    Useful MAC Apps and Hardware [Ongoing Updates]
    288 Posts 34 Posters 238.4k Views 34 Watching
    • Mike LuceyM
      Mike Lucey
      @pbacot said:
      IDK about ethernet and card slots, neither of which I expect to use in the future, but did they eliminate USB and HDMI too? Crazy
      Yep, they did! I agree its crazy. But its creating some business opportunities for others. I've just noticed the 'HyperDrive' on Kickstarter.
      HyperDrive Thunderbolt 3 USB-C Hub for 2016 MacBook Pro
      https://www.kickstarter.com/projects/hypershop/hyperdrivetm-compact-thunderbolt-3-usb-c-hub-for-m?ref=nav_search
      One of these plugged into both sides of the new MBP would be an improvement over the current port arrangement on the last generation MBP but it looks like they only have a left side unit.
        slbaumgartner
        The second adapter Mike showed is to my mind just a variety of dongle. I don't like dongles because they are always at risk of getting flexed and breaking either the dongle or the port on the computer.
        The photos Mike posted earlier answer one question I had about that "below decks dock", namely how does it connect. In the left image you can see a little, thin sort of flap connector going up from the dock to the USB-C port on the side of the MBP. This idea seems to me better, since battery life is one of the biggest things going to pot in Apple's relentless drive to make devices as thin as a sheet of paper. That leaves two other questions: how does it fasten to the bottom of the MBP, and how does it affect heat dissipation through the bottom (as anyone who actually uses a MBP on their lap can tell you, the bottom can get quite warm!). I guess we'll see after they are readily available on the market.
        What I would really like is for Apple to "future proof" the MBP by providing some kind of system bus connector through the bottom by which users could add things such as more RAM, a different graphics adapter, bigger battery, etc. - things that are not upgradable because they are all soldered down. My cynical side says that they may avoid such a port because it would eat into their lucrative sales of new models, though those sales are sagging on their own anyway...
        • Mike LuceyM
          Mike Lucey
          @slbaumgartner
          I agree about the DEC. I would like to learn a lot more about 'whats in the box'.
          Working with the MBP on the lap can get uncomfortable. I recently picked up a Belkin CoolSpot Cushion Laptop Cooling Pad on Amazon and its doing the job of keeping things cool for me and the MBP.
          • pbacotP
            Thx!
            • pbacotP
              [attachment=0:1zrxkzb2]<!-- ia0 -->HyperDrive Thunderbolt 3 USB-C Hub for 2016 MacBook Pro.jpg<!-- ia0 -->[/attachment:1zrxkzb2]
              But hey that covers up the power port doesn't it?
                slbaumgartner
                There's another USB-C on the other side of the MBP. You'd have to use that for power. There is no single-purpose power port any more.
                This is another reason why I think Apple went too far in their quest for paper-thinness in this latest MBP. They seem to have lost track of the things that matter to the heavy-duty Mac user vs the general public. Yeah, it's nice when a laptop is as thin and light as possible, but not when I have to sacrifice connectivity and carry around a mess of adapters!
                Edit: I missed the point that you were commenting on what happens if you connect dongles to both sides.
                • soloS
                  Guess the balance of form and function is off.
                  • pbacotP
                    I still have an older MBP Two USB, Two Thunderbolt HDMI, SD Card reader, headphone jack, separate power jack.
                    I don't know of any reasons to upgrade.
                    I thought this is what the MB "Air" was all about. My wife uses it and it does fine for her business. It probably has more connectivity than the new MBP.
                    I have no idea where Apple is headed. It used to be exciting to watch. Now it's meh.
                      slbaumgartner
                      I'm using a mid-2012 MBP Retina. The only thing about it I would change is that I wish I had maxed out the memory when I bought it. 8GB seemed like a lot at the time, but is today sometimes marginal.
                      • Mike LuceyM
                        Mike Lucey
                        It does but you plug the power into the adaptor.
                        • Mike LuceyM
                          Mike Lucey
                          I have the same year as you. I purchased a refurbished MBPR with 16GB memory and 750 Flash storage. I even now find the 16GB is a bit on the tight side.
                          • pbacotP
                            Does anyone know of a good file search program for use on the Mac. (built-in search is useless).
                            • Mike LuceyM
                              Mike Lucey
                              You might try EasyFind https://www.macupdate.com/app/mac/11076/easyfind Its also free πŸ‘
                              • Mike LuceyM
                                Mike Lucey
                                Apple Engineer Talks About New 2016 Macbook Pro
                                https://youtu.be/-XSC_UG5_kU
                                PS: If you understand Spanish, turn the speaker off.
                                • Mike LuceyM
                                  Mike Lucey
                                  Hi Guys,
                                  I posted about Afloat some time ago. At the time I found it to be an extremely useful utility, especially when working on a single monitor as it 'floated' apps that you need on top.
                                  Recent Mac OS upgrades made Afloat installation impossible but with High Sierra its possible again.
                                  I discovered great step by step instructions by Damian, here, https://www.maketecheasier.com/mac-keeping-your-application-window-always-on-top/
                                  If you install Afloat don't forget to re-enable System Integrity Protection.
                                  Mike
                                  • 11
                                  • 12
                                  • 13
                                  • 14
                                  • 15
                                  • 15 / 15
