    A Jeweler's Workbench
    11 Posts 7 Posters 2.5k Views 7 Watching
      Based on one dated to about 1900. I drew it for a tutorial on cutting the stopped chamfers.
      • cottyC Offline
        cotty
        πŸ‘
        my SketchUp gallery
        • bazB Offline
          baz
          @dave r said:
          [attachment=0:2wmfo4zu]<!-- ia0 -->Jewelers bench.png<!-- ia0 -->[/attachment:2wmfo4zu]
          In FWW?
          • ntxdaveN Offline
            ntxdave
            Dave I always enjoy your posts. I just wish I could come up with stuff like this.
            Press F1...thank me later
              @baz said:
              In FWW?
              Eventually it'll be published as a blog post there.
              Thanks. I just troll the web for likely pieces of furniture. I might have passed on this one except I had done an online training session with a fellow who wanted to know how to make stopped chamfers. I thought it would be a good topic for a blog post and with all the chamfers, it gave me an opportunity to show a few different options.
              • ntxdaveN Offline
                ntxdave
                I need to get beyond my car wash equipment. πŸ˜’
                  Maybe so. After all, how many different ways can you arrange carwash machines? πŸ˜„
                  • tuna1957T Offline
                    tuna1957
                    Most excellent , as always πŸ‘ . Really like your line style and wood texture in this one. Another home run.
                      mwm5053
                      Nice one Dave, interesting flutes on the legs and stretchers. I wonder how you would do that in the shop. I have an idea that would require some work with a chisel.
                      2011 iMac
                      SU 2015 Pro, 2017 Make
                      V2 Twilight
                      macOS Sierra 10.12.5
                        Thanks Mr. Fish. πŸ˜‰
                        Walt, I'm sure a little chisel work would be needed at the ends. I expect you could take most of the waste off with a router. It wouldn't be difficult to build a jig that would make it easy with a router. I have an idea for an even simpler setup for the Router Boss but you'd need to have the Router Boss first. πŸ˜‰
                        With a little modification, this bench would make a nice student desk for someone who doesn't want one made of termite poop.
                          slbaumgartner
                          Except that there appears to be a little step where the chamfer meets the ends, you could build a sort of sled that holds the leg at 45 degrees and run it past an ordinary rabbet bit. If that step is there you'd have to stop a bit short of the end, move over a bit for the step, do the end, and then clean up the little step with a chisel.
