    Resize model.
    5 Posts 3 Posters 374 Views 3 Watching
    • John SayersJ Offline
      John Sayers
      I often import a graphic of a floorplan from a client or forum member. I find a long measurement and measure it using the measure tool - I then type the actual measurement into the lower right input window and it asks me if I'd like to resize the model, I say yes and it resizes the graphic so all measurements are to that new scale.
      It now creates a guideline along the axis of the measurement.
      Why has this feature disappeared in version 2017, it's a very important feature I use regularly.
      • bazB Offline
        baz
        Works fine for me, p'raps try a repair/reinstall?
        Or load the model, see if it works for others?
          John Sayers
          It's ok - found the solution - hold control and measure/resize works ok.
          • BoxB Offline
            Don't hold ctrl, just tap it, it is a toggle. Guide on guide off,you'll even see the little guide line symbol disappear and reappear.
            For some unknown reason they reversed the default in 2017.
            • bazB Offline
              baz
              Damn, never noticed that. The toggle on seems to be the default on my puter. Never needed a reason to toggle off.
