    RFA Fort Victoria
    17 Posts 7 Posters 3.1k Views 7 Watching
    • Bryan KB
      Wow. 😮
      • marked001M
        marked001
        amazing stuff, liam. the detail in the model is great. wish i had that kind of patience. i really like the feel of this last image with the hard shadows. can't wait to see the animation.
        http://www.revision21vis.com
        instagram: revi21on
        • L
          liam887
          Cheers, there is not really that much too it, mostly variation of the same component. Here is my SLS launch gantry that itself is only made of a few repeated components. This is the building block or nearly all of the detail work you see on the model (highlighted in red).
          The animation is going to be in the hard shadow theme so there will be no rendering. I have been working on it all day and I have an idea of how it's going to pull off. Basically Sketchup Stop motion and compiling in AE!
          EDIT: However because I used this as the detailing it means the Oil Tanker is massive, between 75-100 stories I cant remember exactly...
          VISIT MY ONLINE GALLERY
          • HornOxxH
            HornOxx
            Both are so cool: Liam´s great modeling and gallery as well as Paul Chadeisson´s art work. Thanks for posting this ...
            never trust a skinny cook
            • L
              liam887
              Ok have decided to just use Photoshop for the animation. Here is the first test: http://gph.is/2fS4QwD
              Let me know what you think.
              Fastly error: unknown domain 151.101.1.55
              (giphy.com)
              • L
                liam887
                Finished, that took a while 😞
                I did plan on animating the clouds to give some forward movement but Photoshop is acting up and its time for bed, until tomorrow!
                Fastly error: unknown domain 151.101.1.91
                (gph.is)
                • marked001M
                  marked001
                  That's perfect! Love it.
                  instagram: revi21on
                  • pbacotP
                    If the propellers moved faster, the frigates moved slowly, and plus move the clouds or even the background (more slowly- just a little travel) you'd have a complete scene. Great work! How do these things stay in the air?
                    • L
                      liam887
                      To save time I only rotated the propellers 24 frames per second about 15 degrees each time, The plan is to move the clouds and the background but Photoshop is playing up and my key frames wont stick, I will have to go back to it when I figure out what is going wrong. Ideally I want both sets of propellers going opposite ways.
                      Because the animation is a GIF I need the first frame to e the same as the last frame so I cant move things too much, it gets tricky!
                      No idea how they fly lol, magic I suppose.
                      • pbacotP
                        "Because the animation is a GIF I need the first frame to e the same as the last frame so I cant move things too much, it gets tricky!" Oh. But can you make it jump back for the last frame?
                        • L
                          liam887
                          Its proving quite difficult, the animation is set on an infinite loop so it keeps on going, in order for it to be fluid you cant just jump back to frame 1. I am working on cutting the cloud layer in half and then inverting it so that the start is also the end and it just keeps on going seamlessly (in principal, harder in practice 😞 )
