    How to? 4000+ colors into custom materials library
    7 Posts 6 Posters 4.2k Views 6 Watching
      akalorik
      Hi all! I have to get 4000+ colors into a Sketchup file to create a custom colors library - similar to the ones that Sherwin Williams provides. Any suggestions for doing this in a fast and efficient manner? In other programs (such as several by Adobe) I was able to write a simple script to pull the colors in from a spreadsheet with the color names and RGB values. Any suggestions would be greatly appreciated ๐Ÿ˜„
      • Bob JamesB Offline
        Bob James
        http://rhin.crai.archi.fr/rld/plugin_details.php?id=241
        massmaterialimporter.rb by Adam Beazley, tweaked by TIG
        Makes materials from image files in a folder... each named after the image-file and using that image as its texture...
          driven
          a skm file for a color just a zipped set of xml's and a thumbnail...
          it's easy to write your own with a script that get it's info from a spread sheet...
          I modified php one for converting all the Pantone colors, before I found it had already been done...
          4000 colors will still take some time and create a very large Library...
          i.e. for Pantone skm's with preview images on a mac...
          40,072,902 bytes (44 MB on disk) for 1,348 items
            lhs_cummings
            I'm trying to do the same thing but import a couple of dozen Pantone colors pulled from an illustrator file into a Sketchup model. I would like to keep the names the same too. It seems that there should be a way to convert ASE (Illustrator's swatch file format) into SKM (Sketchup's material library format.) If it's XML you could even do it with a text editor or some Excel voodoo. Other than this thread I haven't found anything.
              Is there any particular reason to reinvent the wheel? Could you extract the colors from an existing Pantone SKM library?
                ssmily32
                But how do you get jpg files from an ase or aco files plz ????
                  A Google search turns up plenty of possibilities. Maybe this will help.
