    Dynamic Component DCFunctionsV1 within in Module
    34 Posts 4 Posters 22.8k Views 4 Watching
    • Dan RathbunD
      Dan Rathbun
      @michaelwhksg said:
      Hi TIG. Sorry, will use the "code" tags in future.
      (1) A better idea is to edit your previous post, and insert the code tags.
      (2) The example is STILL wrong in that the check for method definition still uses the name atan2.
      (3) Yes, please use a unique method name, as your implementation of the atan2 method (specifically the parameter list) is not how the rest of the world would define it for use by ALL coders.
      I'm not here much anymore.
      • michaelwhksgM
        michaelwhksg
        If i am using the code which you have shared, and keying DCFunctionsV1.instance_methods.sort in the Ruby Console, I do see atan2 appearing in the console.
        However, if I tried inserting the DCFunctionsV1.instance_methods.sort into the code, an error message appeared.
        Below is the code which I have tried...
        # add_funcs.rb
        # extends DCs functions
        require('sketchup')
        module ABC
        module ABC123
        if Sketchup.version.to_i <= 8
          require('dynamiccomponents.rb')
        else
          require('su_dynamiccomponents.rb')
        if defined?($dc_observers)
          # Open SketchUp's Dynamic Component Functions (V1) class.
          # only if DC extension is active
          class DCFunctionsV1.instance_methods.sort #(did I do this correctly?)
            protected
            unless DCFunctionsV1.method_defined?(;atan2)
              # access to Ruby's arctangent method
              # Usage; =atan2(y,x)
              def atan2(a)
                return Math;;atan2(a[0],a[1]).radians
            end#unless
            protected;atan2
          end#class
        end#if
        end #module ABC123
        end #module ABC
        This generated an error message.
        "Error Loading File arctan-test2.rb
        Error: #<SyntaxError: C:/Users/wongh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/arctan-test2.rb:16: syntax error, unexpected '\n', expecting :: or '[' or '.'
        C:/Users/wongh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/arctan-test2.rb:30: syntax error, unexpected keyword_end, expecting end-of-input
        end #module ABC
        Is there anything I have done wrongly?
        arctan-test2.rb
        arctan-test.skp
        • michaelwhksgM
          michaelwhksg
          Since we are unable to wrap the class DCFunctionsV1 in the name space, if we just submit the script with 2 parts, one of which is the DCFunctionsV1 and letting the formula be defined as my own unique name, and the second part which is wrapped within my name space, will this work? Will EWH team accept this?
          For example,...
          # add_funcs.rb
          require('sketchup')
          else
            class DCFunctionsV1
              protected
              unless DCFunctionsV1.method_defined?(;XXXXXX)
                # Usage; =ABC123
                def (we give this definition a unique name)
                  return XXXXXX (my own unique formula)
              end#unless
              protected;ABC123
            end#class
          end#if
          module ABC
          module ABC123
          codes to be in the name space
          end #ABC123
          end #ABC
          • michaelwhksgM
            michaelwhksg
            Hi Dan,
            Thanks for the feedback.
            1. Have already edited the previous posts with the code tags.
            2. Have changed the example slightly (removal of the name atan2).
            3. Will use my unique name for the formula in the DCFunctionsV1 class.
            Will try to submit the extension after I clean up my code.
            Thanks.
            • michaelwhksgM
              michaelwhksg
              Hi TIG, Dan,
              Is there any resources online that shows how we can input the licensing code to our script? The below web link automatically directed me to another webpage instead of the licensing tutorial.
              http://www.sketchup.com/intl/en/developer/docs/tutorial_licensing
              • Dan RathbunD
                Dan Rathbun
                The licensing tutorial was removed pending an overhaul. No amount of asking has resulted in any estimation of when the tutorial will be edited and reposted.
                Julia Christina Eneroth has posted her own licensing tutorial with test code at GitHub:
                https://github.com/Eneroth3/Sketchup-Api-Licensing-Test
                • Dan RathbunD
                  Dan Rathbun
                  There is a problem with licensing. You will likely NOT pass the extension review if you alter the DCFunctionsV1 class in your extension code.
                    This has been discussed in a circle !
                    I said earlier that any code which was altering a 'built-in' class [like the DC's] was like to fall foul of the EW checkers, and of course [thereby] its licensing regime...
