    Foundation Plugin
    451 Posts 15 Posters 580.3k Views 15 Watching
    • medeekM Offline
      medeek
      An irregular shaped FPSF, note the 135 deg. corners. Once this angle becomes greater than 135 degrees I would probably just treat it the same as a straight wall.
      http://design.medeek.com/resources/images/foundation_su46_800.jpg
      View model here:
      3D Warehouse
      (3dwarehouse.sketchup.com)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.1.3 - 06.03.2017
        • Added "FPSF" option to rectangular slab-on-grade foundations.
        • Added "FPSF" option to rectangular stemwall foundations.
        • Added an insulation layer in the global settings under the "Layers" tab.
        http://design.medeek.com/resources/images/foundation_su47_800.jpg
        design.medeek.com
        • medeekM Offline
          medeek
          http://design.medeek.com/resources/images/foundation_su48_800.jpg
          design.medeek.com
          • medeekM Offline
            medeek
            Working on the square/rectangle spread footing tool:
            Post Footing
            I will start with wood posts as an option with the following sub-options for the wood post:
            Post Size: 4x4, 4x6, 6x6, 6x8, 8x8
            Post Height (in.)
            Post Base: None, ABA, ABU, ABW, CBSQ
            Post Cap: None, CCQ, ECCQ
            Post Rotation: 0, 90, 180, 270
            I also plan on having the option for steel posts with the following sub-options:
            Post Size: HSS4x4x1/2, HSS4x4x3/8, HSS 4x4x1/4, HSS3x3x3/8 etc... (round and square tube)
            Post Height (in.)
            Base Plate Size (in.) - square shape L x L
            Base Plate Thickness (in.)
            Base Plate Hole Dia. (in.): 1/4, 3/8, 1/2, 5/8 (4 bolts per baseplate)
            Vert. Offset (in.) - for non-shrink grout
            Post Cap: Not sure what to do with this yet.
            http://design.medeek.com/resources/images/foundation_su49_800.jpg
            http://design.medeek.com/resources/images/foundation_su50_800.jpg
            I've been contemplating using the Simpson Strong-Tie post caps and bases as provide in the warehouse but I'm worried that the polygon count is too high. I may have to generate my own dumbed down versions.
            http://design.medeek.com/resources/images/foundation_su51_800.jpg
            My 13 year old daughter asked, "What is this for? What good is it?". I replied, "It is good for all sorts of things, just like a Thneed." Then I proceeded to discuss decks, porches, carports etc...
            design.medeek.com
            • medeekM Offline
              medeek
              Added "FPSF" option to polygon slab-on-grade foundations:
              http://design.medeek.com/resources/images/foundation_su52_800.jpg
              design.medeek.com
              • jujuJ Offline
                juju
                Can you do that with the option of putting it (as a vertical component only) on the inside of the foundation wall? It may be of use in climates that isn't as cold and you have the option of putting it either inside or outside of the foundation plinth wall.
                • medeekM Offline
                  medeek
                  I can add another option to insulate the vertical interior face of the stemwall/foundation wall.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Working through the issues of the polygon FPSF option has helped me understand better how to deal with adjacent walls in particular non-orthogonal walls and how best to calculate the geometry at their intersections.
                    This has me primed for further development of the wall plugin, so even though this feature may not have much use for most of the client base it still have served a major purpose in educating me.
                    With the tool function I am able to create lines to show preview geometry however I am wondering if there is a way to show a dimension (beyond showing the numerical value at the bottom of the SketchUp window).
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      An octagon slab on grade (FPSF). Note that the angle of the corners is 225 degrees, any less and the corner treatment would go away.
                      http://design.medeek.com/resources/images/foundation_su53_800.jpg
                      Clarification on the angles:
                      Any corner with an inside angle greater than 135 degrees will not receive corner treatment.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        I've had some discussion with other SketchUp users about developing the plugin for commercial use. Should I require that the user have PRO installed? A number of registered users of the plugin do not use it for commercial use, I would rather keep it open to all users but it would be easier to develop within PRO with its Boolean functions.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Added "FPSF" option to polygon stemwall foundations.
                          http://design.medeek.com/resources/images/foundation_su54_800.jpg
                          Now I've thoroughly beaten the FPSF option to death, the only thing I might add in later is a global setting to change the insulation color to pink, blue or white.
                          design.medeek.com
                          • jujuJ Offline
                            juju
                            Unless the person using it is a registered professional (engineer, etc.) and the application is within the ambit of their qualifications / registrations and they are using it for a personally owned property I would argue that the use could be for commercial purposes, in my mind anyway.
