    [Plugin] FreeDXF Importer
    148 Posts 41 Posters 206.5k Views 41 Watching
      Jim
      One thing you can try while I work on a fix is to open the .dxf file in an editor such as Notepad++, set the encoding to utf-8, then save the file. It should import correctly.
      But might lose some characters such as this one:
      puts "\x90".force_encoding("cp1251").encode("utf-8")
      Ρ’
      • E
        Elektro
        > Ρ’
        I did the test that you have advised me, but nothing has changed.
        Instead I have converted the files in ANSI, I saved it, and then I imported into Sketchup and ...... cheers now works. πŸ˜„
        • G
          GraceAE1
          I was loving this plug-in , really useful thank you!
          But...alas.. it stopped working on me this morning, it gets to the import screen and then doesn't do anything once I click import. It says at the bottom that it is 'parsing' but nothing more. I have uninstalled and reinstalled. I wonder if anyone has had the problem and if there is either something I am doing wrong, or if this is a common problem?
          I am using Sketchup Make 2016. and AutoCAD LT 2017. But i have tried saving in previous dxf versions of AutoCAD.
          Hoping you can help.
            Jim
            That's odd. Did it stop working for one particular file, or for all files?
            Did you make any other changes to your setup?
            Can you please try to import with the Ruby Console window open and see if any errors show up there?
            • G
              GraceAE1
              Not sure if this contains errors but this is the last few lines of my ruby console:
              FreeDXF/SKUI/window.rb:269:in block in add_callback' SketchUp:1:in call'
              It has stopped working for all files. And i did keep with the same settings. I did try it with a lower circle segment geometry setting just to see if that made a difference...but it didn't.
                Jim
                Actually, it is the top lines that are most important. Sorry for not being clear.
                • G
                  GraceAE1
                  Ah yes sorry this makes more sense:
                  Error: #<Encoding::UndefinedConversionError: "\x81" to UTF-8 in conversion from Windows-1252 to UTF-8>
                    Jim
                    This error is because I am guessing all DXF files are encoded using Windows-1252 which is not always correct. However, I don't know of a way to guess the encoding of the files in order to read them correctly in Ruby. From what I have found it is not easy.
                    If you need a quick fix you can try re-encoding the file in a text editor such as Notepad++ (see just a few posts previous).
                    I am interested in having the file so I can check the HEADER section. The HEADER section of DXF files may have the correct encoding. Can you share it here or in a private message?
                    • G
                      gwirth
                      Is there any way to get old plugins, specifically 0.57? I have some training material that uses SketchUp 8.0 and OpenStudio to do some energy modeling and the training material uses the FreeDXF 0.57 to import some DXF files.
                      I would like to try using the existing training material without having to go through and find out what is different so that I can concentrate on the concepts and not the software.
                      I saw that Jim has a site on GitHub but I didn't see any old releases there. I've tried searching all over with Google but I can't find it anywhere.
                      Gus Wirth, M.Sc.S.E
                      Chief Engineer
                      Anchors Aweigh Energy, LLC
                        Jim
                        Hi Gus,
                        You will need to wait until this afternoon but I can send you a version that works in SketchUp 8.
                          Jim
                          Gus - check your messages.
                          • jujuJ
                            juju
                            Jim, would your importer be written in C/C++ by any chance? If so, how much of a stretch would it be to get it to work in LO?
                              Jim
                              Well, it would be a huge stretch as FreeDXF is a Ruby extension. I don't have plans to re-write it as a C/C++ extension.
                              • G
                                gwirth
                                I did some more digging around and finally found the FreeDFX-v0.57 plugin that I was looking for that works with my training materials. Is there somewhere I can upload it to so that others can find it as well?
                                Smooth Sailing,
                                Gus
                                  Jim
                                  Smooth Sailing,
                                  Gus
                                  You can just attach it to a reply here on this topic.
                                  • G
                                    gwirth
                                    Here is the FreeDXF-0.57 plugin for use with SketchUp 8.0 It is needed to go with the training materials for the California Energy Commission (CEC) CBECC-Com energy modeling software using the OpenStudio plugin for SketchUp.
