    3D Truss Models
    1.5k Posts 31 Posters 976.8k Views 30 Watching
    • medeekM Offline
      medeek
      Neck is doing pretty good these days, a little sore some mornings but nothing a little Ibuprofen can't fix.
      On the flip side I came off of the Hydrocodone (for the neck and shoulder pain) about two weeks ago but still suffering from the withdrawal symptoms from this drug. My advice, don't ever use Hydrocodone unless it is absolutely life or death, its just not worth it.
      I'm trying to figure out what to tackle next.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • pbacotP Offline
        All looking great! Glad your neck is better. (I don't know what you've got or what you've been doing about it: I used exercises on mine which seemed good, along with general exercise. And I use a foam neck pillow. Just in case you're looking for ideas.)
        • medeekM Offline
          medeek
          Tonight I spent some time trying to do some "real world" modeling and it quickly becomes apparent how limiting the plugins really are. Take a look at this model here:
          3D Warehouse
          (3dwarehouse.sketchup.com)
          I need the ability to cut holes in the floors and insert headers and double up joists etc...
          There is a serious need for a good staircase plugin, but maybe that already exists, either way it would be handy to have that part of the truss plugin or wall plugin.
          Where roofs merge into other walls requires some attention.
          I really need to get to work on the wall plugin, I'm using Housebuilder but I have a lot of features I would like to see to make it more flexible and reliable.
          The double glulam beam rafter roof would be a nice addition as well.
          design.medeek.com
          • medeekM Offline
            medeek
            Fixed a small bug in the valley truss set, hence the revision 1.7.8b. Hopefully tonight I can attack the timber truss module, I think I have most of the pseudo code put together.
            design.medeek.com
              Garry K
              My stair maker plugin creates straight and curved stairs. Also Spirals.
              I am intending on adding quarter and half landings and some other features.
              I have built more than 200 of these geometric stairs including elliptical, specialty winders etc.
              We also specialized in framed up curved stairs without the cost of stringers.
              Some of my stairs projects include providing the bending forms and flattened stringers.
              • medeekM Offline
                medeek
                Spent some time this morning traversing through the common truss code updating some of the truss types so that I can enable energy/raised heels for all common trusses as well as enable custom layers, materials and connector plates.
                As I've developed the plugin and added new features I used the fink truss as the cutting edge, so everything having to do with this truss type is pretty much up-to-date, however some of the other truss types are seriously lagging so a little house cleaning is in order.
                It may be a few days before I can release this latest version since there is a lot of tedious work ahead.
                design.medeek.com
                • pbacotP Offline
                  Great work. I wish I had your dedication!
                  • medeekM Offline
                    medeek
                    I will download your stair plugin and give it a go.
                    That whole spiral staircase thing looks like a real challenge to code, don't even want to go there.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Raised/Energy heels add another level of complexity to the equation. Below you can see that various heights of a raised heel on a simple King Post truss requires different configurations and hence separate plating routines:
                      http://design.medeek.com/resources/images/truss_su177_800.jpg
                      This also affects the gable trusses as well, below is a fink truss with its gable counterpart:
                      http://design.medeek.com/resources/images/truss_su178_800.jpg
                      View models here:
                      https://3dwarehouse.sketchup.com/model.html?id=91d8d78a-8e6c-4dab-9839-4d689c84c297
                      https://3dwarehouse.sketchup.com/model.html?id=89739563-049f-4277-bfca-75663724967e
                      I'm still house cleaning. I've now got the King Post, Fink and Howe truss fully cleaned up with connector plates enabled for all possible configurations (raised heel, non-raised heel, structural, non-structural). I've only got 9 more common truss types to work through, see list below:
                      Queen Post
                      Fan
                      Mod Queen
                      Double Fink
                      Double Howe
                      Mod Fan
                      Triple Fink
                      Triple Howe
                      Quad Fink
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Raised Heel Howe Truss:
                        http://design.medeek.com/resources/images/truss_su179_800.jpg
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.7.9 - 01.15.2017
                          -Enabled metal plate connectors, materials and custom layers for king post, howe and queen post trusses.
                          • Added energy/raised heels for queen post truss (3 variants: wedge, slider and vertical w/ strut).
                          • Added energy/raised heels for howe truss (3 variants: wedge, slider and vertical w/ strut).
                          • Metal plate connectors now enabled for king post, queen post, fink and howe raised heel/energy trusses.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            I'm still investigating "real world" applications of the plugin to determine where the weakness and deficiencies are. Here is an example combining a dutch gable rafter roof with some raised heel trusses. Now that the raised heel feature is fully active for many of the common trusses it is actually quite easy to measure and then match the heel height of the rafters.
