    Loxodrome - bug loading
    9 Posts 3 Posters 1.1k Views 3 Watching
      Sl-m
      Hi There,
      While trying to load the loxodrome plugin in skp pro 2017 I have this message:
      Error Loading File rp_loxodrome.rb
      Error: #<SyntaxError: C:/Users/Slim/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/rp_loxodrome.rb:19: invalid multibyte char (UTF-8)
      Any help to sort out the problem would be greatly appreciated.
      Sl!m
      • Rich O BrienR Online
        http://sketchucation.com/forums/viewtopic.php?p=564030#p564030
          glro
          Hi There,
          Sl!m
          "invalid multibyte char (UTF-8)"
          invalid character, it seems, should be easy to fix if there is no other problem
            I think the plugin is scrambled so the author needs to fix or open source it.
              glro
              Hi There,
              Sl!m
              it is a crypted file (rbs)
              no way to fix it, except if you have the source file
              Loxodrome - Free Plugins - Regular Polygon
              This plugin creates a loxodrome (spherical helix, rhumb line) in SketchUp, based on parameters.
              (regular-polygon.com)
                Sl-m
                Sl!m[/quote]
                http://regular-polygon.com/plugins/loxodrome/[/quote]
                Just found I had a rbs version (see below):
                Any easy way to fix?
                Description : A SketchupExtension class for the Loxodrome plugin.
                Date : 5/26/2013
                Email : regular.polygon@gmail.com
                Website : http://regularpolygon.org/
                require 'sketchup.rb'
                require 'extensions.rb'
                extension = SketchupExtension.new 'Loxodrome', 'rp_loxodrome/loxodrome.rbs'
                extension.description = 'Create a Loxodrome component based on parameters entered in a dialog. ' +
                'The menu item is Draw -> Spherical Helix (Loxodrome).'
                extension.version = '1.1'
                extension.creator = 'Regular Polygon'
                extension.copyright = "Regular Polygon © #{Time.now.year}"
                Sketchup.register_extension extension, true # show on 1st install
                  Sl-m
                  Hi Rich,
                  Thanks for your reply.
                  Date : 5/26/2013
                    Email Doug and see if he'll fix it.
                      Sl-m
                      I did, looking forward to his reply.
                      Cheers
                      Sl!m
