    [Plugin] Animatex v1.0.6
    38 Posts 13 Posters 32.4k Views 13 Watching
      What screen recorder are you used for the videos?
      • renderizaR Offline
        renderiza
        I used Active Presenter which is free.
        404 Not Found
        (atomisystems.com)
        I also use Frapswhich only captures viewport and ignores things like cursor, toolbars and so on. This screen capturing software reduce lag and preserve frame rate really well but its not free.
        http://www.fraps.com/
        Cheers!
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          thx for the infos! πŸ€“
            Pic Assaut
            Realy Great plugin i think that the last version'll be one of the best tools for Designers
              renderiza
              Animatex is now available at Extension Warehouse!
              http://extensions.sketchup.com/en/content/animatex
              Cheers!
                renderiza
                When I was using Animatex inside SketchUp there was no lag but I guess 'ActivePresenter' screen capturing software produced some lag in the video output. If you want to screen capture without lag output then I recommend using 'Fraps'.
                  renderiza
                  New Video:: (Part 2)
                  • O Offline
                    onlyadwait
                    I installed the plugin but it is not animating... I followed all the instructions... also tried different values, components/groups/ just planes... still it is not animating.. does this require any other supporting plugin to work.?
                      renderiza
                      Did you add face to 'Animatex layer' by selecting the face and clicking the green button under layer in web-dialog? If the face is inside a group you need to enter that group and select the face before pressing add 'Animatex Layer'.
                      Also just in case download latest internet explorer and check if plugin folder have full rights. Let me know if problem persist.
                      thanks for feedback! πŸ‘
                      • duanekempD Offline
                        duanekemp
                        Is this plugin no longer supported in new versions of SU?
                        Duane Kemp
                        Kemp Productions
                        Puidoux, Switzerland
                        Gallery:
                        https://duanekemp.artstation.com/
                          damnboomer
                          Hello, the plugin is not available on plugin warehouse. It's possible to send me the plugin by email ?
                          • jujuJ Offline
                            juju
                            It is available on the Sketchucation PluginStore, just go get it there...
                            • 2 / 2
