    Extension manager woes
    9 Posts 7 Posters 1.4k Views 7 Watching
    • PixeroP Offline
      Pixero
      I'm having some problems when trying to update a plugin through Extension Manager.
      I get a "Failed to update SketchUV. Unable to read extension archive."
      I've been having problems with some other extensions as well.
      I also tried updating them through the Sketchucation Extension Store and that seem to work but the nag from Extension manager keeps poping up when ever I start SU. I have the loading policy setting set to "Unrestricted."
      Is there a way of disabling that nag Popup or is there a way of making these problem extensions install?
      • BoxB Offline
        I think, from memory when it did this to me, you just need to sign out and back in to re-establish the direct link to the EW.
        • bazB Offline
          baz
          Had same issue. Did as Box suggested. All good.
          • PixeroP Offline
            Pixero
            Just tried logging out and in again twice but that did not work.
            Same problem.
            Any other ideas?
            • jujuJ Offline
              juju
              Same problem.
              Any other ideas?
              Did you log out of EW in SU, close SU, restart SU, log back in to EW in SU?
              I used to get the error message with more than one extension and the advice worked fine.
              • PixeroP Offline
                Pixero
                Tried again and restarted SU but after login it's still the same problem. 😞
                This is with SU 2017 on Windows 7.
                Would I need to also log out from SU 2016 and also my from web browser?
                • Rich O BrienR Online
                  I've been locked out from EW and 3DW for months from within SU.
                  I'm logged in but the buttons do nothing.
                  I just use web browser.
                  • duanekempD Offline
                    duanekemp
                    Another SketchUp user (confirmed to have the same issue) and myself are running into the exact same problem.
                    SketchUV Fails to update and continues to be "Unsigned" in both win 7 and win 10.
                    Pixero, did any solution work for you or is it still hanging today?
                    Duane Kemp
                    Kemp Productions
                    Puidoux, Switzerland
                    Gallery:
                    https://duanekemp.artstation.com/
                      KatyaKean
                      Here's the fix, complete with pictures! I tested this with a half dozen people and it worked every time.
                      Fix for Extension Update Error 20171102
                      How to fix the “failed to update” error in the Extension Manager on the “Manage” tab. -------------------- First, try just signing out and back in again. You can do so in the top right corner of the Extension Manager in 2018, and in the top right corner of the main SketchUp window in 2019). ...
                      Google Docs (docs.google.com)