                            https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=cc8bdb7c-d8a4-46a7-b9ff-88ac60c6ec07
                            View model here:
                            3D Warehouse
                            I am interested in how others are actually using the plugin and where it is falling down for you, please feel free to send me models or post on the forum with your "real world" design issues with regards to the plugin. This will help drive future development and prioritize the more important items on the todo list.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Raised heel double fink truss with connector plates:
                              http://design.medeek.com/resources/images/truss_su180_800.jpg
                              I added this one today and will roll it into verson 1.7.9b.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                In the advanced options for common roof trusses I currently have the sheathing option. I am wondering if it might be useful to also enable a gypsum wallboard option for the ceiling, with a global setting that sets the exterior wall thickness (inset) and the gysum thickness:
                                https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=1f8640f7-a620-4542-ad23-3ccdd6ff40b8
                                View model here:
                                3D Warehouse
                                Please chime in if this is something that would have some utility or not.
                                design.medeek.com
                                • jujuJ Offline
                                  juju
                                  View model here:
                                  3D Warehouse
                                  That would be useful! Below are some parameters I would appreciate to help speed up the process:
                                  • board thickness (manual entry, but remembers the last used value)
                                  • offset from walls (manual entry, but remembers the last used value)
                                  • Z-offset, to bottom of ceiling, below tie-beam (manual entry, but remembers the last used value)
                                  • batten sizing (manual entry, but remembers the last used value)
                                  • batten spacing (manual entry, but remembers the last used value)
                                  I like the way you pull out all the stops! I gather the above will also comply to your regimen of being able to preselect the layer assignments?
                                  Something else (more-or-less in line with your train of thought with the above) that would be great to have, if it could be added as well,0 is the ability to automatically generate an extruded plane (extrusion height manual entry, but remembers the value last used) as the roof material. Generally I model these as a box on top of the purlins/roofing battens as a representation of the roofing material, would be great if there were some automation involved here. 😉
                                  • jujuJ Offline
                                    juju
                                    @medeek said:
                                    If its not too much I will probably also specify two additional layers:
                                    ceiling_gypsum
                                    ceiling_batten
                                    Ceilings aren't always made of gypsum board, I think we would need to consider an alternative name there? However, as long as the user is aware, this shouldn't pose a problem even if the naming stays as you proposed.
                                    @medeek said:
                                    What is the typical size for ceiling battens in your locale?
                                    typically 38x38mm and 38x50mm is used, depending on truss spacings
                                    @medeek said:
                                    Also with a roof plane/extrusion, I see the necessity with having this addition when one uses battens but what about when there is already a sheathing layer on the roof and no battens?
                                    I would still consider having the option there. Where I'm from, the typical roof construction does not use sheathing, I think I've used it once ever, with RheinZink as final roof material finish... Maybe some of the other people here can give us some feedback here?
                                    • medeekM Offline
                                      medeek
                                      On a similar note I would also like to create a new section in the global settings for "Sheathing". Here one can select whether sheathing will be an enabled advanced option by default or not and also other default parameters like sheathing thickness (wall and roof separately). My default sheathing material is OSB but in the global settings I will add a toggle between OSB and Plywood.
                                      So far I have not dealt with wall sheathing on the gable ends, leaving it to the user to add their own but I would like to make that an option.
                                      Also with the roof sheathing I would like make a global setting option of coloring the exterior/top face with a pre-determined roofing material if no other roofing extrusion is present, I've got to think about this some more.
                                      My thinking is that the global settings should allow one to setup or customize the plugin so that all of your typical settings are "fine tuned" for you thereby minimizing the effort required when presented with all of the input menus during the roof creation process.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Another item I have been putting off is the heel blocking. I'm planning on offering two variants (vertical and angled), with the option to draw in the ventilation holes (typically 2" in diameter in my region, with 3 holes per 24" o/c spacing) if desired:
                                        http://design.medeek.com/resources/images/truss_su181_800.jpg
                                        Obviously this is not a hot item since no one has bugged me about it but I have not forgotten it, just put it aside up until now.
                                        With raised heels this may become a bit more complicated requiring more options, (ie. a V-cut instead of the typical bird holes). More input from builders would be useful in this regard.
                                        With the angled heel blocking an overhang must be present for this to work so the code will revert to a vertical heel block when not enough overhang is present.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          @Juju
                                          I like what you have proposed here. What I will do is add a new section in the global settings called "Ceilings" that enables one to enable a gypsum wall board layer and/or battens. The thickness and sizes can also be set here as well (which become the default values) but the pop-up menu for ceiling - advanced options will allow for manual entry of each item and will also override the default values with the last values selected.
                                          ceiling_gypsum or ceiling_sheathing?
                                          ceiling_batten
                                          What is the typical size for ceiling battens in your locale? and the o/c spacing?
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            I didn't particularly like the shade of the plywood material that is standard with SketchUp, so I went looking for a better texture. I think I've found one that I like but would be happy to entertain others if someone has a certain plywood material texture that they like.
                                            design.medeek.com
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 75
                                            • 76
                                            • 36 / 76