                                    Gus
                                    For use with SketchUp 8.0
                                      Aurust
                                      I'm having an issue getting this to work on a DXF file saved as 2010 version. I get this error in the Ruby console when I try to import:
                                      Error: #<NoMethodError: undefined method empty?' for nil:NilClass> C:/Users/TEMP.AAP.000/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:1014:in draw_mtext'
                                      C:/Users/TEMP.AAP.000/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:390:in draw' C:/Users/TEMP.AAP.000/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:286:in block in import'
                                      C:/Users/TEMP.AAP.000/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:271:in each' C:/Users/TEMP.AAP.000/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:271:in import'
                                      C:/Users/TEMP.AAP.000/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:236:in do_import' C:/Users/TEMP.AAP.000/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:136:in block in do_options'
                                      C:/Users/TEMP.AAP.000/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:82:in call' C:/Users/TEMP.AAP.000/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:82:in block in trigger_event'
                                      C:/Users/TEMP.AAP.000/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:78:in each' C:/Users/TEMP.AAP.000/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:78:in trigger_event'
                                      C:/Users/TEMP.AAP.000/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/jf-FreeDXF/SKUI/window.rb:357:in event_control_callback' C:/Users/TEMP.AAP.000/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/jf-FreeDXF/SKUI/window.rb:311:in callback_handler'
                                      C:/Users/TEMP.AAP.000/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/jf-FreeDXF/SKUI/window.rb:269:in block in add_callback' SketchUp:1:in call'
                                      Any ideas what is going on?
                                        Until Jim fixes it...
                                        I suspect you have a piece of Mtext in the DXF which is flaky.
                                        Currently the code checks if its 'sting' is empty before continuing, but it doesn't check if it exists !
                                        Edit the file using Notepad++ [TextWrangler on MAC].
                                        Find line 1014 and edit it as follows...
                                        return if txt.empty?
                                        should become...
                                        return if txt.nil?; return if txt.empty?
                                        There might be other instances of this in the code ?
                                        You can search for the other three uses of .empty? and ensure that before each test the existence of the relevant reference with .nil? is invoked. One is already trapped with a return, the next one needs a similar line adding as a fix. The line reading next if l.empty? needs a preceding **next** if l.nil? as that is inside a 'block' rather than in a 'method' and so it should not have a return.
                                          ronjohnson936
                                          I tried to import a .dxf file saved from Inkscape as an Autocad DXF R14 format and nothing happens.
                                          • T
                                            TomDAYarch
                                            When I install the plugin and reopen SkUp (2017), I have an error message appear, telling me:
                                            Error Loading File C:/Users/Resource/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/freedxf/freedxf.rb
                                            Error: #<SyntaxError: C:/Users/Resource/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/freedxf/freedxf.rb:658: syntax error, unexpected ':', expecting keyword_then or ',' or ';' or '\n'
                                            when 1: v = [0 , -h]
                                            C:/Users/Resource/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/freedxf/freedxf.rb:659: syntax error, unexpected keyword_when, expecting keyword_end
                                            when 2: v = [-w/2.0, -h]
                                            C:/Users/Resource/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/freedxf/freedxf.rb:660: syntax error, unexpected keyword_when, expecting keyword_end
                                            when 3: v = [-w , -h]
                                            C:/Users/Resource/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/freedxf/freedxf.rb:661: syntax error, unexpected keyword_when, expecting keyword_end
                                            when 4: v = [0 , -h/2.0]
                                            C:/Users/Resource/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/freedxf/freedxf.rb:662: syntax error, unexpected keyword_when, expecting keyword_end
                                            when 5: v = [-w/2.0, -h/2.0]
                                            C:/Users/Resource/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/freedxf/freedxf.rb:663: syntax error, unexpected keyword_when, expecting keyword_end
                                            when 6: v = [-w , -h/2.0]
                                            C:/Users/Resource/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/freedxf/freedxf.rb:664: syntax error, unexpected keyword_when, expecting keyword_end
                                            when 7: v = [0 , 0]
                                            C:/Users/Resource/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/freedxf/freedxf.rb:665: syntax error, unexpected keyword_when, expecting keyword_end
                                            when 8: v = [-w/2.0, 0]
                                            C:/Users/Resource/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/freedxf/freedxf.rb:666: syntax error, unexpected keyword_when, expecting keyword_end
                                            • 7 / 8