                    It would be possible to write a 'non-compliant' extension which did change the DC's class and publish it BUT it can't be downloaded through the EW [there are many other options] - and if it's to be licensed it'll have to be done through another licensing system [again there are several others]...
                    It is somewhat perverse that SketchUp freely distributes its DC tools, but then does not allow any additions to be made to that code - even with the strictest trapping to avoid overwriting new methods or clashing with other authors - it seems to make the DCs something of an evolutionary dead-end...
                    • Dan RathbunD
                      Dan Rathbun
                      (TIG, I know you said this, but apparently the OP didn't understand it well.)
                      I would prefer that Trimble updates the DC code to add all those missing math functions that Scott did not implement, (... perhaps because Google Docs Spreadsheets did not support them at that time ?)
                      And then I'd like them to be serious about implementing nifty new DC Functions that users request, in a timely manner !
                      • michaelwhksgM
                        michaelwhksg
                        Thanks, Dan. Will take a look at Julia's tutorial.
                        I do agree that some improvements can be made to the DC functionalities. This will definitely benefit a lot of users.
                        • michaelwhksgM
                          michaelwhksg
                          Just an update to everyone.
                          After a few rounds of re-submission of my extension to meet the stringent requirements, this time, it is taking slightly longer than usual. I am still waiting for the status of being published in the Extended Warehouse.
                          In any case, below are some of the screenshots I have created for the extension.
                          • michaelwhksgM
                            michaelwhksg
                            Hi, does anyone know how long it takes to get an extension approved by the Extension Warehouse Team normally?
                            After a few rounds of back and forth and updating the extension, I submitted the extension again on 29May. Aside from getting the one auto-response, I did not hear anything else.
                            I then resubmitted again on 13June. Still no change in the status.
                            Any advice on this?
                            • Dan RathbunD
                              Dan Rathbun
                              They have been known to be slow. Perhaps it's the summer vacation season ?
                              • michaelwhksgM
                                michaelwhksg
                                Oh I see. Thanks a lot Dan. Will wait for the feedback from them then.
                                • michaelwhksgM
                                  michaelwhksg
                                  Hi TIG and Dan, good news. My extension is being approved by the EWH team and the trial version is now in the Extension Store.
                                  ERROR: The request could not be satisfied
                                  (extensions.sketchup.com)
                                  Like you mentioned previously, the EWH team initially rejected the idea of having the DCFunctionsV1 approach. After I explained the rationale of using it, they finally gave the approval.
                                  Seems like there's light at the end of the tunnel.
                                  Thanks.
                                  My next challenge will be the licensing issue.
                                  I went thru Julia Christina Eneroth's tutorial, but still have some questions. For example, in the code, ext_id = "15dfa30f-4957-4549-8cdb-e97b5727a13a", I am unsure how this comes about.
                                  Anyway, one way I circumvent this is to have the trial version in the Extension Store and the full version in my website (still fixing up the shopping cart in my website though).
                                  Thank for the guidance. You guys rock!
                                    A miracle for common-sense - well done !
                                    • Dan RathbunD
                                      Dan Rathbun
                                      Please start a new topic, or find one that is already on this subject.
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Remember I said this ?
                                        I really hope you used a unique function name and not atan2 as you had previously defined it early on.
                                        • michaelwhksgM
                                          michaelwhksg
                                          Will look into the licensing aspect in the forum, Dan.
                                          Yes, you are right. I have used a unique function name for my extension. atan2 is just an example.
                                          By the way, I have sort of documented the steps I took to create the DC extension and have it published in the Extension Warehouse.
                                          Just to share with anyone who is interested. It is actually for my own reference in future.
                                          Creation of extension and submission to Extension Warehouse
                                          • michaelwhksgM
                                            michaelwhksg
                                            A proposed layout for a new site that shows the pallet racking, with a dedicated mezzanine on the left and conveyor system for segregating the inventory via dispatch routes.
                                            3D Warehouse Layout Visualization | WarehouseBlueprint
                                            WarehouseBlueprint - Explanation with clarity Difficulty in visualizing a new warehouse racking layout in 2 dimensions (e.g. CAD drawings)? Having issues explaining to clients the proposed warehouse layout changes? WarehouseBlueprint software has a solution to your problems. With the ability to draw in 3D, you will be able to help your client understand the layout
                                            WarehouseBlueprint | Warehouse Visualization Made Simple (warehouseblueprint.com)
                                            Warehouse Layout
                                            Warehouse Layout - Rendered
                                            • 2 / 2
