    Animator: Parametric Animation plugin - Discussion
    223 Posts 55 Posters 116.8k Views 55 Watching
    • fredo6F Offline
      These are ACTION buttons, not STATUS buttons.
      So the red cross is to delete, the green check mark is to undelete, and the red color for the whole row indicates the status.
      If you are better icons however, I am interested.
      • MALAISEM Offline
        MALAISE
        Could such a picture fit the function ?
        • fredo6F Offline
          Very nice icons, but I would (and maybe will when appropriate) use them for MERGE and SPLIT.
          However, if the single rectangle is replaced by a red bin, that would be perfect
          • MALAISEM Offline
            MALAISE
            Like that ?
            Cheers
            Pierre
            • fredo6F Offline
              That's the idea. But then
              • could you replace the 3 parallelograms by one
              • could you make the arrow a little bit bigger and contrasted so that they are visible when the icons are of reduced size (i.e. fitting in the table).
              • MALAISEM Offline
                MALAISE
                Here, you'll find some material.
                Cheers
                Pierre
                  kostas_designer
                  Fredo, this is absolutely marvellous, the best plugin after Fredoscale imho.
                  Just got my hands on, i'll definitely dig more on the next days.
                  Here's a first attempt on a project I'm currently working on:
                  Very, very promising 👍 👍 👍
                  Again, my best congrats to you.
                    kostas_designer
                    This is getting even more interesting... ☀
                      pabloalonso
                      Dear Fredo6. I just discovered Animator and I think I will not be able to sleep in the next few days. It is an essential program and especially for those who use Thea as a rendering engine, for example.
                      I've been watching the tutorials for several hours and practicing. It is possible that the suggestions that I am going to give you are already implemented. If this is the case, I apologize to everyone.
                      First of all, thank you for all your plugins. All are admirable.
                      My suggestions are related to the use of Animator in architecture visualization.
                      • It would be interesting to be able to link the animation and especially the activation / deactivation of layers with MS Project files or other project management programs. These programs indicate times and tasks. If the tasks are linked to objects and layers, the evolution of a construction could be shown. This is called 4D. There are some plug-ins for sketchup that do it but they are expensive and complex. On other platforms, Naviswork would be the benchmark. It is not far-fetched to think that many people who love sketchup have it very easy with Animator to do almost the same thing.
                      • Facilitate the creation of exploded views. For this it would be good to have two utilities:
                      1. Be able to choose a center and the position of the axes that will define the directions of the explosion. Ideal for general movements of complete buildings. Separate the roof, walls and floor, for example.
                      2. To show the assembly of parts, facilitate the movement of screws and nuts indicating the thread pitch and the direction of the shaft. Thus the composition of linear movement and spin would be easier and natural to perform if it comes with an aid by part of Animator.
                      3. Create links between positions of parent objects and child objects so that the movement of some does not begin until a certain position of the others is reached.
                      Thanks for your attention and patience. I'm from Spain and I'm not fluent in english.
                      Pablo
                        jannineFPS
                        Is the scale function working? I can't seem to engage the menu or toggles.
                          jannineFPS
                          Hi there!
                          Learning to use the Animator Plugin, thanks so much for developing this!
                          I'm attempting to scale a group of objects, and cannot seem to accomplish it. When I create a new movement, every tool seems to work except for the scale function. There are no toggles, no special cursors, and no menu as when I do a translation or rotation, for example. I'm allowed to highlight the group and then nothing.
                          Is this operator error? Is is something to do with how the objects are grouped? Everything else I'm doing with my model works just fine except for this.
                          Thanks so much!
                          • fredo6F Offline
                            Unfortunately, Scaling is not yet implemented. This will come however.
                              sarkarshomit
                              Tried my luck with this awesomeness....its a shame had to use keyframe animator for the scaling of the curtains, but rest all is animator magic....thanks fredo.....hoping for a release of the scaling function in animator soon...regards,,
                              Shomit
                              • soloS Offline
                                Shomit
                                That was great, normally I get bored after a few seconds, I watched until the end, awesome way the apartment morphs, loved the curtain also.
                                • ntxdaveN Offline
                                  ntxdave
                                  Shomit
                                  I too would really like to have the scaling function.
                                  I agree with you 100%
                                  Can you imagine that animation with one of the rendering engines. I have been playing with the trial version of Enscape and have thought about how it would be to combine Animator with Enscape.
                                  Press F1...thank me later
                                    sarkarshomit
                                    @solo said:
                                    Shomit
                                    Thanks for the compliments.....and many thanks to fredo also.
                                      sarkarshomit
                                      @ntxdave said:
                                      Shomit
                                      i would really love to know about rendering options for animator.
                                      i know its possible using keyframe animation,
                                      but with animator i guess its only that ambient occlusion thingy which i am not that interested.
                                      Would be great with vray or thea render.
                                      • ntxdaveN Offline
                                        ntxdave
                                        In addition to Ambient Occlusion, you can use both Twilight (Pro version only) and Thea.
                                        [attachment=0:bp425dj6]<!-- ia0 -->Animator Render.PNG<!-- ia0 -->[/attachment:bp425dj6]
                                          sarkarshomit
                                          [attachment=0:2g4uvf8x]<!-- ia0 -->Animator Render.PNG<!-- ia0 -->[/attachment:2g4uvf8x]
                                          Oh wow, i will give it a try soon...thanks
                                          • I Offline
                                            Isarescu
                                            SO you can`t render the animation with V-Ray?
                                            • 11
                                            • 12
                                            • 8 / 12
