Resize model.
I often import a graphic of a floorplan from a client or forum member. I find a long measurement and measure it using the measure tool - I then type the actual measurement into the lower right input window and it asks me if I'd like to resize the model, I say yes and it resizes the graphic so all measurements are to that new scale.
It now creates a guideline along the axis of the measurement.
Why has this feature disappeared in version 2017, it's a very important feature I use regularly.
Works fine for me, p'raps try a repair/reinstall?
Or load the model, see if it works for others? -
It's ok - found the solution - hold control and measure/resize works ok.
Don't hold ctrl, just tap it, it is a toggle. Guide on guide off,you'll even see the little guide line symbol disappear and reappear.
For some unknown reason they reversed the default in 2017. -
For some unknown reason they reversed the default in 2017.Damn, never noticed that. The toggle on seems to be the default on my puter. Never needed a reason to toggle off.
