    [Plugin] WebGL Cubic Panorama (update 2016-05-06)
    71 Posts 18 Posters 20.2k Views 18 Watching
    • rami_lpmR Offline
      rami_lpm
      No problem.
      Hey, it turns out you can inline almost everything into a single html file. See this two articles. I'll see what I can do with this.
      Offline Application
      Inliner
      • F Offline
        faust07
        That sounds great! I have looked into it ... I once - over 20 years ago - programmed a little and am now primarily user. So I understand very little and can only be amazed by your progress.
        • rami_lpmR Offline
          rami_lpm
          I just updated the plugin.
          It should be able to wrap every panorama inside one rather big html file.
          Also, I realized that I myself started learning to code 20 years ago. Now I feel old. =P
          • OxerO Offline
            Oxer
            Thanks for the plugin!!
            I use Thea Render and works fine replacing the images generated for the plugin with images generated for Thea Render, only one question, when I select Custom Template, the titles to select the different filetype don't appear in the pop-up windows, see the image.
            MAC 0S X 10.11.4 & SU2016
            • rami_lpmR Offline
              rami_lpm
              Thank you for the feedback.
              That's a strange behavior. 'custom template' requests three template files: html, css and js in that order.
              Can you try pasting this line in the ruby console and telling me if it shows the title?
              UI.openpanel("can you read this?", "~/","yes")
              • OxerO Offline
                Oxer
                The title doesn't appear, see the image.
                • OxerO Offline
                  Oxer
                  It's rare, but the window title to Choose Output Folder appears when click in Make panorama icon.
                  (I have translate the plugin to Spanish language)
                  • rami_lpmR Offline
                    rami_lpm
                    So strange.
                    Makes no sense that UI.openpanel has this bug and UI.savepanel doesn't.
                    I guess it's a problem with ruby and OS X. I'll see if there is a way around it.
                    Thanks for letting me know.
                    • F Offline
                      faust07
                      Late answer after my vacation. To pack a panorama in one HTML file, works very well. Great job. 👍 Here's an example. I found no way to assign a file name from the pull-down menu. It always wants open an existing file.
                      unzip - includes panoramic html-file
                      test scene
                      • rami_lpmR Offline
                        rami_lpm
                        Thanks.
                        Nice scene!
                        Yes, filenames are a little restricted because I wrote the plugin mostly for the web.
                        What filenames would you like to change?
                        • F Offline
                          faust07
                          After some consideration the predefined names are fine. A small inconsistency is at the upper side of the cube, when I use the default SketchUp sky. This is not shown in the panoramas in the color of the sky but in the background color.
                          • brettsichellodesignB Offline
                            brettsichellodesign
                            I am getting some problems with this plugin in SU 2017. The images don't appear to be stitching together properly.
                            • rami_lpmR Offline
                              rami_lpm
                              I haven't tested it in SU 2017 yet. I'll see what I can do.
                              Thanks for the heads up.
                              • rami_lpmR Offline
                                rami_lpm
                                Ok, I've tested it, it appears that the exported images have a black border (bottom and right).
                                Can anyone else confirm this?
                                I'll try and fix it.
                                • srxS Offline
                                  srx
                                  Yes. The edges of the box are visible.
                                  www.saurus.rs
                                  • rami_lpmR Offline
                                    rami_lpm
                                    I've found a workaround, if you set the resolution to 1020 or 2036, the edges are gone.
                                    • rami_lpmR Offline
                                      rami_lpm
                                      Hey pilou, is that on windows or mac? I've tested it on windows 10 and and the only problem was the border around images.
                                        In 2017 Upper face cube is always green!
                                          Windows 10
                                          But I have made any regulates!
                                          pano1.zip
                                          • rami_lpmR Offline
                                            rami_lpm
                                            I see. this happens in SU 2016 as well.
                                            Apparently looking straight up renders the style background color, not the sky color.
                                            To avoid this glitch, you should make them both the same color.
                                            • 3 / 4
