    [Plugin] FreeDXF Importer
    148 Posts 41 Posters 206.5k Views 41 Watching
      mgate
      @driven said:
      are you importing from the Extensions or File menu item ?
      through the Extensions (the dwg format is not available in FreeDXF Importer plugin)
      I looked into the Ruby file "teigha.rb". Is it required an additional file or library called "fileutils"? If so, that file is missing inside "jf-freedxf" folder.
      require "fileutils"
      module JF
        module FreeDXF
          module Teigha
            # Teigha Command Line Format is;
            #   Quoted Input Folder
            #   Quoted Output Folder
            #   Output_version {"ACAD9","ACAD10","ACAD12", "ACAD13","ACAD14", "ACAD2000","ACAD2004", "ACAD2007","ACAD2010"}
            #   Output File type {"DWG","DXF","DXB"}
            #   Recurse Input Folder {"0","1"}
            #   Audit each file {"0","1"}
            #   [optional] Input file filter (default;"*.DWG;*.DXF") (Use File.basename(filename))
             if Sketchup.platform == ;platform_win
                EXE = "C;/Program Files (x86)/ODA/Teigha File Converter 4.01.0/TeighaFileConverter.exe"
             else
                EXE = "/Applications/TeighaFileConverter.app/Contents/MacOS/TeighaFileConverter"
      In my WIN 8.1 Pro, the Teigha sofware is installed in the default folder too:
      Cheers!
      • hdpvH
        hdpv
        I have some update!
        Suforyou
        http://www.sketchupforyou.com
          driven
          @mgate said:
          through the Extensions (the dwg format is not available in FreeDXF Importer plugin)[
          You can select a .dwg or a .dxf file and it should import...
          that's in the SU Ruby folder, so it's already available from there...
          have you tried it with 'Ruby Console' open to see if there are any error messages?
          the other thing to try is doing the conversion directly in TeighaFileConverter, if it fails there you may get a reason given...
            Jim
            Actually, I don't think fileutils is needed. I think I was going to use some methods in fileutils to search for the Teigha converter on the disk drive, but haven't got back to it.
            You can remove or comment out the line.
              mgate
              neither working if commented out the "fileutils" line.
              I have a folder with two files in dxf and dwg formats:
              snapshot of folder with dwg and dxf files
              Once opened the "FreeDXF v.0.11.2" pop-up window, there is only the dxf file (the dwg file is not available):
              snapshot of FreeDXF pop-up window
              Is there a problem with "extra extensions"?
              def self.select_file(extra_extensions = "")
                    title     = 'FreeDXF Select DXF File'
                    directory = nil
                    # filename  = 'DXF|*.dxf|DWG|*.dwg||'
                    filenames = "Cad Files|*.dxf" + extra_extensions + "||"
                    file_path = UI.openpanel(title, directory, filenames)
                    if file_path.nil?
                      return nil
                    else
                      file_path.tr!('\\', '/')
                      @last_selected_file = file_path
                      return file_path
                  def self.main
                     puts "\nFreeDXF debugging ON." if $JFDEBUG
                     extra_extensions = Teigha.available? ? ";*.dwg" ; ""
                     file_path = select_file(extra_extensions)
                     return if file_path.nil?
                     #file_path.downcase!
                     if file_path.end_with?(".dwg")
                        Teigha.dialog()
                        file_path = Teigha.convert(file_path)
                        if file_path.nil?
                           puts "dxf file was not created."
                           return
              Any idea how to solve?
              Another way is to convert dwg files manually with TeighaFileConverter, and then use FreeDXF plugin in SKU.
              Sorry to snoop around your codes 😐
                Jim
                This appears to be due to a difference between SketchUp 15 and SketchUp 16 UI.openpanel behavior.
                As a short-term work-around, can you try to enter a * then press ENTER in the filename dropdown to force all files to be listed?
                • atelierpaarA
                  atelierpaar
                  Hello Jim
                  A couple of days ago I posted a request for a plugin that would import measurements directly from a 3D Laser "Leica Disto S910 " in order to draw direct on site.
                  404 Not Found
                  (sketchucation.com)
                  Could your plugin be developed to do the Job ?
                  Thanks for your response
                  Uli
                  • K
                    Kuu
                    Nice plugin, works much better than the SketchupPro import. However, there's a few things I've noticed:
                    β€’ It does not respect blocks' scaling / orientation properly: blocks that were mirrored in the original DXF sometimes end up in strange positions (this does not happen with the other import).
                    β€’ Perhaps related to the last issue, sometimes I saw blocks that had the proper orientation but had ellipse elements that were rotated in 90 or 180 degrees.
