    Quick Tip on drawing rectangles 'from a center point.'
    6 Posts 5 Posters 3.7k Views 5 Watching
    • chippwaltersC Offline
      chippwalters
      I know Fredo has a tool for this, but I sometimes find it's more of a hassle, especially when it's trying to snap to other geometry. I just learned this recently (after many,many years of SU) showing even an old old dog can get lucky and find a bone sometime πŸ˜‰
      Interested if anyone else has a better way...
      https://dl.dropboxusercontent.com/u/3788438/3D/SU-ScaleRect.gif
      Currently working with Cross-Reality technologies
      • BoxB Offline
        Use the corner grip and you can do it in one go.
        As a side note, if you want a centered square you can use the polygon tool set to 4 sides. Ctrl will toggle the orientation.
          Draw any rectangle
          Draw a diagonal
          Group the diagonal (by ShortCut : Menu Edit Create a Group)
          Move the rectangle from the middle of the diagonal to the "Point" wished
          Size as wanted πŸ€“
          Oe maybe something like this
          Make a Component Rectangle with Axes at intersection of Diagonals
          load at any time on the Point wanted
          Size as wished! πŸ’š
          etc...
            chippwalters
            Thanks for the tip!
              rawbee
              R key for rectangle, then hold down the control key
                That became available after this thread started. And you don't need to hold Ctrl. Just tap and release.
