    MSPhysics tests and questions
    104 Posts 21 Posters 59.7k Views 21 Watching
    • robintR
      robint
      Hi Faust
      Through the Ruby Code editor, I found a start_timer and stop_timer function
      Would this help?
      Say put start at the top to activate when staring sim,
      then stop_timer after the reset action line
      then display timer?
      sorry my newbie attempts at script (do you hav any recommendations on the best way to learn script for MSP - there's so much flack out there its hard to know where to start)
      Cheers
      Robin
      As one door closes another one slams in your face
      • F
        faust07
        Hi Robin,
        have tested to find a solution to pause simulation per script, but have nothing found until now.
        I'm a script newbie too. For my purposes I look into scripts of models from the experts at 3D-Warehouse (AntonS & PituPhysics) or ask them in Anton's main MSP post.
        • robintR
          robint
          Well we are both struggling, blind leading the blind
          FYI this timer thing is fundamental to simulating physical systems (mass speed acceleration)
          The on touch is a good start, just need to time the sequence and display result on reset
          opens up a whole new way of simulating mechanical systems
          as fundamental say as a thermometer is to tell you the temperature - if you see my point
          so I must perservere. If I get a result I will post it you
          Cheers
          Robin
          • robintR
            robint
            A bing moment has occured β˜€
            when I # out the reset line, I just had a ontouch line only and it outputs to screen what might be some sort of final velocity m/s on impact (according to the script info)
            pls see model
            Now I cant yet correlate that to the calc velocity which should be 14m/s on impact from 10m
            it comes out at 58 and varies with the UI sim setting of Newton update rate (currently 10)
            also from dropping from 5m gives 33 (should be 9.9m/s and is 1/sqr2 - .707) whereas 33/58 is ca.57
            maybe some dynamic friction in play?
            Is this a worthwhile line of enquiry?
            Cheers
            Robin
            ps the ball is in anton's examples funny little thing - and something for gamers pool table maybe?
            falling block.skp
              Anton_S
              Yes, the final velocity should be 14 m/s, and it is 14 m/s.
              Your script in the model you posted, just outputs the frame:
              onTouch { |toucher, position, normal, force, speed|
                simulation.log_line("onTouch #{frame}")
              That explains why you get unrelated results.
              To output the final velocity, you should change the code to output the speed:
                simulation.log_line("onTouch #{speed}")
              And besides, setting the linear damping of the falling box to zero will make the final velocity even more right because this will eliminate the dissipative force.
              • robintR
                robint
                Thank you so much Anton, I was just about to post an apology for a stoopid boy Pike moment (no smilie for Duh 😳 )
                but I read the second line and it outputs frame to screen, what a numpty
                You gave me some other scrip that outputs velocity, strange to note that the cube reaches a terminal velocity ca 2m/s ca halfway down - intriguing. Is there something in there that simulates viscosity?
                onUpdate {
                Get current velocity
                cv = this.get_velocity
                Output it in the note
                note = sprintf("Velocity: (%.3f, %.3f, %.3f)", cv.x, cv.y, cv.z)
                simulation.display_note(note)
                Cheers
                Robin
                  Anton_S
                  Yes, the viscosity is simulated by the linear damping. To remove the linear damping, select the desired group, open MSPhysics UI, activate the Properties tab, and set Linear Damping to 0.00. This should alter the height of terminal velocity.
                  If you meant something else, like water or buoyancy, you can add a buoyancy plane by navigating to (Menu)Extensions->MSPhysics->Create Buoyancy Plane. Although the liquid is not simulated. It's just the buoyancy force that is applied.
                  • robintR
                    robint
                    Hi Anton
                    Just when I thought you cracked it with speed, something strange happens
                    When dropping the block from 10m = ok = 14m/s as per calc (see model)
                    Move the block down to 5m => nonesense answer like 0.07... (should be 9.9m/s)
                    Yet move block to other elevations like 8.5m or 2.5m , seems to work ok (but I haven't checked the result against calcs (12.9, 7)
                    So I am completely stumped πŸ˜’
                    BTW sometimes the block appears to penetrate the baseplate and slowly return to zero, could this be the reason?
                    Thats ruined my day
                    Cheers
                    Robin
                    falling block2.skp
                    • robintR
                      robint
                      Maybe uncovered a nasty bug? Anton
                      Here's a suggestion from your speed indicator
                      onUpdate {
                      note = sprintf("Velocity: (%.3f)", cv.z)
                      When it runs, on collision it displays 0.00 as expected, the block has stopped but we lost the terminal velocity
                      Could we say put an IF loop in the output velocity to note, only iff velocity <say .5m/s, then it should go to zero when the block stops (assuming no bounce)
                      Just a thought, maybe a simpler approach? from a ruby newby
                      Cheers
                      Robin
                      • robintR
                        robint
                        Sorry, Im getting tired
                        I meant it should retain the highest last value in note when the block stops
                        Apologies
                        Robin
                          Anton_S
                          It's all cool πŸ˜„
                          Here is the code for viewing maximum velocity.
