    [Plugin] Andersen Window
    31 Posts 18 Posters 40.6k Views 18 Watching
    • McGyverM
      McGyver
      Interesting... thanks for the heads-up.
      Visit My ShareCG Freebie Gallery
      • N
        nujak66
        I quite like this Andersen window tool but....Does anyone know if there is a way to clean up (miter) the corners of the frame with this tool (or another quick plugin tool)? They don't seem to miter and look correct on there own.
        Thanks for the help.
        m.o.d.
        • C
          Chriso
          Just ran across this post and wanted to share some info on how to reduce the extraneous lines in some of the Andersen dynamically generated windows. The Window Studio program creates virtual models that have all the detail you would want in 2D. They use that same engine to produce the geometry that goes into making the SKU component. And yes, sometimes there is just too much detail (especially in the corners of the sash frames).
          I found that I could edit the component and use the "Soften Edges" function to eliminate most of the lines. You end up with a really nice look too.
          I don't have screen caps and a full instruction doc, but here's how I did it
          1. Generate and place the window
          2. Select the unit and choose, "Edit Component"
          3. Use the Ctrl key and select all the frame elements
          4. R-Mouse click and choose "Soften/Smooth Edges"
          5. I run the slider until the lines in the corner of the frames goes away (near 100)
          6. For grilles, you need to select a grille member and choose "Edit Group"
          7. Then use the Ctrl and select each grille member (little tedious)
          8. When all selected, choose "Soften/Smooth Edges" and eliminate the lines (usually about 50)
          9. Sit back and see how cool your window looks
          10. Now do the interior, same procedure, if you need to
          WARNING!!!! These windows are dynamically generated, which means if you use their EDIT feature and make a change back in Window Studio, ALL YOUR CHANGES MADE IN SKU WILL DISAPPEAR. Smoothing the window is like the last thing you do once you have all the other decisions made.
          And the andersenwindows.com site was refreshed and this is how you download the program:
          1. From home page go to "For Professionals"
          2. From Professionals, click on "Window Studio and Windowsymbols for Revit and SketchUp...."
          3. Scroll down to Window Studio and click on "Get Window Studio for 32bit or 64 bit Windows PC"
          4. Fill out the form and get a download link
          Oh yeah, and it's free too!
          Enjoy
            rv1974
            does it work in metric system?
              avminkler
              Anyway work around to get this to work with SketchUp 2014? I thought I had stumbled across a way to do it but now can't seem to find it...
                DMDESIGN
                Download the Windows Studio version and it will automatically attach to Sketchup a plug-in the next time you open a file.
                • ccaponigroC
                  ccaponigro
                  😞 I love this plugin or extension and use it all the time. Sadly it appears Anderson has abandon sketchup going forward and concentrating on Revit. The extension is not SU2015 comparable so I have to load an older version create the component save it out to a folder and then bring it into SU2015. Huge disappointment!!!
                  cfcaia.com
                    Mose
                    where to download it. couldnt find it on the site
                      Mose
                      @thomthom said:
                      @krisidious said:
                      what? I didn't see anything to do with sketchup? does the software itself save a SU file?
                      ok I must be dense because I don't see anything about a component or SU anywhere...
                      [attachment=0:2c70gh89]<!-- ia0 -->Windows Studio.png<!-- ia0 -->[/attachment:2c70gh89]
                      nice but how you open this window? I couldn't find it
                      • pbacotP
                        This is an old thread and Anderson has changed their website since then. I tried the link on the page that came up "start here" but I nothing worked for me. On another page it looks like they offer generic files, but I haven't found a usable model yet.
                        Usually can model something better than the offerings by manufacturers, in less time than fooling with their websites.
                        • Collage ArchitectureC
                          Hi,pbacot
                          I recently searched for Window Studio plugin after watching the 3D Basecamp Video
                          You can download Window Studio from the link below
                          http://window-studio.software.informer.com/download/
                          However,Window Studio is only compatible with Sketchup 2015
                          I love Sketchup
                          • ccaponigroC
                            ccaponigro
                            Here is what you can expect from the Plugin. I was using them and had started a library. I ended up creating my own simple generics because I felt the where just to heavy. I would only use them for a detail one section.
                            AW-400-WR-DH400-34x72-4over4.skp
                            cfcaia.com
                            • pbacotP
                              That is pretty nicely detailed. But probably heavy for a whole house model.
                                Mose
                                I think I am real dumb, since I am the only one who can not use the program and create something at first look. I even couldn't understand what is this
                                • 2 / 2
