    Landscaping masks
    layout
    13 Posts 4 Posters 4.2k Views 4 Watching
    • bazB
      baz
      Edit, hang on, that doesnt work, needs transparency of course, duh.
      Will have another think...
      Thought I would have a go at this.
      Drawn in SU, saved as scrapbook file in layout.
      Filled and unfilled version.
      You can change the line weights and apply sketchy styles. And of course they are vector.
      I would be happy to knock some of these out if you are interested.
      Tree-One.layout
      • bazB
        baz
        Here is a PNG with transparency, same as your method.
        Might have a go a la Richard in Layout...
        • bazB
          baz
          Got it. This is SU and Layout only.
          Drawn in SU, Vector model exploded and ungrouped down to single entities.Then regrouped.
          At this stage you can change the line weights, fill etc.
          Warning, once you have any stage of the Layout file as you want it, save it. Layout seems to be a bit twitchy with this operation and you might have to revert.
          Tree-One-Explode.layout
          • pbacotP
            I've tried to explode a SU reference. Grayed out. How is this process done (how did you get put it in LO etc.)?
            • bazB
              baz
              Insert model in LO or send to LO from SU.
              Check Vector is on.
              Right click model window/Explode/Ungroup/
              And depending on how far you drill down you are then left with a bunch of vector entities which can be manipulated with LO tools.
              • pbacotP
                Vector! No wonder!
                • pbacotP
                  So one can import all sorts of drawings from CAD for this sort of thing. Thanks,
                  • N
                    nujak66
                    Baz,
                    You are great! I didn't even think of drawing in sketchup first, then converting to vector in layout! Genius! Thank you! Much better than my png version. I'm glad I didn't spend too much time building a library of .png. I'm going to go at a scrapbook library your way in Layout.
                    Cheers!
                    • bazB
                      baz
                      @nujak66 said:
                      Baz,
                      Cheers!
                      Good,thanks. Show us a few examples when you have some...
                      • RichardR
                        Richard
                        Richard should probably tune in here! There are a ton of DWG tree files of this type all over the internet. Download > drag into SU > compile > drag SU file to LayOut page > vector > explode > ungroup > you may need to run the join tool around > set outline and fill > save as scrapbook.
                        Be mindful you can have some really heavy geome'tree πŸ˜„ in Layout as a result!
                        The beauty is that you have both, a nice set of trees that match for use in both SU and LO.
                        BUILTBRAND.COM.AU
