 0.2)
                                                  next true
                                                false
                                            Aside from that, you can use onTouching event for repetitive action, but it only yields toucher parameter and doesn't provide touch position.
                                            • 4 / 6
