    Vray 2.0 Sketchup 2015 Material Render Problem.
    renderpluginsextensions
    1 Posts 1 Posters 956 Views 1 Watching
      rkelly2941992
      **Hi Guys,
      Wondering if you could help with the following problem. I have a material (concrete texture) that i made from a JPEG image in sketchup, I then applied texture mapping to it with vray material editor. When I render the scene, the desired result for said material appears in some areas but not in others.
      I dont understand why this is happening as I have applied the same texture to the blank area in sketchup so should achieve the exact same result all around.
      Any help on this would be greatly appreciated.
      Please see attached image.
      Many thanks!
      Ru**
