    Creating a plaid on a chair - cloth simulator?
    76 Posts 19 Posters 19.7k Views 19 Watching
    • PixeroP Offline
      Pixero
      Do what ever is easiest for you development wise.
      A cloth simulator would be awesome.
      Making it work with Thomthoms subD would be prefered.
      Don't think too long.
      Just do it! πŸ‘ πŸ˜„
      • soloS Offline
        I'm still trying to decide whether to include it in the upcoming release of MSPhysics or write a new plugin that will specifically focus on soft body simulations.
        I vote for a stand alone cloth simulator, great work by the way.
        • F Offline
          faust07
          Great examples in your video, Anton! And it seams to work in MSPhysics.
          A simple variant for MSPhysics would also be welcome.
          This would make moving objects made of flexible materials more natural.
          The problem of interpenetration of the partial surfaces could be solved temporarily with larger hidden body parts.
          • jujuJ Offline
            juju
            Definitely a separate cloth simulator, pretty please!
              Anton_S
              Thank you all for your suggestions! Now suggestions for the name of the plugin and some upfront ideas would be great.
              Right now I'm thinking of naming it, SoftWorks.
              The plugin will have a UI for controlling the selected deformable groups' mass, stiffness and linear/angular acceleration/damper.
              There will also be a toolbar.
              One toolbar button will allow dropping/simulating the selected or all the deformable bodies until a stop button is pressed, which will freeze​ all/selected in place.
              Another button will allow resetting the original placement of all/selected bodies.
              And another button will allow toggling the UI.
              Another two will allow adding Fixed and Slider constraints in places. The touching cloth will automatically will be connected to the constraints.
              As for the back ground, all other non-ignored visible groups/components will act as static/movable solid bodies.
              There will also be options for exporting animations.
              These are the ideas for now. Suggestions that will guide me in the right way would be nice.
              • soloS Offline
                'Softworks' works for me, now shut up and take my money already. πŸ’š
                • F Offline
                  faust07
                  There are several firms in the world with the name "Softworks"...
                  Regarding the functions of the plugin you are on the right way.
                  It sounds like a little bit of a baby of MSPhysics outside of the physics world.
                  Please don't forget the mother... πŸ˜‰
                    Jorgensen
                    Hi Anton
                    I think you should think in search therms / what it does - use words that people search for - i searched for "cloth simulator", so that would be my suggestion (even though is does more).
                    Will I be possible to pick the cloth itself - and deform it?
                    Can you talk about an estimated development time? Like one week or two months?
                    (I know it can be difficult talking about that).
                    Jorgensen
                    • PixeroP Offline
                      Pixero
                      It would be cool if it could have a virtual thickness setting for simulating thicker stuff.
                      And maybe a setting so that it could use let's say every other or third vertices of a dense mesh to speed up simulation.
                      My only name suggestion so far are Draper or ClothWorks.
                        measuredmove
                        Just a quick Thesaurus search on the word Drape - Cloak, Swathe, Shroud, Veil
                        My 3D Catalogue
                        https://3dwarehouse.sketchup.com/collection/103ed44c-a0c4-4049-9a84-89cd017bcc07/Measured-Move
                        SU8/Brighter3D/Gimp/SimLab Composer
                          Anton_S
                          Solo, good idea! lol
                          Pixero, ClothWorks sounds nice and actually very accurate. Even though it will also allow simulating soft bodies, such as the torus, the collisions acts as if cloth is wrapped around it. The name is also more informal about what the plugin does, which should also attract more users.
                          Jorgensen, it should take 1-3 months to get the first version released. Everything should be easy because most of it is integrating the features of MSPhysics, the other thing is getting a licence system like in Thomthoms SUdb. That, I will need to do more research on.
                          Faust, I will never forget MSPhysics. I will always work on it. In fact ClothWorks with its simplicity, will allow experienced users to get a grip of how MSPhysics works and transition to it MSPhysics for more possibilities.
                            Jorgensen
                            SSS - Soft Surface Simulator
                            • BoxB Offline
                              Soft drape.
                              As a stand alone plugin, reasonable price, easy sale.
                                cuttingedge
                                Something to do with the word "drape" would be apt for its intended use. If there was no drape in the Sandbox tools already--It can be called just DRAPE (IMO). Cloth could be limited to cloth materials.. .
                                Maybe also fibreworks.. just a thought.
                                But if we intend to create clothing (like marvelous Designer). Then CLOTH plugin should give everybody a good clue of what it's for.
                                I am loving this developments.. getting excited again about SU!!
                                • N Offline
                                  nlipovac
                                  Maybe SuSoft as Sous chef to MSPhysics.
                                  Anyhow, when can we expect it!? πŸ˜„
                                  • filibisF Offline
                                    filibis
                                    Why on earth noone attempted to create such feature before? πŸ˜„
                                    Anyways it's great to see this plugin taking shape.
                                    I suggest using "Soft-body" phrase in the name since it's kind of a universal term: https://en.wikipedia.org/wiki/Soft-body_dynamics
                                    "Soft-body Simulator" maybe?
                                    "**SoftWorks"**and "ClothWorks" are quite reasonable though.
                                      measuredmove
                                      DropCloth or Drop-n-Drape
                                      My 3D Catalogue
                                      • jujuJ Offline
                                        juju
                                        please be able to make curtains as well...
                                          Jorgensen
                                          @anton_s
                                          just curious - are you working on this plugin / feature? πŸ˜„
                                          thanks
                                          jorgensen
                                            Anton_S
                                            Jorgensen, I haven't started yet. Once I finish with MSPhysics v1.0.0, I will transition to writing this plugin. It will take a lot less time to write as lots of physics engine code snippets will be used from MSPhysics.
                                            • 2 / 4
