    2d vector exports that preserve transparency and hidden line
    8 Posts 3 Posters 1.4k Views 3 Watching
    • john2J Offline
      john2
      I am trying to export vectors from sketchup so that I have dotted hidden lines visible and transparency as well.
      This is the pure jpeg export. This is the exact requirement in vector format that I neeed
      I am making such graphics for volumetric analysis for architecture.
      For this
      1. I do a pure wireframe export as pdf
      2. I do an ONLY FACES, and no lines export as pdf.
      3. Combine them in Adobe illustrator
      However, I am unable to export hidden dotted lines.
      What I can get closest to is this result?
      wire and transparency vects_forQuest.pdf
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 โ€“ 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
        The back edges in SketchUp are raster not vector. You could send the model to LayOut as wireframe and explode it before converting the back edges to dashed lines or you could trace the back edges with LayOut's Line tool after setting it to make dashed lines.
        As for the face transparency, I don't see how that can work. Faces and transparency are raster things not vector.
        • john2J Offline
          john2
          Okay thanks. I'll try this out. ๐Ÿ˜„
          • john2J Offline
            john2
            I did this using illustrator. I exported wireframe and normal shaded with lines pdf exports in sketchup.
            I then made all the wireframe lines as dotted. These dotted lines were then overlapped with thicker lines of the "shaded" pdf with removed fills.
            Then I did overlaps with vray render.
            FormEvolution Experiment.pdf
            Here is the png image.
              That looks decent.
              • sketch3d.deS Offline
                sketch3d.de
                Sketchup Make 2016 (64-bit), SketchUp Make 2015 (64-bit)...
                btw, SU Make version for non-commercial use only ๐Ÿ˜ฎ
                • john2J Offline
                  john2
                  "Non-commercial use means: you may not sell, rent, lease or lend the output of the Software or the Services." As quoted from the trimble terms and conditions
                  I haven't done any of the financial activities as far as the eps or pdf outputs of sketchup are concerned. The output is taken from a software called Adobe Illustrator.
                  Moreover, my signature doesn't list down each and every piece of software running on my machine, my friend's machine, my colleagues machine, my professor's machine or my uncle's machine. ๐Ÿ˜•
                    sketch3d.de
                    everything created with SketchUp, regardless if further processed with another application, is bound to the license terms agreed by you, transfering to another application for the final, commercially used export is obviously a commercial usage too ๐Ÿ˜
