    [Plugin] WebGL Cubic Panorama (update 2016-05-06)
    71 Posts 18 Posters 17.0k Views 18 Watching
    • OxerO Offline
      Oxer
      The title doesn't appear, see the image.
      • OxerO Offline
        Oxer
        It's rare, but the window title to Choose Output Folder appears when click in Make panorama icon.
        (I have translate the plugin to Spanish language)
        • rami_lpmR Offline
          rami_lpm
          So strange.
          Makes no sense that UI.openpanel has this bug and UI.savepanel doesn't.
          I guess it's a problem with ruby and OS X. I'll see if there is a way around it.
          Thanks for letting me know.
          • F Offline
            faust07
            Late answer after my vacation. To pack a panorama in one HTML file, works very well. Great job. 👍 Here's an example. I found no way to assign a file name from the pull-down menu. It always wants open an existing file.
            unzip - includes panoramic html-file
            test scene
            • rami_lpmR Offline
              rami_lpm
              Thanks.
              Nice scene!
              Yes, filenames are a little restricted because I wrote the plugin mostly for the web.
              What filenames would you like to change?
              • F Offline
                faust07
                After some consideration the predefined names are fine. A small inconsistency is at the upper side of the cube, when I use the default SketchUp sky. This is not shown in the panoramas in the color of the sky but in the background color.
                • brettsichellodesignB Offline
                  brettsichellodesign
                  I am getting some problems with this plugin in SU 2017. The images don't appear to be stitching together properly.
                  • rami_lpmR Offline
                    rami_lpm
                    I haven't tested it in SU 2017 yet. I'll see what I can do.
                    Thanks for the heads up.
                    • rami_lpmR Offline
                      rami_lpm
                      Ok, I've tested it, it appears that the exported images have a black border (bottom and right).
                      Can anyone else confirm this?
                      I'll try and fix it.
                      • srxS Offline
                        srx
                        Yes. The edges of the box are visible.
                        www.saurus.rs
                        • rami_lpmR Offline
                          rami_lpm
                          I've found a workaround, if you set the resolution to 1020 or 2036, the edges are gone.
                          • rami_lpmR Offline
                            rami_lpm
                            Hey pilou, is that on windows or mac? I've tested it on windows 10 and and the only problem was the border around images.
                              In 2017 Upper face cube is always green!
                                Windows 10
                                But I have made any regulates!
                                pano1.zip
                                • rami_lpmR Offline
                                  rami_lpm
                                  I see. this happens in SU 2016 as well.
                                  Apparently looking straight up renders the style background color, not the sky color.
                                  To avoid this glitch, you should make them both the same color.
                                  • srxS Offline
                                    srx
                                    Interesting. Everything is ok when rendered using Thea. No edges. It is about SU export.
                                    www.saurus.rs
                                      AKHLPZ
                                      Hello,
                                      is there any fix for issue with SU2017 ?
                                      i have 2 issues with the WebGL cubic pano plugin:
                                      1. on the cubepictures is a black edge on the right side and down side
                                      2. the cube is consisting of 6 pictures and my progam is unable to recognize/build a panorama.
                                      please, help.
                                      • rami_lpmR Offline
                                        rami_lpm
                                        Not yet.
                                        Have you tried modifying the resolution to 1020,2040 or 4080?
                                        What program are you using? this is for cubic panoramas, and the plugin generates the html needed to show the result.
                                          AKHLPZ
                                          Yes, when i change the resolution for this values, the black boarder is never seen.
                                          I work with Kolor Panotour Pro and when i load the builded 6 pictures, Kolor Panotour Pro can not recognize the cubic pano.
                                          When i build this 6 pictures with a cubicpanoout.rb script, Kolor Panotour Pro work proper fine.
                                            brettsichellodesign
                                            I am still having problems with this plugin.
                                            I have tried changing the resolution and FOV and still getting weird black lines as shown below:
                                            https://s28.postimg.org/521fh77jh/pano_test.jpg
                                            I did try it on a lower resolution which made the lines disappear. However, I would like to create higher resolution images.
                                            • 4 / 4
