    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 927.6k Views 172 Watching
      SketchyPhysicsNutt
      Hi Anton just reporting this little bug im getting with your ams windowsettingsv4.2.0
      plugin and MSphysics keeps jumping out of fullscreen.
      im using MSPhysics_0.9.8/Win 8.1/Sketchup 2016 and ae-toolbar editor plugin
      Before
      http://s3.postimg.org/divr36o8z/test1a.jpg
      After
      http://s18.postimg.org/np66r8oyh/test1b.jpg
      any info would help
      Tez
        DonDeEs
        Hi Anton
        That makes sense of the geared joints option. I had not really worked out what they were about but this is absolutely the solution I needed so many thanks.
          Anton_S
          Thanks for reporting this, SketchyPhysicsNut. I came across it but forgot about it the next moment. Now I got it logged.
          DonDeEs, for the geared effect, you can try connecting joints to joints. They are called geared joints. For your rack and pinion gear, you can connect slider to the rack group and hinge to the pinion group. Then connect slider with the hinge. After that, using UI you can adjust distance-to-angle ratio. Geared joints allows user to utilize gears without having any collision at all. I even tried making a differential gear using the geared joints. It worked very well. Once I get some free time, I will definitely make a tutorial about it. At the moment, here is an example of geared joints:
          MSPhysics Geared Joints
          Edit: At the moment geared joints yield improper behavior under certain cases, but I'm intending to address the issue in the next release.
          Also, I'm aware of the collision wireframe not drawing when the orbit tool is activated. The collision wireframe stops being drawn whenever the simulation is suspended. However, it starts drawing again whenever it is resumed. That's how SketchUp API works and I don't have much control over it. So, while having an orbit tool, if you right click and select Exit the simulation should resume the drawing.
            DonDeEs
            Hi Anton
            I hope it is OK to report a possible bug with MSPhysics 0.9.8.
            I am using it with Sketchup 2017 on a Surface Pro running Windows 10.
            It seems the UI opens in a different resolution and does not therefore display in full. The maximise button is disabled so I wondered if there is anything that I can do to fix this.
            I have attached a screen shot for you if it helps.
              DonDeEs
              I just checked and this only seems to be a problem with S2017. Seems to work fine in 2016.
                Anton_S
                Thank you for reporting this, DonDeEs. Someone reported something similar and I'm in the process of fixing it. I might have to send you s private message to verify the fix.
                  DonDeEs
                  Sure thing. Feel free to do so.
                  • robintR Offline
                    robint
                    Hi Anton
                    Congrats on your great work resurecting old SP for a new version. I played with SP some years ago and amazed myself by getting a caterpillar track chain to work
                    May I ask if it is possible, in your version, to assign real physical values to objects, eg mass in kg, spring rate m/kg, damping kg/m^2 and so on
                    and perhaps equivalent elements for rotating masses
                    Its all in aid of helping my student understand the dynamic behaviour of physical systems with different input and load conditions open loop and closed loop
                    If this could be done, it would be of fantastic benefit for Uni ugrads (yes there are professional - expensive suites to do this). Something tailored to fit with the unbeatable SU would be so good
                    It wasn't available in the original SP, only cruded dimensionless tweaks
                    Cheers
                    Robin
                    ps apologies if this has already been answered pls link me
                    As one door closes another one slams in your face
                      Anton_S
                      Hi, robint,
                      Just to clarify a thing, MSPhysics is not a new version of SketchyPhysics; MSPhysics is a plugin written completely from scratch, integrating the latest NewtonDynamics Physics engine by Julio Jerez. Yes, it does have a similar functionality to SketchyPhysics, but that was done because I didn't want to reinvent all the ideas Chris Phillips put into writing SketchyPhysics and so that SketchyPhysics users wouldn't have hard time transitioning to MSPhysics.
                      In MSPhysics, the mass (kg), force (N), torque (Nm), angular velocity (rad/s), and linear velocity (m/s) - are controled with the standard SI units. These values are proper, even with the world scale set to some value other than one, as behind the scenes they are scaled to maintain themselves in SI units. The parameters for joints, such as power, accel, damp, and friction, however, are controlleded with unknown units. While writing the custom joints, I didn't place close attension to the units, but I think they can be converted to the units you described in your post. Some testing needs to be done to figure out the ratios.
                      By default the mass is calculated by taking the volume of an object, in m^3, and multiplying it by the density, in kg/m^3, which is by default 700 kg/m^3, the density of wood.
                      To assign a particular mass to a body, in killograms, you can do it with the UI dialog:
                      1. Select the desired body.
                      2. Open the MSPhysics UI.
                      3. Activate the Body Properties tab.
                      4. Select weight control option and switch it to mass.
                      5. Write the desired mass into the mass input box.
                      The static and kinetic friciton coeffiences, which can also be assigned through the dialog, are not the actual coefficients. The actual coefficient is an average coeffiecent between the two touching bodies. For instance, if the floor has a static coefficient of 0.9 and kinetic of 0.7, and the touching body has a static coefficient of 0.4 and kinetic of 0.3, the actual static coefficient for the contact, would be (0.9+0.4)/2 and the actual kinetic coefficient would be (0.7+0.3)/2.
                      The same concept applies to elasticity and softness. I'm no expert what the softness does, as I didn't write the physics engine, doing most of the calculations for my wrapper, but I think it controls how much energy is transfered durding collision, i.e an aditional parameter for elasticity.
