    [SOLVED] Help needed for old plugin migration sketchup 2017
    7 Posts 4 Posters 892 Views 4 Watching
      MrWip
      Hi everyone.
      Testing Sketchup 2017, I'm trying to recreate my previous workflow, but I'm struggling with some plugin, not behaving has they were in 2016, so maybe some of you may have advises on how to handle this issues.
      • JOINT PUSH PULL [FREDO]:
      I was working until now with the old jointpushpull (not the latest Fredo6_Jointpushpull), because the way the tool behave was far more natural and sketchup like before (click to initiate /move freely /click to confirm. In the latest version, you have to maintain the click while moving which is a lot less precise).
      So, the old version was fine until now, but not anymore, in sketchup 2017. Is there a way to modify the old version so it is ok for 2017, or to change the behavior of the tool in the latest version ?
      • EXTRUDE LINE , VECTOR BY 2 POINT [TIG]
      I'm using a lot this modify version of an old Didier Bur tool, that allow to extrude edges by a vector. The issue is, that in sketchup 2017 it does not create faces anymore, it just offset the line. Does anyone know this issue, or an other tool to do the same thing ?
      http://www.wip-archi.com
        Reload all your plugins from the PuginStore!
        Because they are all Updated for the 2017!
          Get new versions from the PluginStore... wherever possible...
          I think Fredo's toolsets have now all been updated in the PluginStore [remember to get the LibFredo...]
          Unfortunately my Extrude toolset set has had some issues with the v2017 changes.
          I am still rewriting code to address those... off-hand I can't recall if the 'vector' tool was affected - about 50% of the tools had/have issues...
          You can still install it and use it with the Ruby Console open... and see what errors if any occur...
          If it breaks you know I haven't fixed it yet 😉
            MrWip
            Thank you for the answer, but I actually reload them from the plugin store from the beginning, sadly.
            For the fredo Tool, the issue is quite Old. For some reason, He decided to change the way his tool behave, quite some time ago, and I frankly don't understand why, as I think it's way less easy to use it the way it is now. Maybe he will be able to explain it, if he see this post.
              Best is keep some old versions of SU ! 😉
                db11
                He must have seen it: an update of Joint Push Pull Classic has just been released to the Sketchucation Plugin Store 😄
                https://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=6708%26amp;start=330
                  MrWip
                  Thank You db11, I forgot to post back here, but I talked in PM with both TIG and Fredo, and they really kindly provide Fixes for the plugins.
