    [Plugin] WebGL Cubic Panorama (update 2016-05-06)
    71 Posts 18 Posters 20.5k Views 18 Watching
    • F Offline
      faust07
      Works great even with pictures from scenes of external renderers. Issuing panoramas directly from SketchUp results for large models to the known clipping problem, especially from the pedestrian perspective in the bottom area. And especially when shadows are enabled.
      A short question: Is it feasible to reduce the many generated files to one html Start file and another file containing everything else (especially with several panoramas)?
      • rami_lpmR Offline
        rami_lpm
        I work in metric and rarely encountered the clipping problem.
        Can you try scaling up the model before taking the panorama? (a pain, I know, but the only solution I can think of)
        Sadly, no. I can't reduce the number of files. Each file is required and I don't know a way of packing them all together.
        Maybe you can try generating the images with CubicPanoOut and stitching them with GoCubic. This outputs a single quicktime file for each panorama.
        That is what I used to do before writing this plugin (so I could stop relying on quicktime).
        CubicPanoOut
        GoCubic
        Anyway, I'll try and find a 'one file' solution.
        • F Offline
          faust07
          Thank you for your quick response. The clipping problem is already mitigated by the possibility of external rendering of scenes. Reducing the number of files is only for the ease of use for normal users, clients or patients ... ๐Ÿ˜‰
          • rami_lpmR Offline
            rami_lpm
            No problem.
            Hey, it turns out you can inline almost everything into a single html file. See this two articles. I'll see what I can do with this.
            Offline Application
            Inliner
            • F Offline
              faust07
              That sounds great! I have looked into it ... I once - over 20 years ago - programmed a little and am now primarily user. So I understand very little and can only be amazed by your progress.
              • rami_lpmR Offline
                rami_lpm
                I just updated the plugin.
                It should be able to wrap every panorama inside one rather big html file.
                Also, I realized that I myself started learning to code 20 years ago. Now I feel old. =P
                • OxerO Offline
                  Oxer
                  Thanks for the plugin!!
                  I use Thea Render and works fine replacing the images generated for the plugin with images generated for Thea Render, only one question, when I select Custom Template, the titles to select the different filetype don't appear in the pop-up windows, see the image.
                  MAC 0S X 10.11.4 & SU2016
                  • rami_lpmR Offline
                    rami_lpm
                    Thank you for the feedback.
                    That's a strange behavior. 'custom template' requests three template files: html, css and js in that order.
                    Can you try pasting this line in the ruby console and telling me if it shows the title?
                    UI.openpanel("can you read this?", "~/","yes")
                    • OxerO Offline
                      Oxer
                      The title doesn't appear, see the image.
                      • OxerO Offline
                        Oxer
                        It's rare, but the window title to Choose Output Folder appears when click in Make panorama icon.
                        (I have translate the plugin to Spanish language)
                        • rami_lpmR Offline
                          rami_lpm
                          So strange.
                          Makes no sense that UI.openpanel has this bug and UI.savepanel doesn't.
                          I guess it's a problem with ruby and OS X. I'll see if there is a way around it.
                          Thanks for letting me know.
                          • F Offline
                            faust07
                            Late answer after my vacation. To pack a panorama in one HTML file, works very well. Great job. ๐Ÿ‘ Here's an example. I found no way to assign a file name from the pull-down menu. It always wants open an existing file.
                            unzip - includes panoramic html-file
                            test scene
                            • rami_lpmR Offline
                              rami_lpm
                              Thanks.
                              Nice scene!
                              Yes, filenames are a little restricted because I wrote the plugin mostly for the web.
                              What filenames would you like to change?
                              • F Offline
                                faust07
                                After some consideration the predefined names are fine. A small inconsistency is at the upper side of the cube, when I use the default SketchUp sky. This is not shown in the panoramas in the color of the sky but in the background color.
                                • brettsichellodesignB Offline
                                  brettsichellodesign
                                  I am getting some problems with this plugin in SU 2017. The images don't appear to be stitching together properly.
                                  • rami_lpmR Offline
                                    rami_lpm
                                    I haven't tested it in SU 2017 yet. I'll see what I can do.
                                    Thanks for the heads up.
                                    • rami_lpmR Offline
                                      rami_lpm
                                      Ok, I've tested it, it appears that the exported images have a black border (bottom and right).
                                      Can anyone else confirm this?
                                      I'll try and fix it.
                                      • srxS Offline
                                        srx
                                        Yes. The edges of the box are visible.
                                        www.saurus.rs
                                        • rami_lpmR Offline
                                          rami_lpm
                                          I've found a workaround, if you set the resolution to 1020 or 2036, the edges are gone.
                                          • rami_lpmR Offline
                                            rami_lpm
                                            Hey pilou, is that on windows or mac? I've tested it on windows 10 and and the only problem was the border around images.
                                            • 3 / 4