                      To control other physical properties, such as velocity, you need to assign a Ruby script to a group. This can be done by selecting a desired group, activating the Script tab in the MSPhysics UI, and writting some code in the editor. Here's a script for applying a particular velocity to an object whenever simulation starts:
                      onStart {
                        this.set_velocity(0,1,2) # x, y, z - the velocity vector
                      The velocity can also be applied every time the world is updated:
                      onUpdate {
                        this.set_velocity(4,5,6) # x, y, z - the velocity vector
                      And the velocity can also be recorded:
                      onUpdate {
                        # Get current velocity
                        cv = this.get_velocity
                        # Output it in the note
                        note = sprintf("Velocity; (%.3f, %.3f, %.3f)", cv.x, cv.y, cv.z)
                        simulation.display_note(note)
                      You may also apply force, torque, omega, and do other things with scripting. Check out this scripting documentation link:
                      http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/index
                      Here is the exact link for all the functions available for a body:
                      http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/MSPhysics/Body
                      Regards,
                      Anton
                      • robintR Offline
                        robint
                        Thank you so much Anton, thats given me some homework!
                        BTW I didn't wish to imply you were overwriting the previous SP. MSP is of course entirely yours started from scratch - brilliant stuff
                        I'll be glad to pass any useful models I can generate back to you to pass around to other interested parties and perhaps help generate other instructional models
                        Cheers
                        Robin
                          Anton_S
                          Hi, Robin,
                          I'm glad I could help.
                          Best regards,
                          Anton
                            Sjamon
                            Dear Anton,
                            I just downloaded the plugin to make a simple cinematic / collision check on a folding workbench model, that is basically a deformable parallelogram.
                            Although I got the basic principle and manage to make singles hinges move as expected, any component is stuck as soon as it's linked to two hinges.
                            There's also a message reading "Requires MSPhysics 0.9.8+" in a corner of the screen, should I understand that it won't work unless I install something else ?
                            Armand
                              Anton_S
                              Hi, Armand,
                              A hinge with no parent groups will act stationary. In order for the hinge to move, it must have a parent group. What I think is going on in your model is that the hinges are top level groups. If you want a hinge to link two groups together, and still move, simply create a hinge joint within one of the groups andd then, using the joint connection tool, connect it to the other group. That way the hinge joint will have a parent body, which will allow it to move.
                              Check out this mini clip:
                              Movable Joints Example
                              The message is there so that people using your model would know that they need MSPhysics in order to run it.
                              Regards,
                              Anton
                              • gillesG Offline
                                gilles
                                I think I have some issue with hinge when I link it to a parent:
                                Mac OSX 10.8.5, SU2015.
                                  Anton_S
                                  Hi, gilles,
                                  To fix that, you have to select the joint, open MSPhysics UI, and check the "connected collide" option.
                                  Regards,
                                  Anton
                                  • robintR Offline
                                    robint
                                    @anton_s said:
                                    Hi, Robin,
                                    Best regards,
                                    Anton
                                    I made a simple mass/spring damper system as per model, but I get some odd results not like the damped sinusoid
                                    Am I on the right track or have I made some basic errors
                                    Also the block doesn't sit still on the plane but wanders off
                                    I am also having difficulty tying in the UI with real values of spring rate N/m and damping c*velocity Ns/m
                                    Any advice, most appreciated
                                    Cheers
                                    Robin
                                    BTW I looked at the Ruby docs but couldnt tie up real units to the constants
                                    classic spring damper
                                    • gillesG Offline
                                      gilles
                                      @anton_s said:
                                      Hi, gilles,
                                      Regards,
                                      Anton
                                      Works fine πŸ‘
                                      A lot to dig in, I go back to the mine.
                                        Anton_S
                                        Hi, Robin,
                                        The block doesn't sit still probably because you disabled the friction. Enabling the friction checkbox option for the block and for the floor contacting the block will fix the wandering off behavior.
                                        I will add an option to control accel and damp with the SI units in the upcoming release. At the moment, I figured that spring constant is roughly equals to (accel * 7 - damp), when spring joint stiffness is set to 1.0.
                                        Edit: Ensure that both anuglar and linear damping for all bodies are set to zero. This improves the closeness.
                                        Anton
                                        • robintR Offline
                                          robint
                                          Hi Anton
                                          I'm sure I tried every way with the friction coeffs, and it didnt seem to help much, unless Im doing something wrong. If you could get real SI units into the spring damper model this would be fantastic. Classic maths leaves everything in normalised units which is really hard for students to translate into the real world - thats what MS physics is about. I try to encourage my student to abandon th suck-it-and-see approach in favour of understanding what is really happening and calculating the effect. I know that math is a real turn off for most users, but I try
                                          cheers Robin
                                          • robintR Offline
                                            robint
                                            @anton_s said:
                                            Hi, Robin,
                                            Anton
                                            Yes indeed, improved action, I missed the friction box
                                            Herewith a revised model changing block mass from 0 - 0.5 kg gives a displacement of 0 - 1.0 so the spring rate is 2
                                            spring stiff 1 (what does this do?)
                                            Accel 1, damp 1.5 (gives critical damping approx)
                                            changing sample rate from 1/60 to 1/240 changes the whole model performance
                                            iterations 16 - improves stability
                                            the plane has a mass of 0.01kg, lowest i could get without instability
                                            So Ive actually got a spring damper that sort of behaves but it seems like the spring has inertial mass - an ideal spring should be zero mass and friction
                                            What do you think? Anything I can do to help (ruby dummy just now)
                                            Cheers
                                            Robin) πŸ˜›
                                            V 2
                                            • 11
                                            • 46
                                            • 47
                                            • 9 / 47
