    3D Truss Models
    1.5k Posts 32 Posters 1.9m Views 31 Watching
    • facerF
      facer
      Chinese users will love this version πŸ˜„
      Version 1.8.8 - 04.28.2017
      • pbacotP
        Looks wonderful!
        • medeekM
          medeek
          Version 1.8.9 - 05.01.2017
          • Added energy/raised heels for triple fink truss (3 variant: wedge, slider and vertical w/ strut).
          • Metal plate connectors now enabled for triple fink trusses.
          http://design.medeek.com/resources/images/truss_su215_800.jpg
          Nathaniel P. Wilkerson PE
          Medeek Engineering Inc
          design.medeek.com
          • jujuJ
            juju
            What are the chances of you doing a version of this that does steel trusses? Not really useful for residential, but for industrial / commercial it would be useful.
            • pbacotP
              While I myself most likely would not model rebar or even studs, the quick generation of a visually complete house model (no innards) is very desirable and this last house model looks great. Just that visual shell would be my preference. Emphasis on exterior views, and possibly a foundation model that can be viewed by the design and construction team. Maybe some ability for some interior shots, sun study, fly-through, or top-down (Minus roof) view of rooms. Still the framing is very impressive and looks wonderful!
              • pbacotP
                I assume standard finishes are included in the plugins? You might add standard trim such as dimensional corner trim frieze boards and water tables. Just what's needed for a start-- the user can model special trim for themselves.
                • medeekM
                  medeek
                  So many possibilities and so little time.
                  I've now extended my list of plugins that I would like to create or am currently creating to:
                  1.) Truss Plugin (roofs and floors)
                  2.) Foundation Plugin (stem, sog, slab, spread ftg.)
                  3.) Wall Plugin (stud walls)
                  4.) Stairway Plugin (wood, concrete and steel stairways)
                  5.) Structural Plugin (calculation of beams, footings, posts, shearwalls etc...)
                  6.) Reinforced Concrete Plugin (RC columns, beams, retaining walls, piles, mat foundations, spread footings, etc...
                  7.) Steel Framing Plugin (cold formed steel framing, steel wide flange beams and posts, steel trusses, NUCOR steel buildings)
                  8.) Deck Plugin (residential wood decks, balconies, stairs, footings)
                  9.) Window and Door Plugin (windows, doors, OH Doors, Garage Doors, interior doors)
                  The window and door plugin will probably be part of the wall plugin, but I might also make it a separate standalone plugin if users want that.
                  design.medeek.com
                  • medeekM
                    medeek
                    Fun with Roofs - Episode 1
                    My 9 year old son took one look at this roof and then said "Don't build this in Florida, you'll create a sink hole".
                    http://design.medeek.com/resources/images/truss_su210_800.jpg
                    http://design.medeek.com/resources/images/truss_su212_800.jpg
                    http://design.medeek.com/resources/images/truss_su211_800.jpg
                    http://design.medeek.com/resources/images/truss_su213_800.jpg
                    http://design.medeek.com/resources/images/truss_su214_800.jpg
                    http://design.medeek.com/resources/images/truss_su216_800.jpg
                    http://design.medeek.com/resources/images/truss_su217_800.jpg
                    http://design.medeek.com/resources/images/truss_su218_800.jpg
                    View model here:
                    3D Warehouse
                    (3dwarehouse.sketchup.com)
                    design.medeek.com
                    • medeekM
                      medeek
                      I'm trying to figure out the correct way to frame the stairwell as it joins up with the floor diaphragm above.
                      http://design.medeek.com/resources/images/truss_su220_800.jpg
                      It's hard to show exactly what I mean with sectional views, the best thing is to view the 3D model and you will see what I am talking about.
                      3D Warehouse
                      I am working on the polygon and hole tool for I-Joist and Solid Sawn floors. When you actually frame out this opening would you just use rimboard around the perimeter as I have shown?
                      design.medeek.com
                      • pbacotP
                        A note on the Bobtail truss. For me the height of the heel seems the first obvious important dimension, because the bobtail is used both sides to maintain an exterior wall height while lowering the standard ceiling height. At least this is how we used it recently. The other method seems tied to where the ridge is and the asymmetrical use is not normal or traditional.
