    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 463.1k Views 80 Watching
    • romboutR
      rombout
      Is there a option to use this on mac? Is the code that much different when using plugins on apple machines?
      • P
        Pherim
        Hello,
        just a small thing, but I noticed that when I set Floating Toolbars to hidden, save the settings and enable "Retain on Start", only some of them are hidden after restarting Sketchup.
          Anton_S
          @Rombout Currently this plugin is only workable on Windows. Mac OS X API is too different from Windows API. And I don't mean SketchUp Ruby API.
          @Pherim Thanks for your report. I will get it fixed soon.
          • romboutR
            rombout
            Okay thanks for answering, I've found a working solution now which hides all panels
            • L
              lionk
              hi @Anton_S,
              the plugin dialog covered the trays in sketchup 2016. How to use the plugin correctly?
                Anton_S
                Left-click on the title bar of the settings dialog, hold the mouse button down, and drag it to any desired position on screen, where it doesn't intersect the other dialogs. You can also click on the x button to close it.
                  sarkarshomit
                  The plugin is crashing with this warning:
                  Error Loading File C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings/main.rb
                  Error: #<NameError: uninitialized constant AMS::Timer>
                  C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings/main.rb:69:in init' C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings/main.rb:572:in <top (required)>'
                  C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load'
                  C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings.rb:80:in register_extension' C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings.rb:80:in module:WindowSettings'
                  C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings.rb:62:in `<top (required)>'
                  I had this working before on my SU16, but now after i updated it is crashing unfortunately 😞
                  PS: I am on Win7Ult 64bit
                  Explorer V9
                  PS PS: I had a backup of the older working version which i copy pasted and now it works, but am scared to update!!!
                    Anton_S
                    Sarkarshomit, have you upgraded to AMS Library 3.3.0, besides just upgrading the Windows Settings plugin? Because if you haven't, then the AMS Timer error could be depicted due to an old version of AMS Library.
                      sarkarshomit
                      Yes Anton, updated today the libraries...still this error...
                      C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings/main.rb:62:in init' C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings/main.rb:562:in <top (required)>'
                      C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings.rb:48:in register_extension' C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings.rb:48:in module:WindowSettings'
                      C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings.rb:34:in `<top (required)>'
                        Anton_S
                        Just tested it on my Windows XP and Windows 10 64bit and it works fine. I really don't know what's wrong with yours. Perhaps you didn't overwrite all the files of AMS library. Try deleting an old version of ams_Lib and ams_Lib.rb from the "C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/" folder. Then install the latest version of AMS Library.
                          sarkarshomit
                          Thanks for the trick, it worked fine...regards....
                          • B
                            bharralure
                            Bonjour Anton,
                            J'ai installé "ams_WindowsSettings", et il me semble que je rencontre un problème d'affichage de "la boîte de dialogue des paramètre" (voir capture d'écran ci-après).
                            Je suis sous "Windows 10 Famille v1607 64 bits", carte graphique "AMD Radeon R7 200 Series v16.6".
                            J'ai installé (puis désinstallé et réinstallé à nouveau "ams_Lib.rbz_v3.4.1" et "ams_WindowsSettings_v4.2.1".
                            Je joins également une capture d'écran des différents paramètres qui me sont accessibles depuis le menu "Fenêtre > Réglages"
                            Auriez-vous une réponse à ce problème?
                            D'avance merci.
                              Anton_S
                              Hello, bharralure,
                              My apologies for not responding any sooner. It has been a while since I downloaded a localized SketchUp version. I fixed the bug with localized dialog. Please upgrade to version 4.2.2. Thanks for reporting.
                              Regards,
                              Anton
                              • B
                                bharralure
                                Bonjour Anton,
                                Je viens d'installer la version 4.2.2 qui semble fonctionner parfaitement.
                                De plus, "cerise sur le gâteau" (expression Français qui, j'espère, sera traduite correctement par Google), la fenêtre est en Français.
                                Merci Anton pour cette mise à jour efficace.
                                • P
                                  perroloco2000
                                  Hi Anton,
                                  The setting dialog doesnt display properly and cannot scroll to the option for Retain settings on Start.
                                  The settings aply well but I'm not able to keep them on the start.
                                  Specs: Windows 10 v1607 x64 / SU Pro 2017 v17.0.188899 / AMSlibrary 3.4.1, AMSwindowSettings 4.2.2 / Geforce GTX960M 2GB dedicated / 1920x1080
                                  In my other laptop (same specs as graphics: Intel HD4000 integrated / 1366x768) all works well!!
                                  Maibe a resolution issue? I tried other resolutions and connecting other monitors but same problem. Please help!
                                  Thanks in advance for your help and plugins.
                                  (tried to attach an screnshot)
                                    Anton_S
                                    Thanks for the report, Perroloco. I will fix that soon. By the way, if the Spanish translations are improper, because I used Google translate for them, you can modify the translations for the commands_es.strings and window_settings_es.html, located in ../ams_WindowSettings/lang folder and send me a PM with the two new files so that I could merge them into the plugin.
                                      Anton_S
                                      Alright, Perroloco, it's fixed now. Please upgrade to version 4.2.3.
                                      • P
                                        perroloco2000
                                        THANKS ANTON!!!
                                        Everything is working perfect now!
                                        For a google translation is really well done. I would only change "Contenedores de barra" for "Barra de herramientas".
                                        Glad I could help you also (tiny help je je). And thanks for your quick reply.
                                        Keep up the good work!
                                          Archsuke
                                          how to change language it's not possible
                                            Jorgensen
                                            Hi Anton
                                            A very nice plugin. It's very satisfying working in full screen with no distracting menu bars 😄
                                            When i first saw the settings menu, I thought that I could select the Mode, and then set settings for this mode, and then select an other mode, and then select settings for this mode. But that seems not to be the case - but i might have misunderstood the use of the plugin.
                                            What I was looking for, was to be able to switch to full screen mode using F11, and then I would not see anything, just a blank clean, non disturbing work screen, then when I press F11, I should come back to a "normal" screen where I can access the different menus, if needed.
                                            Could that setup be possible with this plugin?
                                            Jorgensen
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 10 / 15