                            Else the works created would need to be "signed off" by a professional, in which case the lines get blurred and the commercial application / gain with the use of the extension arises...
                              db11
                              Is there an option for underslab insulation? What is the range of insulation thickness available?
                              • medeekM Offline
                                medeek
                                I guess I'm not done with the FPSF option just yet. Insulation thickness is open ended you can put in as thick as you like, some areas apparently install insulation upwards of 12".
                                How do you want the underslab insulation configured?
                                design.medeek.com
                                  db11
                                  In our climate, we use full underslab insulation (anywhere from 6-14") to thermally isolate the slab. In PassivHaus builds we float the house on a 12 - 14" EPS tray that totally eliminates thermal bridging through the envelope and conduction loss to the ground.
                                  Inside perimeter insulation — 2 to 4' of EPS/XPS extending inward from the footing leaving the center area uninsulated — may be sufficient in milder climate zones, and was/(still is?) common for use under basement slabs. But here, the conduction heat loss through the slab renders any material savings moot after the first winter or two of heating bills.
                                  I'll PM you a foundation drawing set for a recent build to give you an idea of our approach — not as an input for feature requests, as I realize that our approach would be considered way overboard by people unfamiliar with PH standards — but just for your interest.
                                  And if you haven't had a chance, I recommend highly that you check out the Iso-Slab website linked in an earlier post. It derives from European slab insulation systems that have been available for years there, originally developed to meet the needs of a burgeoning PH market. It will give you an idea of where building is going, even if the NA construction industry is notoriously slow and resistant to adopting new methods / better materials / higher performance standards.
                                  • medeekM Offline
                                    medeek
                                    The Passivhaus system is really something else. With your form profile what are the measurements that are variable? Is the slab always 8" deep on your typical builds?
                                    design.medeek.com
                                      db11
                                      I should note that specific assemblies and methods — whether foundation / wall / roof etc — are not spec'd by the PH standard, rather their performance is. How you get there is up to you.
                                      So the 8" monolithic slab isn't hard and fast, though it's what we've settled on for combined strength and simplicity: any increase in concrete costs is made up for by simpler tray forming and prep. It could also be done with a 10" grade beam and 6" slab. Seems to me that since you've already enabled grade beams in your regular foundations, then you could use that shape for the upper face(s) of the underslab insulation. (another example where the boolean solid tools would simplify things).
                                      As to the other measurement variables:
                                      1. EPS thickness (obviously) with underslab and edge thickness as independent variables.
                                      2. The width of the upper portion of the EPS footing profile is dependant on the combined outboard cavity wall / sheathing so that the rainscreen / envelope terminate flush with the EPS (as shown in the section drawing I sent you), .
                                      3. The height of the upper portion is simply the slab depth.
                                      4. The front edge profile (chamfer) is just to provide a good integrated drainage plane and connection to the frost protection, so not critical. For first go-round it could be square to simplify things.
                                      5. Frost protection is uniform 4' around the perimeter @ 4" thick, so maybe width and thickness of FP EPS should be independent variables as well?
                                      I'll check with the principal of our firm to see if he's OK with me posting an anonymized version of the EPS tray drawings I PM'd you, so that others can follow/engage the discussion.
                                      • medeekM Offline
                                        medeek
                                        Since I use the followme tool in the API, I can literally form any profile possible. What I need is a typical profile with a variable instead of a number for each critical dimension then I can incorporate it into the plugin. What should I call this kind of insulated slab? I don't want to use Passivhaus if it would violate your copyright protection. Or then again it may help you advertise and sell more houses using this type of foundation.
                                        design.medeek.com
                                          db11
                                          Let me get back to you with a typical profile.
                                          As for naming, Passivhaus / Passive House isn't our trademark, but rather that of the Passive House Institute (Passivhaus Institut in Germany, where it originated): http://www.passivehouse.com/index.html
                                          I'll see if we can come up with a more generic but still descriptive name. We have simply used 'EPS Tray Foundation' as our descriptive term, so maybe that would work... if we can't find anything better.
                                          • medeekM Offline
                                            medeek
                                            Is this type of construction generally rectangular or do you construct any shape or outline?
                                            From a structural standpoint how do you deal with anchor bolts and even more importantly holdowns? The eight inches of concrete does not provide enough embedment depth for your typical holdown anchor bolts.
                                            design.medeek.com
                                            • 22
                                            • 23
                                            • 8 / 23
