    [Plugin] FreeDXF Importer
    148 Posts 41 Posters 209.3k Views 41 Watching
    • K
      Kuu
      Nice plugin, works much better than the SketchupPro import. However, there's a few things I've noticed:
      • It does not respect blocks' scaling / orientation properly: blocks that were mirrored in the original DXF sometimes end up in strange positions (this does not happen with the other import).
      • Perhaps related to the last issue, sometimes I saw blocks that had the proper orientation but had ellipse elements that were rotated in 90 or 180 degrees.
      • Layer colors? Why doesn't it keep the DXF layer colors the way the sketchup-included DXF importer does? Currently I work around this by importing it with one (to get the layer colors) and then delete all the geometry/components and reimport with yours, would be awesome to not have to do this.
      • It would be nice if the import also preserved layer visibility, or have a toggle to choose on import. Currently it sets all the layers to visible.
      • Another toggle to merge DXF layer 0 to sketchup's Layer0 would be handy too.
      • Is it possible for it to keep polylines? I don't know if it's a DXF limitation or Sketchup or what. Polylines would be a godsend!
      I'm on SketchUp 2016 and macOS 10.11.6 in case that's relevant...
        Jim
        @kuu said:
        Nice plugin, works much better than the SketchupPro import. However, there's a few things I've noticed: ...
        Hi Kuu, thanks for the feedback.
        Could you provide a minimal .dxf example file, and example result?
        Maybe related, maybe not - ellipses have proven difficult to crack but it's been awhile since I've had a look at it. Again, a minimal sample file demonstrating an incorrect ellipse would be helpful.
        Layer colors? Visibility?
        I wrote this long before SketchUp had support for setting layer colors. Now it does. Can have a look.
        • E
          Elektro
          Good evening.
          I have installed the latest version freeDXF 16th in Sketchup 2016, but I can not
          to import any DXF files.
          I tried to install the older version of freeDXF but nothing has changed.
          Some solution?
            Jim
            @elektro said:
            Good evening.
            Some solution?
            If you open the Ruby Console before attempting to import using FreeDXF, then are there any errors that appear?
            • E
              Elektro
              Hello Jim.
              No before pressing 'Import' in Ruby Console nothing appears, but after I pressed the 'Import' button appears this error:
              Error: #<Encoding::UndefinedConversionError: "\x90" to UTF-8 in conversion from Windows-1252 to UTF-8>
              C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/dxf2ruby.rb:181:in gets' C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/dxf2ruby.rb:181:in read_codes'
              C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/dxf2ruby.rb:58:in parse' C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:269:in import'
              C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:236:in do_import' C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:136:in block in do_options'
              C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:82:in call' C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:82:in block in trigger_event'
              C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:78:in each' C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:78:in trigger_event'
              C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/SKUI/window.rb:357:in event_control_callback' C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/SKUI/window.rb:311:in callback_handler'
              C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/SKUI/window.rb:269:in block in add_callback' SketchUp:1:in call'
                Jim
                Oh so it's an encoding issue. Can you share the file here or in a private message? I don't have an example with which to work out a solution.
                • E
                  Elektro
                  Hello Jim I have attached the file you that I can not open in Sketchup 2016.
                  If this can be of help, this file was saved as 'AutoCAD 2013 Compatible DXF (*.dxf)
                  File_1.dxf
                    Jim
                    One thing you can try while I work on a fix is to open the .dxf file in an editor such as Notepad++, set the encoding to utf-8, then save the file. It should import correctly.
                    But might lose some characters such as this one:
                    puts "\x90".force_encoding("cp1251").encode("utf-8")
                    ђ
                    • E
                      Elektro
                      > ђ
                      I did the test that you have advised me, but nothing has changed.
                      Instead I have converted the files in ANSI, I saved it, and then I imported into Sketchup and ...... cheers now works. 😄
                      • G
                        GraceAE1
                        I was loving this plug-in , really useful thank you!
                        But...alas.. it stopped working on me this morning, it gets to the import screen and then doesn't do anything once I click import. It says at the bottom that it is 'parsing' but nothing more. I have uninstalled and reinstalled. I wonder if anyone has had the problem and if there is either something I am doing wrong, or if this is a common problem?
                        I am using Sketchup Make 2016. and AutoCAD LT 2017. But i have tried saving in previous dxf versions of AutoCAD.
                        Hoping you can help.
                          Jim
                          That's odd. Did it stop working for one particular file, or for all files?
                          Did you make any other changes to your setup?
                          Can you please try to import with the Ruby Console window open and see if any errors show up there?
                          • G
                            GraceAE1
                            Not sure if this contains errors but this is the last few lines of my ruby console:
                            It has stopped working for all files. And i did keep with the same settings. I did try it with a lower circle segment geometry setting just to see if that made a difference...but it didn't.
                              Jim
                              Actually, it is the top lines that are most important. Sorry for not being clear.
                              • G
                                GraceAE1
                                Ah yes sorry this makes more sense:
                                Error: #<Encoding::UndefinedConversionError: "\x81" to UTF-8 in conversion from Windows-1252 to UTF-8>
                                  Jim
                                  This error is because I am guessing all DXF files are encoded using Windows-1252 which is not always correct. However, I don't know of a way to guess the encoding of the files in order to read them correctly in Ruby. From what I have found it is not easy.
                                  If you need a quick fix you can try re-encoding the file in a text editor such as Notepad++ (see just a few posts previous).
                                  I am interested in having the file so I can check the HEADER section. The HEADER section of DXF files may have the correct encoding. Can you share it here or in a private message?
                                  • G
                                    gwirth
                                    Is there any way to get old plugins, specifically 0.57? I have some training material that uses SketchUp 8.0 and OpenStudio to do some energy modeling and the training material uses the FreeDXF 0.57 to import some DXF files.
                                    I would like to try using the existing training material without having to go through and find out what is different so that I can concentrate on the concepts and not the software.
                                    I saw that Jim has a site on GitHub but I didn't see any old releases there. I've tried searching all over with Google but I can't find it anywhere.
                                    Gus Wirth, M.Sc.S.E
                                    Chief Engineer
                                    Anchors Aweigh Energy, LLC
                                      Jim
                                      Hi Gus,
                                      You will need to wait until this afternoon but I can send you a version that works in SketchUp 8.
                                        Jim
                                        Gus - check your messages.
                                        • jujuJ
                                          juju
                                          Jim, would your importer be written in C/C++ by any chance? If so, how much of a stretch would it be to get it to work in LO?
                                            Jim
                                            Well, it would be a huge stretch as FreeDXF is a Ruby extension. I don't have plans to re-write it as a C/C++ extension.
                                            • 7 / 8