                        • pbacotP
                          On the stairs you can do that as a vanilla framing solution. More important will eventually be how the stairs are supported. Often there's a beam at floor level that the stringers are hung on. In other cases the stringers are just bearing on a wall or beam below. The stringer structure is deeper than you show it. That is, stair support at the top varies, but this seems good for a start. What else were you considering? You might allow for double joists where it makes sense-- some standard framing method for any hole in the floor.
                          • pbacotP
                            Nice model! The textures and detail make it a clear representation.
                            • medeekM
                              medeek
                              I've got to fix my wife's computer today so that will probably stop me from getting any real meaningful work done on the plugins but at least I've been able to throw together a first draft for the office I want to build. Any thoughts on improving the design, sometimes once you get an idea in your head it is hard to see outside the box.
                              http://design.medeek.com/resources/images/MEDEEK_OFFICE4.jpg
                              http://design.medeek.com/resources/images/MEDEEK_OFFICE3.jpg
                              http://design.medeek.com/resources/images/MEDEEK_OFFICE2.jpg
                              http://design.medeek.com/resources/images/MEDEEK_OFFICE1.jpg
                              http://design.medeek.com/resources/images/MEDEEK_OFFICE5.jpg
                              I haven't shown the doors or the front porch which will probably be quite small and pressure treated lumber.
                              • 32'x24'
                              • 5:12 or 6:12 roof with asphalt shingles
                              • two rooms
                              • 9' ceilings
                              • stemwall foundation with crawlspace
                              • carpet throughout
                              • 5/8" wallboard
                              • 3068 doors, (1) 4040XO, (3) 5040XO
                              • 11-7/8" I-Joists at 16" o/c
                              • studs DF No. 2, 2x6 @ 16" o/c
                              • sheathing will probably be 1/2" plywood, I don't like OSB in our climate.
                              • Siding Hardiplank or cedar siding, my budget may call for T11 though.
                              • Electric wall cadet heaters
                              • 50 AMP sub-panel from house
                              • 16" overhangs at eaves and gables with gutters and downspouts and 4" drain lines away from building.
                              design.medeek.com
                              • medeekM
                                medeek
                                Finally getting around to adding the flat trusses:
                                http://design.medeek.com/resources/images/truss_su105_800.jpg
                                I've decided to also provide the option for a monoslope and pitched design. Advanced options won't be for a while yet. I'm still not entirely sure how to handle the gable end trusses for this truss type, what is typical?
                                design.medeek.com
                                • medeekM
                                  medeek
                                  All the end details are working. This is an example of a Mansard Parapet truss with 5 panels and different overhangs:
                                  http://design.medeek.com/resources/images/truss_su221_800.jpg
                                  Now I just need to work on the plates and advanced options.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    I'm still working on the pitched and monoslope option. I will probably release this update without having the advanced options and plates enabled since those items are nice but not a necessity and can be added at a later date.
                                    The next two big items that I would like to tackle is the hip trusses and the timber trusses both of these would be a welcome addition to the plugin.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 1.9.0 - 05.27.2017
                                      • Added flat truss type, configurations: flat, monopitch, pitched.
                                      • Metric input enabled for flat truss types.
                                      • Added gable end trusses for flat truss types.
                                      • Enabled the following end details for all flat truss types: None, Overhang, Cantilever, Mansard, Parapet, Mansard w/ Parapet.
                                      http://design.medeek.com/resources/images/truss_su223_800.jpg
                                      Plates and advanced options are still in progress. With the amount of configurations available with this truss type it will probably be a while before these next elements are in place.
                                      The flat truss type is very configurable and with a little adjustment of parameters you can also easily create a (non-attic) gambrel truss using the flat pitched option.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Here is an example of a small commercial building with a flat truss roof (parapet):
                                        http://design.medeek.com/resources/images/truss_su224_800.jpg
                                        Download model here:
                                        3D Warehouse
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          The flat truss is the first new truss type added to the plugin in 11 months. This brings the total number of truss types to approximately twenty two depending on how you classify the variants of the flat truss:
                                          http://design.medeek.com/resources/images/truss_su225_800.jpg
                                          View model here:
                                          3D Warehouse
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            The flat double pitched truss allows for a user driven asymmetric ridge location as well as differing left and right heel heights. This opens up virtually any possible truss geometry even a negative pitch if one is so inclined:
                                            http://design.medeek.com/resources/images/truss_su226_800.jpg
                                            http://design.medeek.com/resources/images/truss_su227_800.jpg
                                            design.medeek.com
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 76
                                            • 77
                                            • 35 / 77