                          onStart {
                            @max_vz = 0
                          onUpdate {
                            if v.z.abs > @max_vz
                              @max_vz = v.z.abs
                              simulation.display_note(sprintf("Max Speed %.3f m/s", @max_vz))
                          And yes, the speed indicator in onTouch may not always work right, which is the problem of the physics engine that my wrapper is using.
                          • robintR
                            robint
                            Hi Anton
                            Installed your script, works a treat and pretty accurate 😎
                            However I have meddled and got stuck, I cant find a way to print another result on a new line, tried everything, puts, print (can't find sprintf in docs either)
                            As you see I want to print elapsed time as well and it works but overwrite the Max Speed result on the same line
                            I feel really dumb getting stuck on this trivial matter, pls help 😒
                            BTW would I be right in saying that MSP script is a subset of official Ruby 2.0 and some elements like puts and print (they dont do anything on screen or riase an error)are left out?
                            Cheers
                            Robin
                            falling block3.skp
                              Anton_S
                              Here:
                              onStart {
                                @max_vz = 0
                              onUpdate {
                                  @max_vz = v.z.abs
                                  simulation.display_note(sprintf("Max Speed %.3f m/s\nElapsed Time; %.2f s", @max_vz, world.time))
                              • robintR
                                robint
                                Anton, ooh that is nice
                                from little acorns, great oaks grow
                                So now we have a timer as well
                                Maybe add
                                add the x.y.z distance travelled
                                and then I can perhaps simulate a cannon firing a cannon ball at a target
                                and with a bit of wind and air friction, elementary gunnery for the Napoleonic War
                                I will of course present my models to you for the consideration of others in the interest of MSP
                                Cheers, many thanks
                                Robin
                                falling block4.skp
                                • robintR
                                  robint
                                  Hi Anton
                                  Just seen your Turret thingy, blown away by it
                                  30 pages of code - I might as well try and become a brain surgeon!
                                  3D Warehouse
                                  (3dwarehouse.sketchup.com)
                                  Very skilful
                                  Robin
                                  • gillesG
                                    gilles
                                    Just playing with basics,
                                    brought me to some questions:
                                    When you at the screws,
                                    -one is static mesh and is collision shape fits perfectly.
                                    • to achieve the same collision shape for the mobil oneI had to it with several components.
                                    Any reason the soft isn't able to calculate the same collision shape but not static?
                                    To make those movements running well I used a workaround.
                                    For rotation we have hinge, motor, servo.
                                    For translation we have slider, piston, why not a linear motor?
                                    For translation + rotation we have corkscrew, why not motor + linear motor , servo + piston, servo + linear motor , linear motor + piston?
                                    For curve we have curvy slider and curvy piston, why not a curvy motor and curvy piston?
                                    Nota bene: just curiosity here, no request.
                                    Vis MSPhysic.skp
                                    • robintR
                                      robint
                                      At last
                                      Terminal velocity
                                      Time
                                      Distance
                                      Now the basis of my cannon project
                                      Anton has made a sophisticated urret thingy available on 3D warehouse/msphysics
                                      but I want to make a simpler model for a gunner with inputs for
                                      horiz angle
                                      Azimuth
                                      muzzle velocity
                                      Range (from a range finder measurement of a distant target placed at random)
                                      Air density (from Bar pres, RH and temp)
                                      Air friction ?
                                      output > distance landed from target (eg a forward spotter)
                                      Simplistic stuff for a Napoleonic gunnery officer
                                      Maybe a moving target next (eg tank)
                                      On the 7th day god made Robin
                                      falling block6.skp
                                      • F
                                        faust07
                                        Hi Anton, after extensive tests with the fairly complex ice stage model, I can report that everything works very well.
                                        I just had to reverse some curves and exchange the programmed Curvy Piston Joint for the Orca. The calculation of the transformed emitter objects seems to work more precisely.
                                        This costs a little more time for the simulation, but the viewport problems no longer occur.
                                        That's great! Thank you very much!
                                        I have extended the simulation around a rain with middle large hailstones and it works.
                                        And for the future the integration of the good old SketchyPhysics fracture/split function and a kind of soft or flexible surfaces would be great...
                                        πŸ‘
                                          Anton_S
                                          Thanks for testing and verifying, Faust. Next feature would be to improve performance of export to Skindigo and Kerkythea. I think there is a way to reduce export redundancy. The fracture thingy would be implemented too.
                                          • F
                                            faust07
                                            Sounds good!
                                            • 3 / 6
