    Subtract problem non-solid
    3 Posts 2 Posters 1.0k Views 2 Watching
      dihe
      Hi there,
      I have problem with subtracting two components. both are quite simple. Have you any idea how to subtract it?
      http://i68.tinypic.com/5oz05t.png
      File with problem
        Subtract requires that both components/groups be solid. Your Component#10 is not solid due to the internal face shown in red. If you remove that face, the Subtract tool will work.
        The simple definition of a "solid" in SketchUp is that every edge is shared by exactly two faces. In the case of your Component#10, the edges at the bottom of the chamfer are shared by three faces, not two.
        Solid Inspector can fix it or you can easily fix this one without any extensions.
          dihe
          Thank you Dave
          Solid Inspector works great:
          http://i65.tinypic.com/55gmtw.png
          Topic SOLVED