                    β€’ Layer colors? Why doesn't it keep the DXF layer colors the way the sketchup-included DXF importer does? Currently I work around this by importing it with one (to get the layer colors) and then delete all the geometry/components and reimport with yours, would be awesome to not have to do this.
                    β€’ It would be nice if the import also preserved layer visibility, or have a toggle to choose on import. Currently it sets all the layers to visible.
                    β€’ Another toggle to merge DXF layer 0 to sketchup's Layer0 would be handy too.
                    β€’ Is it possible for it to keep polylines? I don't know if it's a DXF limitation or Sketchup or what. Polylines would be a godsend!
                    I'm on SketchUp 2016 and macOS 10.11.6 in case that's relevant...
                      Jim
                      @kuu said:
                      Nice plugin, works much better than the SketchupPro import. However, there's a few things I've noticed: ...
                      Hi Kuu, thanks for the feedback.
                      Could you provide a minimal .dxf example file, and example result?
                      Maybe related, maybe not - ellipses have proven difficult to crack but it's been awhile since I've had a look at it. Again, a minimal sample file demonstrating an incorrect ellipse would be helpful.
                      Layer colors? Visibility?
                      I wrote this long before SketchUp had support for setting layer colors. Now it does. Can have a look.
                      • E
                        Elektro
                        Good evening.
                        I have installed the latest version freeDXF 16th in Sketchup 2016, but I can not
                        to import any DXF files.
                        I tried to install the older version of freeDXF but nothing has changed.
                        Some solution?
                          Jim
                          @elektro said:
                          Good evening.
                          Some solution?
                          If you open the Ruby Console before attempting to import using FreeDXF, then are there any errors that appear?
                          • E
                            Elektro
                            Hello Jim.
                            No before pressing 'Import' in Ruby Console nothing appears, but after I pressed the 'Import' button appears this error:
                            Error: #<Encoding::UndefinedConversionError: "\x90" to UTF-8 in conversion from Windows-1252 to UTF-8>
                            C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/dxf2ruby.rb:181:in gets' C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/dxf2ruby.rb:181:in read_codes'
                            C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/dxf2ruby.rb:58:in parse' C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:269:in import'
                            C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:236:in do_import' C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:136:in block in do_options'
                            C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:82:in call' C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:82:in block in trigger_event'
                            C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:78:in each' C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:78:in trigger_event'
                            C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/SKUI/window.rb:357:in event_control_callback' C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/SKUI/window.rb:311:in callback_handler'
                            C:/Users/Roberto/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jf-FreeDXF/SKUI/window.rb:269:in block in add_callback' SketchUp:1:in call'
                              Jim
                              Oh so it's an encoding issue. Can you share the file here or in a private message? I don't have an example with which to work out a solution.
                              • E
                                Elektro
                                Hello Jim I have attached the file you that I can not open in Sketchup 2016.
                                If this can be of help, this file was saved as 'AutoCAD 2013 Compatible DXF (*.dxf)
                                File_1.dxf
                                  Jim
                                  One thing you can try while I work on a fix is to open the .dxf file in an editor such as Notepad++, set the encoding to utf-8, then save the file. It should import correctly.
                                  But might lose some characters such as this one:
                                  puts "\x90".force_encoding("cp1251").encode("utf-8")
                                  Ρ’
                                  • E
                                    Elektro
                                    > Ρ’
                                    I did the test that you have advised me, but nothing has changed.
                                    Instead I have converted the files in ANSI, I saved it, and then I imported into Sketchup and ...... cheers now works. πŸ˜„
                                    • G
                                      GraceAE1
                                      I was loving this plug-in , really useful thank you!
                                      But...alas.. it stopped working on me this morning, it gets to the import screen and then doesn't do anything once I click import. It says at the bottom that it is 'parsing' but nothing more. I have uninstalled and reinstalled. I wonder if anyone has had the problem and if there is either something I am doing wrong, or if this is a common problem?
                                      I am using Sketchup Make 2016. and AutoCAD LT 2017. But i have tried saving in previous dxf versions of AutoCAD.
                                      Hoping you can help.
                                        Jim
                                        That's odd. Did it stop working for one particular file, or for all files?
                                        Did you make any other changes to your setup?
                                        Can you please try to import with the Ruby Console window open and see if any errors show up there?
                                        • G
                                          GraceAE1
                                          Not sure if this contains errors but this is the last few lines of my ruby console:
                                          It has stopped working for all files. And i did keep with the same settings. I did try it with a lower circle segment geometry setting just to see if that made a difference...but it didn't.
                                            Jim
                                            Actually, it is the top lines that are most important. Sorry for not being clear.
                                            • 7 / 8
